Код (Javascript): var SSID = '111'; var PASSWORD = '111'; var NAME = '111'; var temp = require('@amperka/thermometer').connect(A2); var dweet = require('@amperka/dweetio').connect(NAME); function run() { setInterval(function() { dweet.send({ temperature: Math.floor(temp.read('C')) }); }, 1000); } var wifi = require('@amperka/wifi').setup(function(err) { wifi.connect(SSID, PASSWORD, function(err) { print('Click this link', dweet.follow()); run(); }); });
ISKRA JS, 2v01.49 просто просто отключается вай фай и перестаёт передавать, вот такая ошибка в конце. Код (Javascript): Uncaught Error: 0,CLOSED already registered at line 1 col 44 if(h[a])throw Error(a+" already registered");h[a]=b ^ in function "registerLine" called from line 1 col 137 ...",CLOSED"),socks[e]=void 0}):(socks[e]=void 0,i.emit("err","... ^ in function "c" called from line 1 col 25 g=void 0;var b;c&&(b=c(a))?(g=e,c=b):clearTimeout(d);void 0=... ^ in function "g" called from line 2 col 4 g(f)}b=b.substr(a+1);if(p&&d)return q("");"\n"==b[0]&&(b=b.s... ^ in function called from system Uncaught Error: > already registered at line 1 col 44 if(e[a])throw Error(a+" already registered");e[a]=b ^ in function "register" called from line 1 col 81 ...ister("> "),at.write(n),""}),e):i==="Recv "+n.length+" bytes... ^ in function "c" called from line 1 col 25 g=void 0;var b;c&&(b=c(a))?(g=e,c=b):clearTimeout(d);void 0=... ^ in function "g" called from line 2 col 4 g(f)}b=b.substr(a+1);if(p&&d)return q("");"\n"==b[0]&&(b=b.s... ^ in function called from system Uncaught Error: 0,CLOSED already registered at line 1 col 44 if(h[a])throw Error(a+" already registered");h[a]=b ^ in function "registerLine" called from line 1 col 137 ...",CLOSED"),socks[e]=void 0}):(socks[e]=void 0,i.emit("err","... ^ in function "c" called from line 1 col 25 g=void 0;var b;c&&(b=c(a))?(g=e,c=b):clearTimeout(d);void 0=... ^ in function "g" called from line 2 col 4 g(f)}b=b.substr(a+1);if(p&&d)return q("");"\n"==b[0]&&(b=b.s... ^ in function called from system >
Всё чисто, можно ответ узнать по проводу вай фай ESP-12F он может отключатся в спящий режим? Как это устранить?
Вырубается каждые 10-15 минут, может есть команда чтобы это всё в цикле перезагружала раз в это время?
@007nikss007, у вас Native IDE или приложение к Хрому? Попробуйте открыть ссылки (http и https) http://js.amperka.ru/modules/@amperka/thermometer.min.js https://js.amperka.ru/modules/@amperka/thermometer.min.js http://js.amperka.ru/modules/@amperka/dweetio.min.js https://js.amperka.ru/modules/@amperka/dweetio.min.js http://js.amperka.ru/modules/@amperka/wifi.min.js https://js.amperka.ru/modules/@amperka/wifi.min.js и сравните их с github Ампреки У вас Espruino выполняет код, который больше похож на браузерный JavaScript
попробуйте так и скажите как ведет себя светодиод LED1: Код (Javascript): var SSID = '111'; var PASSWORD = '111'; var NAME = '111'; var temp = require('@amperka/thermometer').connect(A2); var dweet = require('@amperka/dweetio').connect(NAME); var m = false; function run() { setInterval(function() { dweet.send({ temperature: Math.floor(temp.read('C')) }); m = !m; LED1.write(m); }, 1000); } var wifi = require('@amperka/wifi').setup(function(err) { wifi.connect(SSID, PASSWORD, function(err) { print('Click this link', dweet.follow()); run(); }); }); к чему это я? к тому что с интервалами надо быть осторожным, чтоб не наплодить их целую пачку. Поэтому везде, где есть скользкие моменты стараюсь подчищать старые интервалы перед вызовом нового замещающего... Честно не уверен в поведении wifi.connect (я им не особо пользуюсь), но если с кодом выше ваш светодиод начинает мигать чаще 1сек, то скорее всего идет многоразовое выполнение run(), а следовательно и запуск новых интервалов. Даже если я не прав и разрывы-восстановления wifi-соединения не влияют на обратную функцию wifi.connect, то все равно, подчищать интервалы будет хорошим тоном на будущее, например так: Код (Javascript): var SSID = '111'; var PASSWORD = '111'; var NAME = '111'; var temp = require('@amperka/thermometer').connect(A2); var dweet = require('@amperka/dweetio').connect(NAME); var id = 0; function run() { id = setInterval(function() { dweet.send({ temperature: Math.floor(temp.read('C')) }); }, 1000); } var wifi = require('@amperka/wifi').setup(function(err) { wifi.connect(SSID, PASSWORD, function(err) { print('Click this link', dweet.follow()); clearInterval(id); run(); }); }); ну и конечно же держите нас в курсе, желательно подробно
