NOKIA 6100 LCD
Тема в разделе "Arduino & Shields", создана пользователем Дмитрий_, 20 июл 2012.
  1. Дмитрий_
    Дмитрий_ Нерд
    Добрый день!
    Подскажите начинающему в чем тут может быть проблемма???
    Изображение выводится наоборот!
      ChronoLCD Color - An example sketch for the Color LCD Shield Library
      by: Jim Lindblom
      SparkFun Electronics
      date: 6/23/11
      license: CC-BY SA 3.0 - Creative commons share-alike 3.0
      use this code however you'd like, just keep this license and
      attribute. Let me know if you make hugely, awesome, great changes.
      This sketch draws an analog and digital clock on the Color LCD
      Shield. You can also use the on-board buttons to set the hours
      and minutes.
      Use the defines at the top of the code to set the initial time.
      You can also adjust the size and color of the clock.
      To set the time, first hit S3. Then use S1 and S2 to adjust the
      hours and minutes respsectively. Hit S3 to start the clock
      back up.
      This example code should give you a good idea of how to use
      the setCircle, setLine, and setStr functions of the Color LCD
      Shield Library.
    #include <ColorLCDShield.h>
    // Enter the time below in 12-hr format
    #define HOURS 10
    #define MINUTES 21
    #define SECONDS 00
    #define AMPM 0  // enter 0 for AM, 1 for PM
    #define CLOCK_RADIUS 50  // radius of clock face
    #define CLOCK_CENTER 55  // If you adjust the radius, you'll probably want to adjust this
    #define H_LENGTH  30  // length of hour hand
    #define M_LENGTH  40  // length of minute hand
    #define S_LENGTH  48  // length of second hand
    #define BACKGROUND  BLACK  // room for growth, adjust the background color according to daylight
    #define C_COLOR  RED  // This is the color of the clock face, and digital clock
    #define H_COLOR  BLUE  // hour hand color
    #define M_COLOR  GREEN  // minute hand color
    #define S_COLOR  YELLOW  // second hand color
    LCDShield lcd;
    int hours, minutes, seconds, ampm;
    int buttonPins[3] = {3, 4, 5};
      /* Set up the button pins as inputs, set pull-up resistor */
      for (int i=0; i<3; i++)
        pinMode(buttonPins[i], INPUT);
        digitalWrite(buttonPins[i], HIGH);
      hours = HOURS;
      minutes = MINUTES;
      seconds = SECONDS;
      ampm = AMPM;
      /* Initialize the LCD, set the contrast, clear the screen */
      lcd.init(PHILLIPS);
      lcd.contrast(40);
      lcd.clear(WHITE);
      drawClock();  // Draw the clock face, this includes 12, 3, 6, 9
      displayAnalogTime(hours, minutes, seconds);  // Draw the clock hands
      displayDigitalTime(hours, minutes, seconds, ampm);  // Draw the digital clock text
      /* We'll run around checking for button presses,
        until it's been a second */
      while(millis() % 1000)
        if (!digitalRead(buttonPins[2]))
          setTime();  // If S3 was pressed, go set the time
      /* We'll get here if it's been a second. We need to increase
      seconds by 1 and then go from there */
      seconds++;
      if (seconds >= 60)
        seconds = 0;  // If seconds is 60, set it back to 0
        minutes++;    // and increase minutes by 1
        if (minutes >= 60)
          minutes = 0;  // If minutes is 60, set it back to 0
          hours++;      // and increase hours by 1
          if (hours == 12)
            ampm ^= 1;  // If it's 12 o'clock, flip ampm
          if (hours >= 13)
            hours = 1;  // If hours is 13, set it to 1. 12-hr clock.
      /* Once each second, we'll redraw the clock with new values */
      drawClock();
      setTime uses on-shield switches S1, S2, and S3 to set the time
      pressing S3 will exit the function. S1 increases hours, S2
      increases seconds.
    void setTime()
      /* Reset the clock to midnight */
      seconds = 0;
      minutes = 0;
      hours = 12;
      ampm = 0;
      /* Draw the clock, so we can see the new time */
      drawClock();
      while (!digitalRead(buttonPins[2]))
        ;  // wait till they let go of S1
      /* We'll run around this loop until S3 is pressed again */
      while(digitalRead(buttonPins[2]))
        /* If S1 is pressed, we'll update the hours */
        if (!digitalRead(buttonPins[0]))
          hours++;  // Increase hours by 1
          if (hours == 12)
            ampm ^= 1;  // Flip am/pm if it's 12 o'clock
          if (hours >= 13)
            hours = 1;  // Set hours to 1 if it's 13. 12-hour clock.
