Attiny 2313 плюсы и минусы
Тема в разделе "Микроконтроллеры AVR", создана пользователем DrProg, 9 ноя 2015.
  1. ИгорьК
    Ну.... "C-code driver for SPI master and slave" - так написано в этом апноте во первых строках. Надо искать :)
  2. ИгорьК
    Вот, все для вас. Драйвер реализован для ATmega169, но вы же запросто поправите установочные регистры :) Особенно с учетом предыдущих жертвоприношений от румынов.
    // This file has been prepared for Doxygen automatic documentation generation.
    /*! \file ********************************************************************
    * Atmel Corporation
    * \li File:               spi_via_usi_driver.c
    * \li Compiler:           IAR EWAAVR 3.10c
    * \li Support mail:       avr@atmel.com
    * \li Supported devices:  All devices with Universal Serial Interface (USI)
    *                         capabilities can be used.
    *                         The example is written for ATmega169.
    * \li AppNote:            AVR319 - Using the USI module for SPI communication.
    * \li Description:        Example on how to use the USI module for communicating
    *                         with SPI compatible devices. The functions and variables
    *                         prefixed 'spiX_' can be renamed to be able to use several
    *                         spi drivers (using different interfaces) with similar names.
    *                         Some basic SPI knowledge is assumed.
    *                         $Revision: 1.4 $
    *                         $Date: Monday, September 13, 2004 12:08:54 UTC $
    #include <ioavr.h>
    #include <inavr.h>
    /* USI port and pin definitions.
    #define USI_OUT_REG    PORTE    //!< USI port output register.
    #define USI_IN_REG    PINE    //!< USI port input register.
    #define USI_DIR_REG    DDRE    //!< USI port direction register.
    #define USI_CLOCK_PIN    PE4    //!< USI clock I/O pin.
    #define USI_DATAIN_PIN    PE5    //!< USI data input pin.
    #define USI_DATAOUT_PIN    PE6    //!< USI data output pin.
    /*  Speed configuration:
    *  Bits per second = CPUSPEED / PRESCALER / (COMPAREVALUE+1) / 2.
    *  Maximum = CPUSPEED / 64.
    #define TC0_PRESCALER_VALUE 256    //!< Must be 1, 8, 64, 256 or 1024.
    #define TC0_COMPARE_VALUE   1    //!< Must be 0 to 255. Minimum 31 with prescaler CLK/1.
    /*  Prescaler value converted to bit settings.
    #if TC0_PRESCALER_VALUE == 1
        #define TC0_PS_SETTING (1<<CS00)
    #elif TC0_PRESCALER_VALUE == 8
        #define TC0_PS_SETTING (1<<CS01)
    #elif TC0_PRESCALER_VALUE == 64
        #define TC0_PS_SETTING (1<<CS01)|(1<<CS00)
    #elif TC0_PRESCALER_VALUE == 256
        #define TC0_PS_SETTING (1<<CS02)
    #elif TC0_PRESCALER_VALUE == 1024
        #define TC0_PS_SETTING (1<<CS02)|(1<<CS00)
    #else
        #error Invalid T/C0 prescaler setting.
    #endif
    /*! \brief  Data input register buffer.
    *  Incoming bytes are stored in this byte until the next transfer is complete.
    *  This byte can be used the same way as the SPI data register in the native
    *  SPI module, which means that the byte must be read before the next transfer
    *  completes and overwrites the current value.
    unsigned char storedUSIDR;
    /*! \brief  Driver status bit structure.
    *  This struct contains status flags for the driver.
    *  The flags have the same meaning as the corresponding status flags
    *  for the native SPI module. The flags should not be changed by the user.
    *  The driver takes care of updating the flags when required.
    struct usidriverStatus_t {
        unsigned char masterMode : 1;       //!< True if in master mode.
        unsigned char transferComplete : 1; //!< True when transfer completed.
        unsigned char writeCollision : 1;   //!< True if put attempted during transfer.
    volatile struct usidriverStatus_t spiX_status; //!< The driver status bits.
    /*! \brief  Timer/Counter 0 Compare Match Interrupt handler.
    *  This interrupt handler is only enabled when transferring data
    *  in master mode. It toggles the USI clock pin, i.e. two interrupts
    *  results in one clock period on the clock pin and for the USI counter.
    #pragma vector=TIMER0_COMP_vect
    __interrupt void timer0comp_handler()
        USICR |= (1<<USITC);    // Toggle clock output pin.
    /*! \brief  USI Timer Overflow Interrupt handler.
    *  This handler disables the compare match interrupt if in master mode.
    *  When the USI counter overflows, a byte has been transferred, and we
    *  have to stop the timer tick.
    *  For all modes the USIDR contents are stored and flags are updated.
