Ошибка компиляции
Тема в разделе "Arduino & Shields", создана пользователем mes01, 27 июн 2015.
  1. mes01
    mes01 Нуб
    Какие только библиотеки уже и не пробовал, постоянно хоть какая-то но ошибка вылезет, я в тупике :(
    ниже привожу код ошибки + скетч
    #include <SPI.h>
    #include <Ethernet.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 2
    OneWire oneWire(ONE_WIRE_BUS);
    byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x30, 0x31 };
    EthernetClient client;
    char server[] = "arduino.bc22.ru"; // имя вашего сервера  www.arduino.ru
    int buff=0;
    const int led=13;
    const int led1=13;
      Ethernet.begin(mac);
      pinMode( led, OUTPUT);
      digitalWrite(led, LOW);
        if (client.connect(server, 80))
          client.print( "GET /add_data.php?");
          client.print("temperature=22");
          client.print("&");
          client.print("&");
          client.print("temperature1=33");
          client.println( " HTTP/1.1");
          client.print( "Host: " );
          client.println(server);
          client.println( "Connection: close" );
          client.println();
          client.println();
          delay(200);
            while (client.available())
            char c = client.read();
              if ( c=='1')
              buff=1;
              if ( c=='0')
              buff=0;
            client.stop();
            client.flush();
            delay(100);
        else
        client.stop();
        delay(1000);
        client.connect(server, 80);
      if ( buff==1)
            digitalWrite (led1, HIGH);
            else
              digitalWrite(led1, LOW);
      delay(500);
    Arduino: 1.6.5 (Mac OS X), Плата"Arduino Uno"
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp: In member function 'void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)':
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:65:39: error: no matching function for call to 'W5100Class::setIPAddress(IPAddress::<anonymous union>&)'
      W5100.setIPAddress(local_ip._address);
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:65:39: note: candidate is:
    In file included from /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:1:0:
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:392:6: note: void W5100Class::setIPAddress(uint8_t*)
    void W5100Class::setIPAddress(uint8_t *_addr) {
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:392:6: note:  no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:66:38: error: no matching function for call to 'W5100Class::setGatewayIp(IPAddress::<anonymous union>&)'
      W5100.setGatewayIp(gateway._address);
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:66:38: note: candidate is:
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:368:6: note: void W5100Class::setGatewayIp(uint8_t*)
    void W5100Class::setGatewayIp(uint8_t *_addr) {
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:368:6: note:  no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:67:38: error: no matching function for call to 'W5100Class::setSubnetMask(IPAddress::<anonymous union>&)'
      W5100.setSubnetMask(subnet._address);
    /Users/mes01/Documents/Arduino/libraries/Ethernet/Ethernet.cpp:67:38: note: candidate is:
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:376:6: note: void W5100Class::setSubnetMask(uint8_t*)
    void W5100Class::setSubnetMask(uint8_t *_addr) {
    /Users/mes01/Documents/Arduino/libraries/Ethernet/utility/w5100.h:376:6: note:  no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
    Multiple libraries were found for "SPI.h"
    Used: /Users/mes01/Documents/Arduino/libraries/SPI
    Not used: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
    Multiple libraries were found for "Ethernet.h"
    Used: /Users/mes01/Documents/Arduino/libraries/Ethernet
    Not used: /Applications/Arduino.app/Contents/Java/libraries/Ethernet
    Ошибка компиляции.
      Это сообщение будет содержать больше информации чем
      "Отображать вывод во время компиляции"
      включено в Файл > Настройки
  2. mes01
    mes01 Нуб
    кстати использую оборудование:
    • Arduino UNO R3
    • Enc28j60 Ethernet LAN
  3. Unixon
    Тогда наверное нужно и библиотеку брать для Enc28j60, а не для W5100.
    Ошибки компиляции из-за месива несовместимых библиотек.
