Как перенести всю OC Rasbian с одной SD карты на другую?
Тема в разделе "Raspberry Pi", создана пользователем HerMak, 4 май 2018.
  1. HerMak
    HerMak Нуб
    Есть СД карточка на 8 гб. Сегодня я посчитал, что 8 гб мало...Нужно 16.Но вот тут проблема, как перенести уже установленную ОС со всеми настройками на другую СД карточку?
  2. Igor68
    Igor68 Гуру
    Про DD ничего не слышали?
    www-data@pi01:~$ dd --help
    Usage: dd [OPERAND]...
      or:  dd OPTION
    Copy a file, converting and formatting according to the operands.
      bs=BYTES        read and write up to BYTES bytes at a time
      cbs=BYTES       convert BYTES bytes at a time
      conv=CONVS      convert the file as per the comma separated symbol list
      count=N         copy only N input blocks
      ibs=BYTES       read up to BYTES bytes at a time (default: 512)
      if=FILE         read from FILE instead of stdin
      iflag=FLAGS     read as per the comma separated symbol list
      obs=BYTES       write BYTES bytes at a time (default: 512)
      of=FILE         write to FILE instead of stdout
      oflag=FLAGS     write as per the comma separated symbol list
      seek=N          skip N obs-sized blocks at start of output
      skip=N          skip N ibs-sized blocks at start of input
      status=WHICH    WHICH info to suppress outputting to stderr;
                      'noxfer' suppresses transfer stats, 'none' suppresses all
    N and BYTES may be followed by the following multiplicative suffixes:
    c =1, w =2, b =512, kB =1000, K =1024, MB =1000*1000, M =1024*1024, xM =M
    GB =1000*1000*1000, G =1024*1024*1024, and so on for T, P, E, Z, Y.
    Each CONV symbol may be:
      ascii     from EBCDIC to ASCII
      ebcdic    from ASCII to EBCDIC
      ibm       from ASCII to alternate EBCDIC
      block     pad newline-terminated records with spaces to cbs-size
      unblock   replace trailing spaces in cbs-size records with newline
      lcase     change upper case to lower case
      ucase     change lower case to upper case
      sparse    try to seek rather than write the output for NUL input blocks
      swab      swap every pair of input bytes
      sync      pad every input block with NULs to ibs-size; when used
                with block or unblock, pad with spaces rather than NULs
      excl      fail if the output file already exists
      nocreat   do not create the output file
      notrunc   do not truncate the output file
      noerror   continue after read errors
      fdatasync  physically write output file data before finishing
      fsync     likewise, but also write metadata
    Each FLAG symbol may be:
      append    append mode (makes sense only for output; conv=notrunc suggested)
      direct    use direct I/O for data
      directory  fail unless a directory
      dsync     use synchronized I/O for data
      sync      likewise, but also for metadata
      fullblock  accumulate full blocks of input (iflag only)
      nonblock  use non-blocking I/O
      noatime   do not update access time
      nocache   discard cached data
      noctty    do not assign controlling terminal from file
      nofollow  do not follow symlinks
      count_bytes  treat 'count=N' as a byte count (iflag only)
      skip_bytes  treat 'skip=N' as a byte count (iflag only)
      seek_bytes  treat 'seek=N' as a byte count (oflag only)
    Sending a USR1 signal to a running 'dd' process makes it
    print I/O statistics to standard error and then resume copying.
      $ dd if=/dev/zero of=/dev/null& pid=$!
      $ kill -USR1 $pid; sleep 1; kill $pid
      18335302+0 records in
      18335302+0 records out
      9387674624 bytes (9.4 GB) copied, 34.6279 seconds, 271 MB/s
    Options are:
          --help     display this help and exit
          --version  output version information and exit
    GNU coreutils online help: <http://www.gnu.org/software/coreutils/>
    Full documentation at: <http://www.gnu.org/software/coreutils/dd>
    or available locally via: info '(coreutils) dd invocation'
    www-data@pi01:~$
    Это если копировать по Linux.
  3. HerMak
    HerMak Нуб
    К сожалению нет, я только начинающий пользователь Raspbian :C
  4. Igor68
    Igor68 Гуру
    В таком случае установите Linux (Хоть есть метод копирования образов и для windows - но давно не использую... уже на помню) как виртуальную машину... ну допустим в Virtualbox или иное.
    Потом вставляете SD кару в PC... при этом дав доступ к ней виртуальному Linux(Debian, Ubuntu и ...) и дав доступ к ней виртуальной машине. Если основная система Linux, то виртуалка ни к чему. И устройство (SD) не должно быть "примонтировано".
    Далее
    dd if=/dev/<устройтво - Ваша SD> of=<путь и имя файла куда скинете образ с Вашей SD-карты>
    это если одно устройство чтения/записи SD карты. А если два устройства то то
    dd if=/dev/<устройтво - Ваша SD с которой читаетк > of=/dev/<устройство SD на которую надо перенести>
    Устройство на которое переносится копия должно быть не меньше образа.
    После установки новой карты в случае копирования из образа:
    dd if=<путь и имя файла куда уже скинули образ с Вашей SD-карты> of=/dev/<устройтво - Ваша SD куда копируете образ>
    null нравится это.
  5. Jeid
    Jeid Нерд
    Утилита с помощью который вы записывали образ на эту флешку так же может и прочитать содержимое флешки.
    Я использую Win32DiskImager (волде бы так называется)
    Hotboll нравится это.
