Локальный mqtt broker на esp8266 с дисплеем
Тема в разделе "Глядите, что я сделал", создана пользователем sanik, 26 окт 2023.
  1. sanik
    sanik Гик
    Может кому пригодится
       uMQTTBroker demo for Arduino (C++-style)
      https://github.com/martin-ger/uMQTTBroker
       The program defines a custom broker class with callbacks,
       starts it, subscribes locally to anything, and publishs a topic every second.
       Try to connect from a remote client and publish something - the console will show this as well.
    #include "SSD1306.h"
    #include <ESP8266WiFi.h>
    #include "uMQTTBroker.h"
    SSD1306 display(0x3c, D2, D1);
       Your WiFi config here
    int counter = 0;
    int printMin;
    int printHour;
    int printSek;
    int printDauy;
    char ssid[] = "Name WiFi";     // your network SSID (name)
    char pass[] = "*******"; // your network password
    bool WiFiAP = false;      // Do yo want the ESP as AP?
    unsigned long previousMillis = 0;
       Custom broker class with overwritten callback functions
    class myMQTTBroker: public uMQTTBroker {
      public:
        virtual bool onConnect(IPAddress addr, uint16_t client_count) {
          Serial.println(addr.toString() + " connected");
          return true;
        virtual void onDisconnect(IPAddress addr, String client_id) {
          Serial.println(addr.toString() + " (" + client_id + ") disconnected");
        virtual bool onAuth(String username, String password, String client_id) {
          Serial.println("Username/Password/ClientId: " + username + "/" + password + "/" + client_id);
          return true;
        virtual void onData(String topic, const char *data, uint32_t length) {
          char data_str[length + 1];
          os_memcpy(data_str, data, length);
          data_str[length] = '\0';
          Serial.println("received topic '" + topic + "' with data '" + (String)data_str + "'");
          //printClients();
        // Sample for the usage of the client info methods
        virtual void printClients() {
          for (int i = 0; i < getClientCount(); i++) {
            IPAddress addr;
            String client_id;
            getClientAddr(i, addr);
            getClientId(i, client_id);
            Serial.println("Client " + client_id + " on addr: " + addr.toString());
    myMQTTBroker myBroker;
       WiFi init stuff
    void startWiFiClient() {
      Serial.println("Connecting to " + (String)ssid);
      WiFi.mode(WIFI_STA);
      WiFi.begin(ssid, pass);
      while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println("");
      Serial.println("WiFi connected");
      Serial.println("IP address: " + WiFi.localIP().toString());
      display.clear();
      display.setTextAlignment(TEXT_ALIGN_CENTER);
      display.setFont(ArialMT_Plain_16);
      display.drawString(64, 0, "WiFi connected");
      display.drawString(64, 16, "IP:" + WiFi.localIP().toString());
      display.display();
    void startWiFiAP() {
      WiFi.mode(WIFI_AP);
      WiFi.softAP(ssid, pass);
      Serial.println("AP started");
      Serial.println("IP address: " + WiFi.softAPIP().toString());
      Serial.begin(115200);
      Serial.println();
      Serial.println();
      display.init();
      display.flipScreenVertically();
      // Start WiFi
      if (WiFiAP)
        startWiFiAP();
      else
        startWiFiClient();
      // Start the broker
      Serial.println("Starting MQTT broker");
      myBroker.init();
         Subscribe to anything
      myBroker.subscribe("#");
      // wait a second
      unsigned long currentMillis = millis(); //read current time
      if (currentMillis - previousMillis >= 1000) { //if current time - last time > 1 sec
        previousMillis = currentMillis;
        counter++;
        printSek = counter % 60;
        printMin = (counter / 60) % 60;
        printHour = (counter / 3600) % 24;
        printDauy = (counter / 86400);
           Publish the counter value as String
        myBroker.publish("broker/counter", (String)counter);
        display.clear();
        display.drawString(64, 42, (String)printDauy + "d " + (String)printHour + ":" + (String)printMin + ":" + (String)printSek);
        display.display();
  2. DetSimen
    DetSimen Гуру
    Если ты переопределяешь виртуальную функцию базового класса, никада так не пиши
    всегда пиши так
    void onDisconnect(IPAddress addr, String client_id) override {
    это избавит тебя впаслецтвии от множества труднообнаруживаемых ошибок.
  3. Airbus
    Это оно?
  4. parovoZZ
  5. sanik
    sanik Гик
    Да оно.
    OldKryptos нравится это.
  6. sanik
    sanik Гик
    Спасибо попробую.
  7. OldKryptos
    OldKryptos Гик
    Да, с видео наглядней. Понятно, для чего это нужно.
