Часы на Arduino NANO + MAX7219 + FM приемник
Тема в разделе "Глядите, что я сделал", создана пользователем IvanUA, 31 авг 2017.
  1. UT5EQR
    UT5EQR Нуб
    Arduino: 1.8.5 (Windows 10), Плата:"Arduino Nano, ATmega328P"
    D:\ПРОГРАММЫ\arduino-1.8.5\arduino-builder -dump-prefs -logger=machine -hardware D:\ПРОГРАММЫ\arduino-1.8.5\hardware -tools D:\ПРОГРАММЫ\arduino-1.8.5\tools-builder -tools D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -built-in-libraries D:\ПРОГРАММЫ\arduino-1.8.5\libraries -libraries C:\Users\UT5EUD\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020 -warnings=more -build-cache C:\Users\UT5EUD\AppData\Local\Temp\arduino_cache_726351 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -verbose D:\Moi_Czasy8x32\Moi_Czasy8x32.ino
    D:\ПРОГРАММЫ\arduino-1.8.5\arduino-builder -compile -logger=machine -hardware D:\ПРОГРАММЫ\arduino-1.8.5\hardware -tools D:\ПРОГРАММЫ\arduino-1.8.5\tools-builder -tools D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -built-in-libraries D:\ПРОГРАММЫ\arduino-1.8.5\libraries -libraries C:\Users\UT5EUD\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020 -warnings=more -build-cache C:\Users\UT5EUD\AppData\Local\Temp\arduino_cache_726351 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr -verbose D:\Moi_Czasy8x32\Moi_Czasy8x32.ino
    Using board 'nano' from platform in folder: D:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr
    Using core 'arduino' from platform in folder: D:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr
    Detecting libraries used...
    "D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020\sketch\Moi_Czasy8x32.ino.cpp" -o "nul"
    "D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\variants\eightanaloginputs" "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020\sketch\Moi_Czasy8x32.ino.cpp" -o "nul"
    "D:\ПРОГРАММЫ\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\variants\eightanaloginputs" "-ID:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020\sketch\Moi_Czasy8x32.ino.cpp" -o "C:\Users\UT5EUD\AppData\Local\Temp\arduino_build_718020\preproc\ctags_target_for_gcc_minus_e.cpp"
    D:\Moi_Czasy8x32\Moi_Czasy8x32.ino:69:158: fatal error: radio.h: No such file or directory
    #include <radio.h> // Общая библиотека радио без дополнительных возможностей
    compilation terminated.
    Несколько библиотек найдено для "Wire.h"
    Используется: D:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\libraries\Wire
    Не используется: C:\Users\UT5EUD\Documents\Arduino\libraries\Wire
    Используем библиотеку Wire версии 1.0 из папки: D:\ПРОГРАММЫ\arduino-1.8.5\hardware\arduino\avr\libraries\Wire
    exit status 1
    Ошибка компиляции для платы Arduino Nano.
  2. IvanUA
    IvanUA Гуру
    На сколько я понимаю, у вас не то что не хватает библиотек, а как раз их перебор....
    Szirovicza Csaba нравится это.
  3. UT5EQR
    UT5EQR Нуб
    Я C:\Users\UT5EUD\Documents\Arduino\libraries\Wire вроде как удалил. Всё равно что то не то.
  4. UT5EQR
    UT5EQR Нуб
    exit status 1
  5. UT5EQR
    UT5EQR Нуб
    Что обозначает статус выхода 1?
  6. big_alex
    big_alex Гик
    Попробуйте папку "ПРОГРАММЫ" латиницей написать (переименовать)
  7. warman
    warman Гик
    а термометр можно подключить и цифровой, типа DS1631,
  8. UT5EQR
    UT5EQR Нуб
    Не помогло. Попробую переустановить Ардуино
  9. UT5EQR
    UT5EQR Нуб
    Как это побороть?
    Используем библиотеку Wire в папке: D:\arduino-1.8.5\libraries\Wire (legacy)
    exit status 1
  10. Deniskyn
    Deniskyn Гик
    Могу хексы скинуть =)
    UT5EQR нравится это.
  11. big_alex
    big_alex Гик
    похоже нет библиотеки "Radio"
  12. Szirovicza Csaba
    Szirovicza Csaba Нерд
    :):) 60x60mm 8x8 ledmatrix
  13. Szirovicza Csaba
    Hi, I'm sorry to use a google translator from Russian to Hungarian.You're very good at work.IvanUA
  14. UT5EQR
    UT5EQR Нуб
    Если можно на ut5eqr гав mail.ru
    Где её взять? Может кто поделиться?
  15. big_alex
    big_alex Гик
    http://bit.ly/2qCMMxi
  16. Szirovicza Csaba
  17. UT5EQR
    UT5EQR Нуб
    Теперь вот такое выдаёт:
    exit status 1
    stray '\320' in program
  18. UT5EQR
    UT5EQR Нуб
    Кажется победил. скейч залился. Библиотеку Radio-1(которую нашёл в Гугл) переименовал в radio.h.
    Пока идут с Алли DS3231 и RDA5897 попробовал включить. Индикаторы сразу полностью вспыхивают, а потом тухнут. Это нормально или есть проблема?
  19. Deniskyn
    Deniskyn Гик
    RDS бы прикрутить...
  20. IvanUA
    IvanUA Гуру
    Нормально)
