Помогите новичку!!!!!
Тема в разделе "Arduino & Shields", создана пользователем maksfranklin, 22 апр 2019.
  1. maksfranklin
    maksfranklin Нуб
    Есть esp8266-01, реле, емкосная сенсорная кнопка, и вот такой скейч
    // Relay control using the ESP8266 WiFi chip
    // Import required libraries
    #include <ESP8266WiFi.h>
    // WiFi parameters
    const char* ssid = "****";
    const char* password = "****";
    //Room Name
    const String RoomName = "Room 1";
    //Response from Client
    String request = "";
    // The port to listen for incoming TCP connections
    #define LISTEN_PORT           80
    // set pin numbers:
    const int buttonPin = 0;    // the number of the pushbutton pin
    const int relayPin = 2;      // the number of the LED pin
    int relayState = LOW;         // the current state of the output pin
    int buttonState;             // the current reading from the input pin
    int lastButtonState = LOW;   // the previous reading from the input pin
    long lastDebounceTime = 0;  // the last time the output pin was toggled
    long debounceDelay = 50;    // the debounce time; increase if the output     flickers
    // Create an instance of the server
    WiFiServer server(LISTEN_PORT);
    WiFiClient client;
    void setup(void)
          // Start Serial
          Serial.begin(115200);
          delay(10);
          Serial.println();
          Serial.println();
          Serial.println();
          Serial.println();
          pinMode(buttonPin, INPUT);
          pinMode(relayPin, OUTPUT);
          // set initial LED state
          digitalWrite(relayPin, relayState);
          // Connect to WiFi
          WiFi.begin(ssid, password);
          while (WiFi.status() != WL_CONNECTED) {
            delay(500);
            Serial.print(".");
          Serial.println("");
          Serial.println("WiFi connected");
          // Start the server
          server.begin();
          Serial.println("Server started");
          Serial.println("You can connect to this Switch at this URL:");
          Serial.print("http://");
          // Print the IP address
          Serial.print(WiFi.localIP());
          Serial.println("/");
         // Handle REST calls
         WiFiClient client = server.available();
         if (client) {
            Serial.println("User connected.");
            while(!client.available()){
                 delay(1);
            Serial.print("Request Received:");
           String request = client.readStringUntil('\r\n');
            Serial.println(request);
            client.flush();
           //process the request
           if (request.indexOf("/LED=ON") != -1) {
            digitalWrite(relayPin,LOW);
           if (request.indexOf("/LED=OFF") != -1) {
            digitalWrite(relayPin,HIGH);
          // read the state of the switch into a local variable:
          int reading = digitalRead(buttonPin);
          // If the switch changed, due to noise or pressing:
          if (reading != lastButtonState) {
            // reset the debouncing timer
            lastDebounceTime = millis();
          if ((millis() - lastDebounceTime) > debounceDelay) {
            // whatever the reading is at, it's been there for longer
            // than the debounce delay, so take it as the actual current state:
            // if the button state has changed:
            if (reading != buttonState) {
              buttonState = reading;
              // only toggle the LED if the new button state is HIGH
              if (buttonState == HIGH) {
                relayState = !relayState;
          // save the reading.  Next time through the loop,
          // it'll be the lastButtonState:
          lastButtonState = reading;
         if (client) {
             client.println("HTTP/1.1 200 OK");
      client.println("Content-Type: text/html");
      client.println("");
      client.println("<!DOCTYPE HTML>");
      client.println("<html>");
      client.println("<head><title>ESP8266 RELAY Control</title></head>");
      client.print("<h1>Relay is now: </h1>");
      if(relayState == HIGH)
        client.print("<div style=\"text-align: center;width: 198px;color:white ;padding: 10px 30px;background-color: #ff9900;margin: 0 auto;\">OFF</div>");
      else
        client.print("<div style=\"text-align: center;width: 198px;color:white ;padding: 10px 30px;background-color: #43a209;margin: 0 auto;\">ON</div>");
      client.println("<br><br>");
      client.println("<div>");
      client.println("<div style=\"text-align: center;font-size: 50px;width: 298px;color:white ;padding: 10px 30px;background-color: #ff9900;margin: 0 auto;\">Turn <a href=\"/LED=OFF\">OFF</a> RELAY<br></div>");
      client.println("<div style=\"text-align: center;font-size: 50px;width: 298px;color:white ;padding: 10px 30px;background-color: #43a209;margin: 0 auto;\">Turn <a href=\"/LED=ON\">ON</a> RELAY<br></div>");
      client.println("</div>");
        client.println("</html>");
      delay(1);
      Serial.println("Client disonnected");
      Serial.println("");
    моя проблема в том что я хочу выключать и включать реле из веб формы, и с кнопки, но что то не то я пишу в коде,
  2. Asper Daffy
    Asper Daffy Иксперд
    Это действительно, проблема.
    Andrey12 и Алексей.А нравится это.
  3. maksfranklin
    maksfranklin Нуб
    хорошо что не сказал -"она действительно твоя!")
  4. Voha888
    Voha888 Нуб
    А если закинуть странички в SPIFFS ? Там же нельзя использовать Си-код. Нашёл пример для ESP32, там для переменных используют в коде страничек что то типа %BUTTON, и это потом вызывает одноименные переменные в Си-коде, насколько я понял. Если не сложно, пожалуйста, ткните носом где рассказано как на ESP8266 привязать переменные, или строки (в случае с get/post), к событиям на веб страничках находящихся в SPIFFS ? Надеюсь Вы поняли о чем я спрашиваю?
  5. Asper Daffy
    Asper Daffy Иксперд
    Voha888 нравится это.
  6. Voha888
    Voha888 Нуб
    Спасибо. Попробую
  7. LCD 16x2
    LCD 16x2 Нерд
