Ардуино.
Тема в разделе "Arduino & Shields", создана пользователем Дмитрий24, 22 июн 2017.
  1. Доброго времени суток. Друзья, помогите устранить ошибку в коде?
    // Example testing sketch for various DHT humidity/temperature sensors
    // Written by ladyada, public domain
    #include "DHT.h"
    #define DHTPIN 2 // what pin we're connected to
    // Uncomment whatever type you're using!
    //#define DHTTYPE DHT11 // DHT 11
    #define DHTTYPE DHT22 // DHT 22 (AM2302)
    //#define DHTTYPE DHT21 // DHT 21 (AM2301)
    // Connect pin 1 (on the left) of the sensor to +5V
    // Connect pin 2 of the sensor to whatever your DHTPIN is
    // Connect pin 4 (on the right) of the sensor to GROUND
    // Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
    DHT dht(DHTPIN, DHTTYPE);
    int rele =3;
    int x = 0;
    int y = 0;
    Serial.println("DHTxx test!");
    dht.begin();
    pinMode (rele, OUTPUT);
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    // check if returns are valid, if they are NaN (not a number) then something went wrong!
    if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    } else {
    x=x+1;
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
    Serial.print(x);
    it(h < 70 and x > 600)digitalWrite(rele, HIGH); Ошибка
    else digitalWrite(rele, LOW);
    it(h > 70 and x > 600) x=420;
    Arduino: 1.8.3 (Windows 7), Плата:"Arduino/Genuino Uno"
    C:\Users\РЈРЎРЎ\Documents\Arduino\DHTtester\DHTtester.ino: In function 'void loop()':
    DHTtester:50: error: 'it' was not declared in this scope
    DHTtester:51: error: 'else' without a previous 'if'
    Несколько библиотек найдено для "DHT.h"
    Используется: C:\Program Files\Arduino\Arduino1\Arduino\libraries\DHT
    Не используется: C:\Users\УСС\Documents\Arduino\libraries\DHT_sensor_library
    exit status 1
    Этот отчёт будет иметь больше информации с
    включенной опцией Файл -> Настройки ->
    "Показать подробный вывод во время компиляции"
    С уважением, Дмитрий.
  2. mcureenab
    mcureenab Гуру
    Ну написано же все. Протри глаза...
    наверное не it а if.
  3. Tomasina
    А так разве можно?
  4. mcureenab
    mcureenab Гуру
    некоторые рисуют
    #define and &&
    заменить на
    digitalWrite(rele, h < 70 && x > 600 ? HIGH : LOW);
    Andrey12 нравится это.