          /* and update the clock, so we can see it */
          drawClock();
        if (!digitalRead(buttonPins[1]))
          minutes++;  // Increase minutes by 1
          if (minutes >= 60)
          drawClock();
      /* Once S3 is pressed, we'll exit, but not until it's released */
      while(!digitalRead(buttonPins[2]))
      displayDigitalTime() takes in values for hours, minutes, seconds
      and am/pm. It'll print the time, in digital format, on the
      bottom of the screen.
    void displayDigitalTime(int h, int m, int s, int ap)
      char timeChar[13] = {'x', 'x', 0x0A, 'x', 'x', 0x0A, 'x', 'x', ' ', ' '};
      /* Gotta turn the values into individual integers */
      timeChar[0] = h/10;
      timeChar[1] = h - (timeChar[0] * 10);
      timeChar[3] = m/10;
      timeChar[4] = m - (timeChar[3] * 10);
      timeChar[6] = s/10;
      timeChar[7] = s - (timeChar[6] * 10);
      /* once we have each integer separated, we need to turn them
        into displayable characters. Adding 0x30 does this (check an
        ASCII table. We set the colons to 0x0A initially, this will
        turn them into the proper 0x3A.*/
      for (int i=0; i<8; i++)
        timeChar[i] += 0x30;
      timeChar[8] = ' ';  // add a space between the time and AM/PM
      /* Add AM or PM to the end of the timeChar string */
      if (!ap)
        timeChar[9] = 'A';
        timeChar[10] = 'M';
      else
        timeChar[9] = 'P';
        timeChar[10] = 'M';
      /* add some blank spaces after the time, otherwise it'll display
        unwanted characters */
      timeChar[11] = ' ';
      timeChar[12] = ' ';
      /* Print the time on the clock */
      lcd.setStr(timeChar, CLOCK_CENTER + CLOCK_RADIUS + 4, 22, C_COLOR, WHITE);
      drawClock() simply draws the outer circle of the clock, and '12',
      '3', '6', and '9'. Room for growth here, if you want to customize
      your clock. Maybe add dashe marks, or even all 12 digits.
    void drawClock()
      /* Draw the circle */
      lcd.setCircle(CLOCK_CENTER, 66, CLOCK_RADIUS, C_COLOR);
      /* Print 12, 3, 6, 9, a lot of arbitrary values are used here
        for the coordinates. Just used trial and error to get them
        into a nice position. */
      lcd.setStr("12", CLOCK_CENTER - CLOCK_RADIUS, 66-9, C_COLOR, WHITE);
      lcd.setStr("3", CLOCK_CENTER - 9, 66 + CLOCK_RADIUS - 12, C_COLOR, WHITE);
      lcd.setStr("6", CLOCK_CENTER + CLOCK_RADIUS - 18, 66-4, C_COLOR, WHITE);
      lcd.setStr("9", CLOCK_CENTER - 9, 66 - CLOCK_RADIUS + 4, C_COLOR, WHITE);
      displayAnalogTime() draws the three clock hands in their proper
      position. Room for growth here, I'd like to make the clock hands
      arrow shaped, or at least thicker and more visible.
    void displayAnalogTime(int h, int m, int s)
      double midHours;  // this will be used to slightly adjust the hour hand
      static int hx, hy, mx, my, sx, sy;
      /* Adjust time to shift display 90 degrees ccw
        this will turn the clock the same direction as text */
      h -= 3;
      m -= 15;
      s -= 15;
      if (h <= 0)
        h += 12;
      if (m < 0)
        m += 60;
      if (s < 0)
        s += 60;
      /* Delete old lines: */
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+sx, 66+sy, WHITE);  // delete second hand
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+mx, 66+my, WHITE);  // delete minute hand
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+hx, 66+hy, WHITE);  // delete hour hand
      /* Calculate and draw new lines: */
      s = map(s, 0, 60, 0, 360);  // map the 0-60, to "360 degrees"
      sx = S_LENGTH * sin(3.14 * ((double) s)/180);  // woo trig!
      sy = S_LENGTH * cos(3.14 * ((double) s)/180);  // woo trig!
