MD_Parola
Тема в разделе "Arduino & Shields", создана пользователем keeper, 5 фев 2015.
  1. keeper
    keeper Нерд
    Помогите разобраться не могу понять почему не компилирует тестовый проект
    выдает
    In file included from Parola_Scrolling.ino:15:
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:281: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:530: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:530: error: expected ',' or '...' before '*' token
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:559: error: ISO C++ forbids declaration of 'MD_MAX72XX' with no type
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:559: error: expected ';' before '*' token
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:608: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:608: error: ISO C++ forbids declaration of 'fontType_t' with no type
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:608: error: expected ';' before '*' token
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: In member function 'void MD_PZone::zoneClear()':
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:323: error: '_MX' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:323: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: In member function 'void MD_PZone::setIntensity(uint8_t)':
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:419: error: '_MX' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:419: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: In member function 'void MD_PZone::setZoneFont(int)':
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:530: error: '_fontDef' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:530: error: 'fontDef' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: At global scope:
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1198: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1198: error: expected ',' or '...' before '*' token
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1211: error: 'MD_MAX72XX' has not been declared
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1211: error: expected ',' or '...' before '*' token
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1217: error: 'MD_MAX72XX' does not name a type
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: In member function 'void MD_Parola::setFont(int)':
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1198: error: 'fontDef' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h: In member function 'void MD_Parola::setFont(uint8_t, int)':
    C:\Program Files (x86)\Arduino\libraries\MD_Parola/MD_Parola.h:1211: error: 'fontDef' was not declared in this scope
  2. Megakoteyka
    Megakoteyka Оракул Модератор
    А код где?
  3. keeper
    keeper Нерд
    Вот
    // Program to exercise the MD_Parola library
    // Demonstrates most of the functions of the Parola library.
    // All animations can be run and tested under user control.
    // Speed for the display is controlled by a pot on SPEED_IN analog input.
    // Digital switches used for control of Justification, Effect progression,
    // Pause between animations, LED intensity, and invert mode. UI switches
    // are normally HIGH.
    // Keyswitch library can be found at http://arduinocode.codeplex.com
    #include <MD_Parola.h>
    #include <MD_MAX72xx.h>
    #include <MD_KeySwitch.h>
    // Define the number of devices we have in the chain and the hardware interface
    // NOTE: These pin numbers will probably not work with your hardware and may
    // need to be adapted
    #define    MAX_DEVICES    8
    #define    CLK_PIN        13
    #define    DATA_PIN    11
    #define    CS_PIN        10
    // HARDWARE SPI
    MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
    // SOFTWARE SPI
    //MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
    // Turn on debug statements to the serial output
    #define  DEBUG_ENABLE  1
    #if  DEBUG_ENABLE
    #define    DEBUG(s, x)    { Serial.print(F(s)); Serial.print(x); }
    #define    DEBUGS(x)    Serial.print(F(x))
    #define    DEBUGX(x)    Serial.println(x, HEX)
    #else
    #define    DEBUG(s, x)
    #define DEBUGS(x)
    #define DEBUGX(x)
    #endif
    // User interface pin and switch definitions
    #define    SPEED_IN    A5    // control the speed with an external pot
    #define    PAUSE_SET    4    // toggle pause time
    #define JUSTIFY_SET    6    // change the justification
    #define    INTENSITY_SET    7    // change the intensity of the display
    #define    EFFECT_SET    8    // change the effect
    #define    INVERSE_SET    9    // set/reset the display to inverse
    #define    PAUSE_TIME        1000    // in milliseconds
    #define    SPEED_DEADBAND    5        // in analog units
    // Global variables
    uint8_t    curString = 0;
    char    *pc[] =
      "Parola for",
      "Arduino",
      "LED Matrix",
      "Display"
    #define    NEXT_STRING    ((curString + 1) % ARRAY_SIZE(pc))
    MD_KeySwitch uiJustify(JUSTIFY_SET);
    MD_KeySwitch uiEffect(EFFECT_SET);
    MD_KeySwitch uiPause(PAUSE_SET);
    MD_KeySwitch uiIntensity(INTENSITY_SET);
    MD_KeySwitch uiInverse(INVERSE_SET);
    void doUI(void)
      // set the speed if it has changed
        int16_t    speed = map(analogRead(SPEED_IN), 0, 1023, 0, 100);
        if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
          (speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
          P.setSpeed(speed);
          DEBUG("\nChanged speed to ", P.getSpeed());
      // now process the digital inputs
      if (uiJustify.read())    // TEXT ALIGNMENT
        static uint8_t    curMode = 0;
        textPosition_t    align = P.getTextAlignment();
        textPosition_t    textAlign[] =
          LEFT,
          CENTER,
          RIGHT
        DEBUG("\nChanging alignment to ", curMode);
        P.setTextAlignment(textAlign[curMode]);
        P.displayReset();
        curMode = (curMode + 1) % ARRAY_SIZE(textAlign);
      if (uiEffect.read())    // EFFECT CHANGE
        static uint8_t  curFX = 0;
        textEffect_t effect[] =
          PRINT,
          SLICE,
          WIPE,
          WIPE_CURSOR,
          OPENING,
          OPENING_CURSOR,
          CLOSING,
          CLOSING_CURSOR,
          BLINDS,
          DISSOLVE,
          SCROLL_UP,
          SCROLL_DOWN,
          SCROLL_LEFT,
          SCROLL_RIGHT,
          SCROLL_UP_LEFT,
          SCROLL_UP_RIGHT,
          SCROLL_DOWN_LEFT,
          SCROLL_DOWN_RIGHT,
          SCAN_HORIZ,
          SCAN_VERT,
          GROW_UP,
          GROW_DOWN,
        DEBUG("\nChanging effect to ", curFX);
        P.setTextEffect(effect[curFX], effect[curFX]);
        P.displayReset();
        curFX = (curFX + 1) % ARRAY_SIZE(effect);
      if (uiPause.read())    // PAUSE DELAY
        DEBUGS("\nChanging pause");
        if (P.getPause() <= P.getSpeed())
          P.setPause(PAUSE_TIME);
        else
          P.setPause(0);
      if (uiIntensity.read())    // INTENSITY
        static uint8_t    intensity = 7;
        intensity = ++intensity % 16;
        P.setIntensity(intensity);
        DEBUG("\nChanged intensity to ", intensity);
      if (uiInverse.read())        // INVERSE
        P.setInvert(!P.getInvert());
    void setup(void)
    #if DEBUG_ENABLE
      Serial.begin(57600);
      DEBUGS("[Parola Test]");
    #endif
      // user interface switches
      uiJustify.begin();
      uiEffect.begin();
      uiPause.begin();
      uiIntensity.begin();
      uiInverse.begin();
      // parola object
      P.begin();
      P.displayText(pc[curString], CENTER, P.getSpeed(), PAUSE_TIME, PRINT, PRINT);
      curString = NEXT_STRING;
    void loop(void)
      doUI();
      if (P.displayAnimate())
        P.setTextBuffer(pc[curString]);
        P.displayReset();
  4. Megakoteyka
    Библиотеки все куда надо положены? Компилятор не видит MD_MAX72XX.
  5. X-Dron
    X-Dron Гик
    Ошибка при сборке MD_Parola.h., она не видит декларацию класса MD_MAX72XX.
    А что если последовательность инклюдов поменять.
  6. keeper
    keeper Нерд
    Разобрался
    все моя невнимательность ;)
    #include <MD_KeySwitch.h> не была установлена
  7. вирус не повод поднимать темы 15 года.
    хотя как знать...
    Daniil нравится это.
