Помогите исправить ошибки в скетче
Тема в разделе "Моторы, сервоприводы, робототехника", создана пользователем джекте трис, 9 сен 2018.
  1. Всем привет я скачал проект :
    MJRoBot-Programmed-Arm
    и в скетче есть ошибки
    сам не понял но надеюсь на вас
    Часть 1
    *  3 or 4-DOF Arm  Programming to perform a specific repetitive task
    *  Programing local or remote using Android/BT
    *  ==> In mode "Local" the servos are controled only by Potenciometers.
    *  ==> In mode "Remote" the servos are controled only by Sliders at Android.
    *  ==> Physical Switchs (Buttons) work in paralell with Android.
    *  ==> Arm Robot Starts as "Local" mode control. Pressing "Alarm" or "Remote/Local" button at Android, will put in mode "Remote"
    *  ==> Press button PROGRAM localy or at Android to Record a step (LED Grenn will light up)
    *  ==> Press button RUN localy or at Android to execute sequencially the recorded steps, the "program" (LED blue will light up)
    *  ==> Press button RESTART at Android to abort program (LED red will light up) - Note that should be at end of a completre pgm.
    *  ==> Servos Ranges can be defined at ArmDefines.h or at by Android app
    Develop by Marcelo Jose Rovai
    Please visit http://MJRoBot.org for more information
    The Android app can be dowload free at Google Play Store: https://play.google.com/store/apps/details?id=appinventor.ai_mjrovai.MJRoBot_BT_ARM_CTRL_V2_1&hl=en
    16Fev16
    #include <Servo.h>
    #include <LiquidCrystal.h>
    #include "ArmDefines.h"
      BT.begin(9600);
      lcdMessage("Arm Robot prog.", "   MJRoBot.org"); // Display message at LCD
      myservoBase.attach(servoBasePin);  // attaches the servo
      myservoShou.attach(servoShouPin);  // attaches the servo
      myservoGrip.attach(servoGripPin);  // attaches the servo
      myservoElbw.attach(servoElbwPin);  // attaches the servo
      pinMode (ledYellow, OUTPUT);
      pinMode (ledGreen, OUTPUT);
      pinMode (ledRed, OUTPUT);
      pinMode (buzzerPin, OUTPUT);
      pinMode (recordPositionPin, INPUT);
      pinMode (execTaskPin, INPUT);
      pinMode (resetSwitchPin, INPUT);
      digitalWrite(ledRed, LOW);
      digitalWrite(ledGreen, LOW);
      digitalWrite(ledYellow, HIGH);
      armPositionZero(); //Put Arm at "position zero" that is define as "mid<servo>" position
      delay (time);
      lcdArmPosition(); // Display Servo Positions at LCD
      outputPosition(); // Display Servo Positions at Serial Monitor
      warningStartTask();
      digitalWrite(ledGreen, HIGH);
      checkBTcmd();
      defineLocalRemote();
      execTaskCmd = digitalRead (execTaskPin);
      if(execTaskCmd == HIGH || command == "runon")
        runProgram();
      else recArmPosition();
      command = "";
    * Defime mode Local / Remote
    void defineLocalRemote()
      if (command == "alarmon")
        alarmRemoteCommand();
      if (command == "remote")
        remoteCommand = !remoteCommand;
        digitalWrite(ledYellow, !remoteCommand);
        BT.print("change command");
    * Run Program
    void runProgram()
      digitalWrite(ledBlue, HIGH);
      executeTask();
      lcdArmPosition();
      outputPosition();
      digitalWrite(ledBlue, LOW);
    * Record Arm Positon
    void recArmPosition()
      recordPosition = debounce (recordPositionPin);
      if(recordPosition == HIGH || command == "pgmon")
        positionIndex++;
        gripPosition[positionIndex] = servoGripVal;
        basePosition[positionIndex] = servoBaseVal;
        shouPosition[positionIndex] = servoShouVal;
        elbwPosition[positionIndex] = servoElbwVal;
        beep(buzzerPin, 1000, 100);
        serialMonitorArmPosition();
        lcdArmPgmPosition(positionIndex);
        delay(1000);
      if (!remoteCommand && readPotenciometers())
