Help me, plz!
Тема в разделе "Посоветуйте детальки", создана пользователем Aziza, 21 фев 2014.
  1. Aziza
    Aziza Нерд
    выдает такие ошибки
    BritishLamp.ino: In function 'void setup()':
    BritishLamp:227: error: 'i2cInit' was not declared in this scope
    BritishLamp.ino: In function 'byte mpr121Read(uint8_t)':
    BritishLamp:642: error: 'i2cSendStart' was not declared in this scope
    BritishLamp:643: error: 'i2cWaitForComplete' was not declared in this scope
    BritishLamp:645: error: 'i2cSendByte' was not declared in this scope
    BritishLamp:655: error: 'TRUE' was not declared in this scope
    BritishLamp:655: error: 'i2cReceiveByte' was not declared in this scope
    BritishLamp:658: error: 'i2cGetReceivedByte' was not declared in this scope
    BritishLamp:660: error: 'i2cSendStop' was not declared in this scope
    BritishLamp:662: error: 'cbi' was not declared in this scope
    BritishLamp:663: error: 'sbi' was not declared in this scope
    BritishLamp.ino: In function 'void mpr121Write(unsigned char, unsigned char)':
    BritishLamp:670: error: 'i2cSendStart' was not declared in this scope
    BritishLamp:671: error: 'i2cWaitForComplete' was not declared in this scope
    BritishLamp:673: error: 'i2cSendByte' was not declared in this scope
    BritishLamp:682: error: 'i2cSendStop' was not declared in this scope
    Мы подключили тач сенсор вот так:
    GND - GND
    VCC - 5V
    SDA - A4
    SCL - A5
    правильно?
  2. acos
    Врррооооде... Переверните Uno, там внизу, рядом с USB на колодках есть надпись SDA, SCL.
    Библиотеку то подключить Заааабыли)
    Вот там второй зип архив (GroveIICTouchSensor.zip) — это библиотека. В Arduino IDE идёте в «Эскиз»→«Импорт библиотек»→«Добавить библиотеку». Оттуда выбираете этот .zip архив (прямо сразу зип), жмёте Open, и всё заработает
  3. Aziza
    Aziza Нерд
    все сделали, сначала работало все, но потом выдает такую ошибку
    /Users/aziza/Documents/Arduino/libraries/GroveMultiTouch/GroveMultiTouch.cpp: In member function 'void GroveMultiTouch::set_register(int, unsigned char, unsigned char)':
    /Users/aziza/Documents/Arduino/libraries/GroveMultiTouch/GroveMultiTouch.cpp:111: error: 'Wire' was not declared in this scope
    /Users/aziza/Documents/Arduino/libraries/GroveMultiTouch/GroveMultiTouch.cpp: In member function 'void GroveMultiTouch::readTouchInputs()':
    /Users/aziza/Documents/Arduino/libraries/GroveMultiTouch/GroveMultiTouch.cpp:121: error: 'Wire' was not declared in this scope
  4. acos
    но сначала то всё работало? Попробовали перезалить и сломалось?
    Перезагрузитесь на всякий случай
  5. acos
    Ну чего там?
  6. Aziza
    Aziza Нерд
    Спасибо огромное, что так помогли!
    Ждем Вас завтра на презентации.
