Не работает скетч примера на Arduino Leonardo ETH
Тема в разделе "Arduino & Shields", создана пользователем YeS, 13 апр 2016.
  1. YeS
    YeS Гик
    Добрый день всем!
    Пробую заставить Arduino Leonardo ETH поработать веб-сервером. Беру пример из библиотеки Ethernet2:
      Web Server
    A simple web server that shows the value of the analog input pins.
    using an Arduino Wiznet Ethernet shield.
    Circuit:
    * Ethernet shield attached to pins 10, 11, 12, 13
    * Analog inputs attached to pins A0 through A5 (optional)
    created 18 Dec 2009
    by David A. Mellis
    modified 9 Apr 2012
    by Tom Igoe
    #include <SPI.h>
    #include <Ethernet2.h>
    // Enter a MAC address and IP address for your controller below.
    // The IP address will be dependent on your local network:
    byte mac[] = {
      0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    IPAddress ip(192, 168, 1, 177);
    // Initialize the Ethernet server library
    // with the IP address and port you want to use
    // (port 80 is default for HTTP):
    EthernetServer server(80);
      // Open serial communications and wait for port to open:
      while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      // start the Ethernet connection and the server:
      Ethernet.begin(mac, ip);
      server.begin();
      Serial.print("server is at ");
      Serial.println(Ethernet.localIP());
      // listen for incoming clients
      EthernetClient client = server.available();
      if (client) {
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
              // send a standard http response header
              client.println("HTTP/1.1 200 OK");
              client.println("Content-Type: text/html");
              client.println("Connection: close");  // the connection will be closed after completion of the response
              client.println("Refresh: 5");  // refresh the page automatically every 5 sec
              client.println();
              client.println("<!DOCTYPE HTML>");
              client.println("<html>");
              // output the value of each analog input pin
              for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
                int sensorReading = analogRead(analogChannel);
                client.print("analog input ");
                client.print(analogChannel);
                client.print(" is ");
                client.print(sensorReading);
                client.println("<br />");
              client.println("</html>");
              break;
            if (c == '\n') {
              // you're starting a new line
            else if (c != '\r') {
              // you've gotten a character on the current line
              currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disconnected");
    меняю ip на 192.168.25.199 и мак адрес на свой. Вгружаю, отключаю usb кабель, подключаю к сети, включаю источник питания - не работает. Пинга нет. В чём может быть проблема?
  2. YeS
    YeS Гик
    Разобрался сам. Не поднимался сериал (usb то отключён), а без него setup дальше не отрабатывал:
      while (!Serial) {