        lcdArmPosition();
        outputPosition();
        armPosition(servoGripVal, servoBaseVal, servoShouVal, servoElbwVal);
        servoGripPastVal = servoGripVal;
        servoBasePastVal = servoBaseVal;
        servoShouPastVal = servoShouVal;
        servoElbwPastVal = servoElbwVal;
      if (remoteCommand && readSliders())
        lcdArmPosition();
        outputPosition();
    * Executed recorded task program
    void executeTask()
      int i;
      warningStartTask();
      resetSwitch = digitalRead(resetSwitchPin);
      while (resetSwitch == LOW)
        for (i=1; i<=positionIndex; i++)
          lcdArmPgmPosition(i);
          armPosition(gripPosition[i], basePosition[i], shouPosition[i], elbwPosition[i]);
          delay (time);
        i=0;
        checkBTcmd();
        Serial.println (command);
        if (command == "rston") {resetSwitch = HIGH;}
        else {resetSwitch = digitalRead(resetSwitchPin);}
      digitalWrite(ledRed, HIGH);
      positionIndex = 0;
      BT.print("reset");
      warningFinishTask();
      armPositionZero();
  2. Часть 2
    #define BT Serial1
    String command;
    String device;
    int time = 2000; // <== Could be necessary to adjust
    /* Define Arm parameters to be used */
    // MeArm 4-DOF
    #define minGrip 15
    #define minBase 0
    #define minShou 60
    #define minElbw 60
    #define maxGrip 45
    #define maxBase 170
    #define maxShou 180
    #define maxElbw 150
    #define midGrip 30
    #define midBase 87
    #define midShou 138
    #define midElbw 100
    /* SS 3-DOF
    #define minGrip 75
    #define minBase 5
    #define minShou 5
    #define minElbw 0
    #define maxGrip 125
    #define maxBase 150
    #define maxShou 155
    #define maxElbw 0
    #define midGrip 100
    #define midBase 90
    #define midShou 90
    #define midElbw 0
    LiquidCrystal lcd(12, 11, 2, 4, 6, 8);
    const int servoBasePin = 3;        // first servo - base
    const int servoShouPin = 10;      // second servo - shouder
    const int servoGripPin = 5;       // third servo - gripp
    const int servoElbwPin = 9;      // forth servo (ELBOW - used at meArm)
    const int recordPositionPin = 7;  // Button to record position
    const int ledGreen = 13;          // LED to inform that a position was recorded
    const int execTaskPin = 15;  // Button to record position
    const int ledBlue =14;        // LED to inform that a recorded task is underway
    const int ledYellow = 21;
    int remoteCommand = 0;
    const int resetSwitchPin = 17;
    int resetSwitch = 0; //
    const int ledRed = 20;        // LED to inform that a recorded task is aborted
    const int joyBase = 2;      // Pot or Joystick used for Basemouth control
    const int joyShou = 3;     // Pot or Joystick used for shouation control
    const int potpin = 0;      // Pot used for Gripp control
    const int joyElbw = 1;     // Pot used for Gripp control
    const int buzzerPin = 16;   //
    int servoBaseVal;           // variables to read the value from the analog pin
    int servoShouVal;
    int servoGripVal;
    int servoElbwVal;
    int servoBasePastVal;       // variables to store the value from the analog pin at last loop
    int servoShouPastVal;
    int servoGripPastVal;
    int servoElbwPastVal;
    int movement;
    int recordPosition = 0;        // if HIGH, record servo position
    int execTaskCmd = 0;              // if HIGH, run program
    Servo myservoBase;  // create servo object to control a servo
    Servo myservoShou;  // create servo object to control a servo
    Servo myservoGrip;  // create servo object to control a servo
    Servo myservoElbw;  // create servo object to control a servo
    int gripPosition[100];
    int basePosition[100];
    int shouPosition[100];
    int elbwPosition[100];
