Arduino: 1.8.9 (Windows 10), Плата:"Arduino/Genuino Uno" In file included from C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/TFT_eSPI.h:589:0, from C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master\examples\160 x 128\TFT_graphicstest_small\TFT_graphicstest_small.ino:19: C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:7:38: error: 'fs' has not been declared void loadFont(String fontName, fs::FS &ffs); ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:7:45: error: expected ',' or '...' before '&' token void loadFont(String fontName, fs::FS &ffs); ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:40:3: error: 'fs' does not name a type fs::File fontFile; ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:47:3: error: 'fs' does not name a type fs::FS &fontFS = SPIFFS; ^ exit status 1 Ошибка компиляции для платы Arduino/Genuino Uno. Этот отчёт будет иметь больше информации с включенной опцией Файл -> Настройки -> "Показать подробный вывод во время компиляции" Код (C++): /* Adapted from the Adafruit graphicstest sketch. This sketch uses the GLCD font (font 1) only. Disable other fonts to make the sketch fit in an UNO! Make sure all the display driver and pin comnenctions are correct by editting the User_Setup.h file in the TFT_eSPI library folder. Note that yield() or delay(0) must be called in long duration for/while loops to stop the ESP8266 watchdog triggering. ######################################################################### ###### DON'T FORGET TO UPDATE THE User_Setup.h FILE IN THE LIBRARY ###### ######################################################################### */ #include <TFT_eSPI.h> // Hardware-specific library #include <SPI.h> TFT_eSPI tft = TFT_eSPI(); // Invoke custom library float p = 3.1415926; void setup(void) { Serial.begin(9600); Serial.print("Hello! ST7735 TFT Test"); // Use this initializer if you're using a 1.8" TFT tft.init(); // initialize a ST7735S chip Serial.println("Initialized"); uint16_t time = millis(); tft.fillScreen(TFT_BLACK); time = millis() - time; Serial.println(time, DEC); delay(500); // large block of text tft.fillScreen(TFT_BLACK); testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", TFT_WHITE); delay(1000); // tft print function! tftPrintTest(); delay(4000); // a single pixel tft.drawPixel(tft.width()/2, tft.height()/2, TFT_GREEN); delay(500); // line draw test testlines(TFT_YELLOW); delay(500); // optimized lines testfastlines(TFT_RED, TFT_BLUE); delay(500); testdrawrects(TFT_GREEN); delay(500); testfillrects(TFT_YELLOW, TFT_MAGENTA); delay(500); tft.fillScreen(TFT_BLACK); testfillcircles(10, TFT_BLUE); testdrawcircles(10, TFT_WHITE); delay(500); testroundrects(); delay(500); testtriangles(); delay(500); mediabuttons(); delay(500); Serial.println("done"); delay(1000); } void loop() { tft.invertDisplay(true); delay(500); tft.invertDisplay(false); delay(500); } void testlines(uint16_t color) { tft.fillScreen(TFT_BLACK); for (int16_t x=0; x < tft.width(); x+=6) { tft.drawLine(0, 0, x, tft.height()-1, color); } for (int16_t y=0; y < tft.height(); y+=6) { tft.drawLine(0, 0, tft.width()-1, y, color); } tft.fillScreen(TFT_BLACK); for (int16_t x=0; x < tft.width(); x+=6) { tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color); } for (int16_t y=0; y < tft.height(); y+=6) { tft.drawLine(tft.width()-1, 0, 0, y, color); } tft.fillScreen(TFT_BLACK); for (int16_t x=0; x < tft.width(); x+=6) { tft.drawLine(0, tft.height()-1, x, 0, color); } for (int16_t y=0; y < tft.height(); y+=6) { tft.drawLine(0, tft.height()-1, tft.width()-1, y, color); } tft.fillScreen(TFT_BLACK); for (int16_t x=0; x < tft.width(); x+=6) { tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color); } for (int16_t y=0; y < tft.height(); y+=6) { tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color); } } void testdrawtext(char *text, uint16_t color) { tft.setCursor(0, 0); tft.setTextColor(color); tft.setTextWrap(true); tft.print(text); } void testfastlines(uint16_t color1, uint16_t color2) { tft.fillScreen(TFT_BLACK); for (int16_t y=0; y < tft.height(); y+=5) { tft.drawFastHLine(0, y, tft.width(), color1); } for (int16_t x=0; x < tft.width(); x+=5) { tft.drawFastVLine(x, 0, tft.height(), color2); } } void testdrawrects(uint16_t