    #pragma vector=USI_OVF_vect
    __interrupt void usiovf_handler()
        // Master must now disable the compare match interrupt
        // to prevent more USI counter clocks.
        if( spiX_status.masterMode == 1 ) {
            TIMSK0 &= ~(1<<OCIE0A);
        // Update flags and clear USI counter
        USISR = (1<<USIOIF);
        spiX_status.transferComplete = 1;
        // Copy USIDR to buffer to prevent overwrite on next transfer.
        storedUSIDR = USIDR;
    /*! \brief  Initialize USI as SPI master.
    *  This function sets up all pin directions and module configurations.
    *  Use this function initially or when changing from slave to master mode.
    *  Note that the stored USIDR value is cleared.
    *  \param spi_mode  Required SPI mode, must be 0 or 1.
    void spiX_initmaster( char spi_mode )
        // Configure port directions.
        USI_DIR_REG |= (1<<USI_DATAOUT_PIN) | (1<<USI_CLOCK_PIN); // Outputs.
        USI_DIR_REG &= ~(1<<USI_DATAIN_PIN);                      // Inputs.
        USI_OUT_REG |= (1<<USI_DATAIN_PIN);                       // Pull-ups.
        // Configure USI to 3-wire master mode with overflow interrupt.
        USICR = (1<<USIOIE) | (1<<USIWM0) |
                (1<<USICS1) | (spi_mode<<USICS0) |
                (1<<USICLK);
        // Enable 'Clear Timer on Compare match' and init prescaler.
        TCCR0A = (1<<WGM01) | TC0_PS_SETTING;
        // Init Output Compare Register.
        OCR0A = TC0_COMPARE_VALUE;
        // Init driver status register.
        spiX_status.masterMode       = 1;
        spiX_status.transferComplete = 0;
        spiX_status.writeCollision   = 0;
        storedUSIDR = 0;
    /*! \brief  Initialize USI as SPI slave.
    *  Use this function initially or when changing from master to slave mode.
    void spiX_initslave( char spi_mode )
        USI_DIR_REG |= (1<<USI_DATAOUT_PIN);                      // Outputs.
        USI_DIR_REG &= ~(1<<USI_DATAIN_PIN) | (1<<USI_CLOCK_PIN); // Inputs.
        USI_OUT_REG |= (1<<USI_DATAIN_PIN) | (1<<USI_CLOCK_PIN);  // Pull-ups.
        // Configure USI to 3-wire slave mode with overflow interrupt.
                (1<<USICS1) | (spi_mode<<USICS0);
        spiX_status.masterMode       = 0;
        storedUSIDR = 0;
    /*! \brief  Put one byte on bus.
    *  Use this function like you would write to the SPDR register in the native SPI module.
    *  Calling this function in master mode starts a transfer, while in slave mode, a
    *  byte will be prepared for the next transfer initiated by the master device.
    *  If a transfer is in progress, this function will set the write collision flag
    *  and return without altering the data registers.
    *  \returns  0 if a write collision occurred, 1 otherwise.
    char spiX_put( unsigned char val )
        // Check if transmission in progress,
        // i.e. USI counter unequal to zero.
        if( (USISR & 0x0F) != 0 ) {
            // Indicate write collision and return.
            spiX_status.writeCollision = 1;
            return;
        // Reinit flags.
        // Put data in USI data register.
        USIDR = val;
        // Master should now enable compare match interrupts.
            TIFR0 |= (1<<OCF0A);   // Clear compare match flag.
            TIMSK0 |= (1<<OCIE0A); // Enable compare match interrupt.
        if( spiX_status.writeCollision == 0 ) return 1;
        return 0;
    /*! \brief  Get one byte from bus.
    *  This function only returns the previous stored USIDR value.
    *  The transfer complete flag is not checked. Use this function
    *  like you would read from the SPDR register in the native SPI module.
    unsigned char spiX_get()
        return storedUSIDR;
    /*! \brief  Wait for transfer to complete.
    *  This function waits until the transfer complete flag is set.
    *  Use this function like you would wait for the native SPI interrupt flag.
    void spiX_wait()
        do {} while( spiX_status.transferComplete == 0 );
    // end of file
    DrProg нравится это.
  3. ИгорьК
    Ну а если совсем не царское дело в регистрах ковыряться, проверяйте вот эту ссылку: http://srcpro.pl/more.php?pg=1&article=13
    Авось заработает.
    Доставил? :)
  4. DrProg
    DrProg Вечный нерд
    Вот удивительное дело, запись вида:
    #define USI_SCK     PB7
    компилировалась у меня как просто цифровой пин 7 (на каждом МК свой порт и свой бит). Для доступа к конкретно PB7 пришлось использовать битовые операции с портом B. А в этих примерах пишут и не парятся. Или это конкретно применительно к этому МК работает?
    ИгорьК нравится это.