    int positionIndex = 0;   // Index to be used at position array used for recorded tasks
  3. Часть 3
    * Read and Map sliders at Android for Servos positioning
    bool readSliders()
      char armServo = command[0];
         byte value = command[2];
         //Serial.print(armServo);
        // Serial.println(value);
         if ( armServo == 'g')
           servoGripVal = value;
           servoGripVal = map(servoGripVal, 0, 255, minGrip, maxGrip); // scale it to use it with the servo
         if ( armServo == 'b')
           servoBaseVal = value;
           servoBaseVal = map(servoBaseVal, 0, 255, minBase, maxBase);     // scale it to use it with the servo
         if ( armServo == 's')
           servoShouVal = value;
           servoShouVal = map(servoShouVal, 0, 255, minShou, maxShou);     // scale it to use it with the servo
         if ( armServo == 'e')
           servoElbwVal = value;
           servoElbwVal = map(servoElbwVal, 0, 255, minElbw, maxElbw);     // scale it to use it with the servo
      if (servoGripVal != servoGripPastVal || servoBaseVal != servoBasePastVal || servoShouVal != servoShouPastVal || servoElbwVal != servoElbwPastVal)
        movement = true;
      }else movement = false;
      return movement;
    * Read and Map Potenciometers for Servos positioning
    bool readPotenciometers()
      servoGripVal = analogRead(potpin);
      servoGripVal = map(servoGripVal, 0, 1023, minGrip, maxGrip); // scale it to use it with the servo
      // Read the Basemouth value  (value between 0 and 1023)
      servoBaseVal = analogRead(joyBase);
      servoBaseVal = map(servoBaseVal, 0, 1023, minBase, maxBase);     // scale it to use it with the servo
      // Read the shouation value  (value between 0 and 1023)
      servoShouVal = analogRead(joyShou);
      servoShouVal = map(servoShouVal, 0, 1023, minShou, maxShou);     // scale it to use it with the servo
    // Read the elbow value  (value between 0 and 1023)
      servoElbwVal = analogRead(joyElbw);
      servoElbwVal = map(servoElbwVal, 0, 1023, minElbw, maxElbw);     // scale it to use it with the servo
        movement = true;
      return movement;
    * Read and Map Potenciometers at begginging
    void readPotenciometersInitial()
      outputPosition();
    * Put Arm at given position
    void armPosition(int gripp, int basee, int shouder, int elbow )
      myservoGrip.write(gripp);
      delay(15);
      myservoBase.write(basee);
      delay(15);
      myservoShou.write(shouder);
      delay(15);
      myservoElbw.write(elbow);
      delay(15);
    * Put Arm at "position zero"
    void armPositionZero()
      servoBaseVal = midBase;
      servoShouVal = midShou;
      servoGripVal = midGrip;
      servoElbwVal = midElbw;
      myservoBase.write(servoBaseVal);
      delay(15);
      myservoShou.write(servoShouVal);
      delay(15);
      myservoGrip.write(servoGripVal);
      delay(15);
      myservoElbw.write(servoElbwVal);
      delay(15);
    * Display Servo Positions at Serial Monitor
    void outputPosition()
        Serial.print("   Gripp: ");
        Serial.print (servoGripVal);
        Serial.print("   Base: ");
        Serial.print(servoBaseVal);
        Serial.print("   Shoulder: ");
        Serial.print(servoShouVal);
        Serial.print("   Elbow: ");
        Serial.println (servoElbwVal);
    * Print at Serial Monotor the actual Arm Position
    void serialMonitorArmPosition()
       Serial.print("Position ==>");
       Serial.print(positionIndex);
       Serial.println(gripPosition[positionIndex]);
       Serial.print(basePosition[positionIndex]);
       Serial.print(shouPosition[positionIndex]);
       Serial.println(elbwPosition[positionIndex]);
    * Display Arm Position ar LCD
    void lcdArmPosition()
        lcd.begin(16, 2);
        lcd.print("Grp Bas Sho Elw ");
