Здравствуйте, кто сталкивался с проблемой подключения NodeMcu к домашней wi fi сети? Вот код программы: Код (C++): #define ENA 14 // Enable/speed motors Right GPIO14(D5) #define ENB 12 // Enable/speed motors Left GPIO12(D6) #define IN_1 15 // L298N in1 motors Right GPIO15(D8) #define IN_2 13 // L298N in2 motors Right GPIO13(D7) #define IN_3 2 // L298N in3 motors Left GPIO2(D4) #define IN_4 0 // L298N in4 motors Left GPIO0(D3) #include <ESP8266WiFi.h> #include <WiFiClient.h> #include <ESP8266WebServer.h> String command; //String to store app command state. int speedCar = 800; // 400 - 1023. int speed_Coeff = 3; const char* ssid = "wi fi"; // имя сети const char* pass = "пароль" ESP8266WebServer server(80); void setup() { pinMode(ENA, OUTPUT); pinMode(ENB, OUTPUT); pinMode(IN_1, OUTPUT); pinMode(IN_2, OUTPUT); pinMode(IN_3, OUTPUT); pinMode(IN_4, OUTPUT); Serial.begin(115200); // Connecting WiFi WiFi.mode(WIFI_AP); WiFi.softAP(ssid, pass); IPAddress myIP = WiFi.softAPIP(); Serial.print("AP IP address: "); Serial.println(myIP); // Starting WEB-server server.on ( "/", HTTP_handleRoot ); server.onNotFound ( HTTP_handleRoot ); server.begin(); } void goAhead(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goBack(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goRight(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goLeft(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goAheadRight(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar/speed_Coeff); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goAheadLeft(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar/speed_Coeff); } void goBackRight(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar/speed_Coeff); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goBackLeft(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar/speed_Coeff); } void stopRobot(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void loop() { server.handleClient(); command = server.arg("State"); if (command == "F") goAhead(); else if (command == "B") goBack(); else if (command == "L") goLeft(); else if (command == "R") goRight(); else if (command == "I") goAheadRight(); else if (command == "G") goAheadLeft(); else if (command == "J") goBackRight(); else if (command == "H") goBackLeft(); else if (command == "0") speedCar = 400; else if (command == "1") speedCar = 470; else if (command == "2") speedCar = 540; else if (command == "3") speedCar = 610; else if (command == "4") speedCar = 680; else if (command == "5") speedCar = 750; else if (command == "6") speedCar = 820; else if (command == "7") speedCar = 890; else if (command == "8") speedCar = 960; else if (command == "9") speedCar = 1023; else if (command == "S") stopRobot(); } void HTTP_handleRoot(void) { if( server.hasArg("State") ){ Serial.println(server.arg("State")); } server.send ( 200, "text/html", "" ); delay(1); } У NodeMcu лампочка с соответствующим пином светится постоянно, как будто бы ищет соединения, когда подключаюсь к wi fi, приложение для Android написано. "http://ip-адрес NodeMCU/?State=<letter>" вот такую ошибку выдаёт программа для Android.
не могу сказать точно. в чем ошибка - но у вас в коде пароль к ВайФаю нигде не используется, из чего видно. что подключаетесь вы неправильно.
Вот и я тоже так подумал, что куда записывается ssid в функцию туда и нужно я так понял и команду pass ввести?
IPAddress myIP = WiFi.softAPIP(); Serial.print("AP IP address: "); Serial.println(myIP); Вот эти строчки не пойму что такое "AP IP address" ?
Я никогда не работал с модулем таким образом, поэтому вам надо разбираться с примерами этой библиотеки. Мне просто бросается в глаза, что этот кусок кода: Код (C++): WiFi.mode(WIFI_AP); WiFi.softAP(ssid, pass); IPAddress myIP = WiFi.softAPIP(); Serial.print("AP IP address: "); Serial.println(myIP); // Starting WEB-server server.on ( "/", HTTP_handleRoot ); server.onNotFound ( HTTP_handleRoot ); server.begin(); создает сервер на собственной точке доступа, а не заводит модуль в сеть.
