Добрый день! Помогите понять в чем трабла: Приобрел плату arduino-ethernet-shield - https://amperka.ru/product/arduino-ethernet-shield Установил на UNO3. Но сконфигурировать так и не получилось. Вывод в монитор порта: 0.0.0.0 Failed to configure Ethernet using DHCP 255.255.255.255 connecting... 255.255.255.255 255.255.255.255 255.255.255.255 connection failed disconnecting. Код: Код (C++): /* Web client This sketch connects to a website (http://www.google.com) using an Arduino Wiznet Ethernet shield. Circuit: * Ethernet shield attached to pins 10, 11, 12, 13 created 18 Dec 2009 by David A. Mellis modified 9 Apr 2012 by Tom Igoe, based on work by Adrian McEwen */ #include<SPI.h> #include<Ethernet2.h> // Enter a MAC address for your controller below. // Newer Ethernet shields have a MAC address printed on a sticker on the shield uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // if you don't want to use DNS (and reduce your sketch size) // use the numeric IP instead of the name for the server: //IPAddress server(74,125,232,128); // numeric IP for Google (no DNS) char server[] = "www.google.com"; // name address for Google (using DNS) // Set the static IP address to use if the DHCP fails to assign IPAddressip(192, 168, 0, 177); uint8_t ipp[]={192, 168, 0, 177}; // Initialize the Ethernet client library // with the IP address and port of the server // that you want to connect to (port 80 is default for HTTP): EthernetClient client; voidsetup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } Serial.println(Ethernet.localIP()); // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { // Ethernet.init(); Serial.println("Failed to configure Ethernet using DHCP"); Serial.println(Ethernet.localIP()); // no point in carrying on, so do nothing forevermore: // try to congifure using IP address instead of DHCP: Ethernet.begin(mac, ip); } // give the Ethernet shield a second to initialize: delay(1000); Serial.println("connecting..."); Serial.println(Ethernet.localIP()); w5500.setIPAddress(ipp); w5500.getIPAddress(ipp); Serial.println(Ethernet.localIP()); Serial.println(Ethernet.gatewayIP()); // if you get a connection, report back via serial: if (client.connect(server, 80)) { Serial.println("connected"); // Make a HTTP request: client.println("GET /search?q=arduino HTTP/1.1"); client.println("Host: www.google.com"); client.println("Connection: close"); client.println(); } else { // kf you didn't get a connection to the server: Serial.println("connection failed"); } } voidloop() { // if there are incoming bytes available // from the server, read them and print them: if (client.available()) { char c = client.read(); Serial.print(c); } // if the server's disconnected, stop the client: if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); client.stop(); // do nothing forevermore: while (true); } }