        lcd.setCursor(0, 1);
        lcd.print("                ");
        lcd.print("   ");
        lcd.print(servoGripVal);
        lcd.setCursor(4, 1);
        lcd.print("   ");
        lcd.print(servoBaseVal);
        lcd.setCursor(8, 1);
        lcd.print("   ");
        lcd.print(servoShouVal);
        lcd.setCursor(12, 1);
        lcd.print("   ");
        lcd.print(servoElbwVal);
    * Display Arm proggramed Position (steps) at LCD
    void lcdArmPgmPosition(int pos)
        lcd.begin(16, 2);
        lcd.setCursor(0, 0);
        lcd.print("                ");
        lcd.print("Position # ");
        lcd.setCursor(12, 0);
        lcd.print("   ");
        lcd.print(pos);
        lcd.print("                ");
        lcd.print("   ");
        lcd.print("   ");
        lcd.print("   ");
        lcd.print("   ");
    * Warning with sound start of a programed task
    void warningStartTask()
      lcd.begin(16, 2);
      lcd.print("                ");
      lcd.print("WARNING PGM INIT");
      lcd.print("                ");
      lcd.print("<<<<<<<<>>>>>>>>");
      for (int cont=30; cont<100; cont++)
      { // Play Music
        beep(buzzerPin, 10*cont, 10);
      for (int cont=100; cont>30; cont--)
      { // Play Music
      for(int cont = 0; cont < 3; cont++){   //Bip 2 times
        delay(100);
    * Warning with sound  the start programming a new task
    void warningFinishTask()
      lcd.begin(16, 2);
      lcd.print("                ");
      lcd.print(" Start New PGM ");
      lcd.print("                ");
      lcd.print(">>>>>>><<<<<<<<<");
      { // Play Music
        beep(buzzerPin, 5*cont, 10);
      { // Play Music
        beep(buzzerPin, 1000, 300);
        delay(100);
    * Alarm command received
    void alarmRemoteCommand()
      lcd.begin(16, 2);
      lcd.print("                ");
      lcd.print("REMOTE - CONTROL");
      lcd.print("                ");
      for (int cont=30; cont<100; cont++){ // Play Music
      for (int cont=100; cont>30; cont--){
      lcd.print("     Start      ");;
      lcd.print("   Programing   ");
      command = "remote";
      remoteCommand = 0;
  4. Часть 4
    * Verify if there is data at BT if YES, storage at "command"
    void checkBTcmd()
       while (BT.available())   //Check if there is an available byte to read
         delay(10); //Delay added to make thing stable
         char c = BT.read(); //Conduct a serial read
         device += c; //build the string.
       if (device.length() > 0)
         Serial.print("Command received from BT ==> ");
         Serial.println(device);
         command = device;
         device ="";  //Reset the variable
    * Sound Generator
    void beep(int pin, int freq, long ms)   //square wave - freq ==> ms
      int i;
      long semiper = (long) (1000000/(freq*2));
      long loops = (long)((ms*1000)/(semiper*2));
      for (i=0;i<loops;i++){
        digitalWrite(pin, HIGH);  //set buzzer pin high
        delayMicroseconds(semiper);  //for half of the period
        digitalWrite(pin, LOW);   //set buzzer pin low
        delayMicroseconds(semiper);  //for the other half of the period
    * Debouncing a key
    boolean debounce(int pin)
      boolean state;
      boolean previousState;
      const int debounceDelay = 60;
      previousState = digitalRead(pin);
      for(int counter=0; counter< debounceDelay; counter++)
        delay(1);
        state = digitalRead(pin);
        if(state != previousState)
          counter =0;
          previousState = state;
      return state;
    * Display message at LCD
    void lcdMessage(String line1, String line2)
        lcd.begin(16, 2);
        lcd.print("                ");
        lcd.print(line1);
        lcd.print("                ");
        lcd.print(line2);
  5. Вот Схема