Увидел немного неверные функции, исправлю. Ещё один момент не пойму, для чего создавать http-сервер для NodeMCU, если я буду управлять программой на Android?
Программа на андроиде (судя по всему) отправляет запросы на модуль. Чтобы принимать эти запросы, модуль и поднимает собственный, малюсенький веб-сервер. Когда вы заходите на эту страницу, вы отправляете на нее запрос. В ответ получаете то, что считает нужным вам передать страница. В случае же с этим устройством, страница будет что-то с ним делать.
Код (C++): #define ENA 14 // Enable/speed motors Right GPIO14(D5) #define ENB 12 // Enable/speed motors Left GPIO12(D6) #define IN_1 15 // L298N in1 motors Right GPIO15(D8) #define IN_2 13 // L298N in2 motors Right GPIO13(D7) #define IN_3 2 // L298N in3 motors Left GPIO2(D4) #define IN_4 0 // L298N in4 motors Left GPIO0(D3) #include <ESP8266WiFi.h> #include <WiFiClient.h> #include <ESP8266WebServer.h> String command; //String to store app command state. int speedCar = 800; // 400 - 1023. int speed_Coeff = 3; const char *ssid = "Smart Car"; const char *password = "12345678"; ESP8266WebServer server(80); void setup() { pinMode(ENA, OUTPUT); pinMode(ENB, OUTPUT); pinMode(IN_1, OUTPUT); pinMode(IN_2, OUTPUT); pinMode(IN_3, OUTPUT); pinMode(IN_4, OUTPUT); Serial.begin(115200); // Connecting WiFi Serial.print("Connecting to "); Serial.println(ssid); WiFi.mode(WIFI_STA); // Задаем режим работы WIFI_STA (клиент) WiFi.begin(ssid, password); // Подключаемся while (WiFi.status() != WL_CONNECTED) // Ждем пока статус не станет WL_CONNECTED { delay(500); } Serial.println("WiFi connected"); Serial.print("IP address: "); Serial.println(WiFi.localIP()); // показывает наше IP // Starting WEB-server server.on ( "/", HTTP_handleRoot ); server.onNotFound ( HTTP_handleRoot ); server.begin(); } void goAhead(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goBack(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goRight(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goLeft(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goAheadRight(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar/speed_Coeff); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar); } void goAheadLeft(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, HIGH); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, HIGH); analogWrite(ENB, speedCar/speed_Coeff); } void goBackRight(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar/speed_Coeff); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void goBackLeft(){ digitalWrite(IN_1, HIGH); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, HIGH); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar/speed_Coeff); } void stopRobot(){ digitalWrite(IN_1, LOW); digitalWrite(IN_2, LOW); analogWrite(ENA, speedCar); digitalWrite(IN_3, LOW); digitalWrite(IN_4, LOW); analogWrite(ENB, speedCar); } void loop() { server.handleClient(); command = server.arg("State"); if (command == "F") goAhead(); else if (command == "B") goBack(); else if (command == "L") goLeft(); else if (command == "R") goRight(); else if (command == "I") goAheadRight(); else if (command == "G") goAheadLeft(); else if (command == "J") goBackRight(); else if (command == "H") goBackLeft(); else if (command == "0") speedCar = 400; else if (command == "1") speedCar = 470; else if (command == "2") speedCar = 540; else if (command == "3") speedCar = 610; else if (command == "4") speedCar = 680; else if (command == "5") speedCar = 750; else if (command == "6") speedCar = 820; else if (command == "7") speedCar = 890; else if (command == "8") speedCar = 960; else if (command == "9") speedCar = 1023; else if (command == "S") stopRobot(); } void HTTP_handleRoot(void) { if( server.hasArg("State") ){ Serial.println(server.arg("State")); } server.send ( 200, "text/html", "" ); delay(1); } Немного видоизменил строки, взял из стандартной библиотеки код и скопировал, все равно не подключается NodeMCU, я вот думаю может самому программу написать на Android и уже вписывать там свои значения? Может знает кто программы в которых можно таблицами прогать?