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+sx, 66+sy, S_COLOR);  // print second hand
      m = map(m, 0, 60, 0, 360);  // map the 0-60, to "360 degrees"
      mx = M_LENGTH * sin(3.14 * ((double) m)/180);  // woo trig!
      my = M_LENGTH * cos(3.14 * ((double) m)/180);  // woo trig!
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+mx, 66+my, M_COLOR);  // print minute hand
      midHours = minutes/12;  // midHours is used to set the hours hand to middling levels between whole hours
      h *= 5;  // Get hours and midhours to the same scale
      h += midHours;  // add hours and midhours
      h = map(h, 0, 60, 0, 360);  // map the 0-60, to "360 degrees"
      hx = H_LENGTH * sin(3.14 * ((double) h)/180);  // woo trig!
      hy = H_LENGTH * cos(3.14 * ((double) h)/180);  // woo trig!
      lcd.setLine(CLOCK_CENTER, 66, CLOCK_CENTER+hx, 66+hy, H_COLOR);  // print hour hand
  2. Дмитрий_
    Дмитрий_ Нерд
    Вот нашел ответ на свой вопрос
    http://www.sparkfun.com/products/9363
    • [​IMG]
      TCWORLD | 10 месяцев назад * 1
      - Библиотека обновление: 22 октября 2011 -
      Если кому-то интересно, я создал библиотеку Arduino для этого. (Я не заметил там был пример библиотеки, так что я сделал свой собственный).
      GLCD библиотеке GitHub
      Вам просто нужно скопировать GLCD папки внутри архива в папку "библиотек в каталоге, где установлен Arduino.
      Есть также два примера эскизов, которые объясняют, как пользоваться библиотекой. В программное обеспечение Arduino перейдите в меню Файл -> Примеры -> GLCD -> BasicFunctions (или TestPattern)
      Библиотека работает с Филлипсом и Epson контроллеров. Он пока не может обнаружить, какой вы есть, так что вы должны указать, что в рамках Init () команды. См. например, эскиз или для получения дополнительной информации.
      На данный момент он может рисовать линии, коробки, и круги. Он может построить отдельные пиксели, вы можете контролировать цвет (4096 цветов), а также распечатывать текстовые строки. Существует также встроенный тестовый шаблон.
      Существует также функция установить контрастность экрана, если значение по умолчанию не работает должным образом.
      Данные для печати символов теперь хранится в памяти программы, которая освобождает 480bytes ОЗУ.
      Для дисплеев Филлипс, инициализации () вызов был изменен. В настоящее время:
      graphic.Init (сдвиг-, сдвиг-, invertColour, 1, mirrorX);
      - (Сдвиг-, сдвиг-) устанавливает положение о происхождении на экране в случае, если некоторые пиксели отсекаются.
      -InvertColour reveses значения цвета, когда истинный (то есть, если черный выглядит как белый, установите 1.
      MirrorX-х меняет направление.
      Это изменение связано с некоторыми Филлипс дисплеях отображается зеркально.
      Я также добавил функцию быстрого digitalWrite в библиотеку, которая, если включен увеличивает частоту обновления экрана в 10 раз.
      Для того, чтобы использовать это, вы должны определить, какой порт каждый контактный LCD находится на в gLCD.h файл. Если вы используете эту sheild неизмененной, то библиотека не нужно редактирование, как порт по умолчанию определяет поддержку этой sheild.
      Для использования функции быстрее с этим sheild, это должны быть определены:
      GLCD графики (8,9,13,11,1);
      Это как это было раньше, за исключением существует пятый переменной, которая информирует библиотеки использовать быстрые записи.
      Я буду обновлять библиотеки медленно, на данный момент это версия 1.3
    Desert Ops нравится это.
  3. nailxx
    Ничего себе вы задвинули :eek:
    Спасибо за ликбез!
