Помогите со скетчем.
Тема в разделе "Моторы, сервоприводы, робототехника", создана пользователем Серый Волк, 8 янв 2021.
  1. Приветствую всех!
    Взял готовый скетч с официальной страницы Remote XY здесь https://remotexy.com/en/examples/car/
    //        RemoteXY include library         //
    /* RemoteXY select connection mode and include library */
    #define REMOTEXY_MODE__SOFTWARESERIAL
    #include <SoftwareSerial.h>
    #include <RemoteXY.h>
    /* RemoteXY connection settings */
    #define REMOTEXY_SERIAL_RX 2
    #define REMOTEXY_SERIAL_TX 3
    #define REMOTEXY_SERIAL_SPEED 9600
    /* RemoteXY configurate  */
    unsigned char RemoteXY_CONF[] =
      { 3,0,23,0,1,5,5,15,41,11
      ,43,43,1,2,0,6,5,27,11,5
      ,79,78,0,79,70,70,0 };
    /* this structure defines all the variables of your control interface */
    struct {
        /* input variable */
      signed char joystick_1_x; /* =-100..100 x-coordinate joystick position */
      signed char joystick_1_y; /* =-100..100 y-coordinate joystick position */
      unsigned char switch_1; /* =1 if switch ON and =0 if OFF */
        /* other variable */
      unsigned char connect_flag;  /* =1 if wire connected, else =0 */
    } RemoteXY;
    //           END RemoteXY include          //
    /* defined the right motor control pins */
    #define PIN_MOTOR_RIGHT_UP 7
    #define PIN_MOTOR_RIGHT_DN 6
    #define PIN_MOTOR_RIGHT_SPEED 10
    /* defined the left motor control pins */
    #define PIN_MOTOR_LEFT_UP 5
    #define PIN_MOTOR_LEFT_DN 4
    #define PIN_MOTOR_LEFT_SPEED 9
    /* defined the LED pin */
    #define PIN_LED 13
    /* defined two arrays with a list of pins for each motor */
    unsigned char RightMotor[3] =
      {PIN_MOTOR_RIGHT_UP, PIN_MOTOR_RIGHT_DN, PIN_MOTOR_RIGHT_SPEED};
    unsigned char LeftMotor[3] =
      {PIN_MOTOR_LEFT_UP, PIN_MOTOR_LEFT_DN, PIN_MOTOR_LEFT_SPEED};
       speed control of the motor
       motor - pointer to an array of pins
       v - motor speed can be set from -100 to 100
    void Wheel (unsigned char * motor, int v)
      if (v>100) v=100;
      if (v<-100) v=-100;
      if (v>0) {
        digitalWrite(motor[0], HIGH);
        digitalWrite(motor[1], LOW);
        analogWrite(motor[2], v*2.55);
      else if (v<0) {
        digitalWrite(motor[0], LOW);
        digitalWrite(motor[1], HIGH);
        analogWrite(motor[2], (-v)*2.55);
      else {
        analogWrite(motor[2], 0);
      /* initialization pins */
      pinMode (PIN_MOTOR_RIGHT_UP, OUTPUT);
      pinMode (PIN_MOTOR_RIGHT_DN, OUTPUT);
      pinMode (PIN_MOTOR_LEFT_UP, OUTPUT);
      pinMode (PIN_MOTOR_LEFT_DN, OUTPUT);
      pinMode (PIN_LED, OUTPUT);
      /* initialization module RemoteXY */
      RemoteXY_Init ();
      /* event handler module RemoteXY */
      RemoteXY_Handler ();
      /* manage LED pin */
      digitalWrite (PIN_LED, (RemoteXY.switch_1==0)?LOW:HIGH);
      /* manage the right motor */
      Wheel (RightMotor, RemoteXY.joystick_1_y - RemoteXY.joystick_1_x);
      /* manage the left motor */
      Wheel (LeftMotor, RemoteXY.joystick_1_y + RemoteXY.joystick_1_x);
    Заработал он сходу с Remote XY, но не так как мне нужно.
    Нужно чтоб при движении джойстика (право-лево) один мотор вперёд и назад крутился, а при движении джойстика (вверх-вниз) второй мотор .
    Это можно сделать что то в этом скетче изменив, или нужно переписывать всё по новой.
  2. Так как мне нужно работает если нажимать джойстик по диагоналям.
  3. Asper Daffy
    Asper Daffy Иксперд
    Можно.
    Серый Волк нравится это.
  4. Понятно.))
  5. Прошу прощения у администрации за неправильно вставленный код.
  6. Airbus
    Хорошо что сам справился)))
