Как мне превратить ÄîÁðî ïîæàëîâàòü в нормальный русский текст силами или python или на худой конец php
Код (Python): #!/usr/bin/python #-*- coding: utf-8 -*- # Example using a character LCD connected to a Raspberry Pi or BeagleBone Black. import sys import time import MySQLdb from datetime import datetime from subprocess import * import Adafruit_CharLCD as LCD reload(sys) sys.setdefaultencoding('utf-8') # Raspberry Pi pin configuration: lcd_rs = 25 # Note this might need to be changed to 21 for older revision Pi's. lcd_en = 24 lcd_d4 = 22 lcd_d5 = 23 lcd_d6 = 18 lcd_d7 = 17 lcd_backlight = 4 # BeagleBone Black configuration: # lcd_rs = 'P8_8' # lcd_en = 'P8_10' # lcd_d4 = 'P8_18' # lcd_d5 = 'P8_16' # lcd_d6 = 'P8_14' # lcd_d7 = 'P8_12' # lcd_backlight = 'P8_7' # Define LCD column and row size for 16x2 LCD. #lcd_columns = 16 #lcd_rows = 2 # Alternatively specify a 20x4 LCD. lcd_columns = 20 lcd_rows = 4 # Initialize the LCD using the pins above. lcd = LCD.Adafruit_CharLCD(lcd_rs, lcd_en, lcd_d4, lcd_d5, lcd_d6, lcd_d7, lcd_columns, lcd_rows, lcd_backlight) moment = datetime.now().strftime(' %d.%m.%Y %H:%M \n') greeting='Добро пожаловать'.encode('utf-8') db=MySQLdb.connect("localhost", "nigger", "all_cops_are_bastards", "ghetto") cursor=db.cursor() sql = "UPDATE text_display SET text =' %s' WHERE id ='1';" % greeting cursor.execute (sql) sql = "UPDATE text_display SET text ='%s' WHERE id ='2';" % moment cursor.execute (sql) sql = "UPDATE text_display SET text =' ' WHERE id ='3';" cursor.execute (sql) sql = "UPDATE text_display SET text =' ' WHERE id ='4';" cursor.execute (sql) db.commit() db.close() # Print a two line message lcd.write8(0b101010) #lcd.message(' Welcome!\n') lcd.message(' \xC4\xEE\xC1\xF0\xEE \xEF\xEE\xE6\xE0\xEB\xEE\xE2\xE0\xF2\xFC\n') lcd.message(datetime.now().strftime(' %d.%m.%Y %H:%M \n')) lcd.backlight(0) #lcd.message('\xC4\xEE\xC1\xF0\xEE \xEF\xEE\xE6\xE0\xEB\xEE\xE2\xE0\xF2\xFC') time.sleep(0.5)
Всё равно не понятно, вам иероглифы из БД приходят? Или записываются туда иероглифы? Попробуйте в самом начала сделать забрось к БД PHP: set names utf8
Используйте различные кодировки, возможно стоит использовать cp1251 (иногда её обозначают как windows-1251)
Пробуйте кодировки для БД cp1251_general_ci или utf8_unicode_ci db = MySQLdb.connect(host="example.com",user='user',passwd='passwd',db='db',charset='cp1251')
