Подружить код (за вознаграждение)
Тема в разделе "Arduino & Shields", создана пользователем sersahar, 14 янв 2016.
  1. sersahar
    sersahar Нерд
    Всем привет. Задача такая. Есть скетч с использованием библиотеки <EtherCard.h>. Нашел инфу, которая мне кажется подойдет для моей задачи, а именно простой smtp клиент (без всякой авторизации). Источник: https://github.com/gregington/SMTPClient .
    An Arduino library to send emails to an SMTP server. Supports sending emails from an Arduino to an unauthenticated SMTP server. This library supports sending email through Ethernet, however it should also work with WiFi, but this has not been tested.
    Usage
    Client.h, Mail.h and SMTPClient.h need to be imported.
    #import <Client.h>
    #import <Mail.h>
    #import <SMTPClient.h>
    An instance of SMTPClient needs to be created with the server hostname or IP and the port where the SMTP server is located as well as the Client instance that will be used to make the connection. If the port is omitted, it is defaulted to port 25. In the following example, the client is an EthernetClient, but a WiFi or other client could be specified.
    byte ip[] = { 192, 168, 0, 125 };
    EthernetClient ethClient;
    SmtpClient client(&ethClient, ip);
    To send an email, an instance of the Mail class needs to be creaed and methods called to populate the object. At a minimum, at least one recipient and a from address are required. A maximum of 16 destination addresses are supported, with them being any combination of To, Cc or Bcc.
    Mail mail;
    mail.from("Some Sender <sender@example.com>");
    mail.replyTo("noreply@example.com");
    mail.to("Someone <someone@example.com>");
    mail.to("Someone Else <someoneelse@example.com>");
    mail.cc("Another <another@example.com>");
    mail.bcc("Secret <secret@example.com>");
    mail.subject("Hello there");
    mail.body("I can send email from an Arduino!");
    client.send(&mail);
    Моя часть кода для инициализации сетевого модуля:
    static byte mymac[] = {0x5A,0x5A,0x5A,0x5A,0x5A,0x5A };
    static byte myip[] = { 192,168,1,222 };
    static uint8_t gateway_ip[4]={192,168,1,1};
    byte Ethernet::buffer[900];
    BufferFiller bfill;
      if (ether.begin(sizeof Ethernet::buffer, mymac,10) == 0);
      ether.staticSetup(myip,gateway_ip); }
    с меня расчет тому, кто действительно поможет. Гарантирую
    • ethercard.zip
      95,3 КБ
  2. Mestniy
    Mestniy Гуру
  3. sersahar
    sersahar Нерд
    больше желающих нет?