color) { tft.fillScreen(TFT_BLACK); for (int16_t x=0; x < tft.width(); x+=6) { tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color); } } void testfillrects(uint16_t color1, uint16_t color2) { tft.fillScreen(TFT_BLACK); for (int16_t x=tft.width()-1; x > 6; x-=6) { tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1); tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2); } } void testfillcircles(uint8_t radius, uint16_t color) { for (int16_t x=radius; x < tft.width(); x+=radius*2) { for (int16_t y=radius; y < tft.height(); y+=radius*2) { tft.fillCircle(x, y, radius, color); } } } void testdrawcircles(uint8_t radius, uint16_t color) { for (int16_t x=0; x < tft.width()+radius; x+=radius*2) { for (int16_t y=0; y < tft.height()+radius; y+=radius*2) { tft.drawCircle(x, y, radius, color); } } } void testtriangles() { tft.fillScreen(TFT_BLACK); int color = 0xF800; int t; int w = tft.width()/2; int x = tft.height()-1; int y = 0; int z = tft.width(); for(t = 0 ; t <= 15; t+=1) { tft.drawTriangle(w, y, y, x, z, x, color); x-=4; y+=4; z-=4; color+=100; } } void testroundrects() { tft.fillScreen(TFT_BLACK); int color = 100; int i; int t; for(t = 0 ; t <= 4; t+=1) { int x = 0; int y = 0; int w = tft.width()-2; int h = tft.height()-2; for(i = 0 ; i <= 16; i+=1) { tft.drawRoundRect(x, y, w, h, 5, color); x+=2; y+=3; w-=4; h-=6; color+=1100; } color+=100; } } void tftPrintTest() { tft.setTextWrap(false); tft.fillScreen(TFT_BLACK); tft.setCursor(0, 30); tft.setTextColor(TFT_RED); tft.setTextSize(1); tft.println("Hello World!"); tft.setTextColor(TFT_YELLOW); tft.setTextSize(2); tft.println("Hello World!"); tft.setTextColor(TFT_GREEN); tft.setTextSize(3); tft.println("Hello World!"); tft.setTextColor(TFT_BLUE); tft.setTextSize(4); tft.print(1234.567); delay(1500); tft.setCursor(0, 0); tft.fillScreen(TFT_BLACK); tft.setTextColor(TFT_WHITE); tft.setTextSize(0); tft.println("Hello World!"); tft.setTextSize(1); tft.setTextColor(TFT_GREEN); tft.print(p, 6); tft.println(" Want pi?"); tft.println(" "); tft.print(8675309, HEX); // print 8,675,309 out in HEX! tft.println(" Print HEX!"); tft.println(" "); tft.setTextColor(TFT_WHITE); tft.println("Sketch has been"); tft.println("running for: "); tft.setTextColor(TFT_MAGENTA); tft.print(millis() / 1000); tft.setTextColor(TFT_WHITE); tft.print(" seconds."); } void mediabuttons() { // play tft.fillScreen(TFT_BLACK); tft.fillRoundRect(25, 10, 78, 60, 8, TFT_WHITE); tft.fillTriangle(42, 20, 42, 60, 90, 40, TFT_RED); delay(500); // pause tft.fillRoundRect(25, 90, 78, 60, 8, TFT_WHITE); tft.fillRoundRect(39, 98, 20, 45, 5, TFT_GREEN); tft.fillRoundRect(69, 98, 20, 45, 5, TFT_GREEN); delay(500); // play color tft.fillTriangle(42, 20, 42, 60, 90, 40, TFT_BLUE); delay(50); // pause color tft.fillRoundRect(39, 98, 20, 45, 5, TFT_RED); tft.fillRoundRect(69, 98, 20, 45, 5, TFT_RED); // play color tft.fillTriangle(42, 20, 42, 60, 90, 40, TFT_GREEN); }
Hi! Библиотека работала до этого, или проблема только в этом скетче? Включите Файл -> Настройки -> «Показать подробный вывод во время компиляции», потом киньте вывод. А зачем это? Есть же константа PI
"C:\\Users\\COMP\\AppData\\Local\\Temp\\arduino_build_512958\\sketch\\TFT_Clock.ino.cpp.o" In file included from C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/TFT_eSPI.h:589:0, from C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master\examples\160 x 128\TFT_Clock\TFT_Clock.ino:14: C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:7:38: error: 'fs' has not been declared void loadFont(String fontName, fs::FS &ffs); ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:7:45: error: expected ',' or '...' before '&' token void loadFont(String fontName, fs::FS &ffs); ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:40:3: error: 'fs' does not name a type fs::File fontFile; ^ C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master/Extensions/Smooth_font.h:47:3: error: 'fs' does not name a type fs::FS &fontFS = SPIFFS; ^ Используем библиотеку TFT_eSPI-master версии 1.5.0 из папки: C:\Users\COMP\Documents\Arduino\libraries\TFT_eSPI-master Используем библиотеку SPI версии 1.0 из папки: D:\program files\arduino-1.8.9-windows\arduino-1.8.9\hardware\arduino\avr\libraries\SPI exit status 1 Ошибка компиляции для платы Arduino/Genuino Uno.
