Есть esp8266-01, реле, емкосная сенсорная кнопка, и вот такой скейч Код (C++): // Relay control using the ESP8266 WiFi chip // Import required libraries #include <ESP8266WiFi.h> // WiFi parameters const char* ssid = "****"; const char* password = "****"; //Room Name const String RoomName = "Room 1"; //Response from Client String request = ""; // The port to listen for incoming TCP connections #define LISTEN_PORT 80 // set pin numbers: const int buttonPin = 0; // the number of the pushbutton pin const int relayPin = 2; // the number of the LED pin int relayState = LOW; // the current state of the output pin int buttonState; // the current reading from the input pin int lastButtonState = LOW; // the previous reading from the input pin long lastDebounceTime = 0; // the last time the output pin was toggled long debounceDelay = 50; // the debounce time; increase if the output flickers // Create an instance of the server WiFiServer server(LISTEN_PORT); WiFiClient client; void setup(void) { // Start Serial Serial.begin(115200); delay(10); Serial.println(); Serial.println(); Serial.println(); Serial.println(); pinMode(buttonPin, INPUT); pinMode(relayPin, OUTPUT); // set initial LED state digitalWrite(relayPin, relayState); // Connect to WiFi WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); // Start the server server.begin(); Serial.println("Server started"); Serial.println("You can connect to this Switch at this URL:"); Serial.print("http://"); // Print the IP address Serial.print(WiFi.localIP()); Serial.println("/"); } void loop() { String request = ""; // Handle REST calls WiFiClient client = server.available(); if (client) { Serial.println("User connected."); while(!client.available()){ delay(1); } Serial.print("Request Received:"); String request = client.readStringUntil('\r\n'); Serial.println(request); client.flush(); } //process the request if (request.indexOf("/LED=ON") != -1) { digitalWrite(relayPin,LOW); } if (request.indexOf("/LED=OFF") != -1) { digitalWrite(relayPin,HIGH); } // read the state of the switch into a local variable: int reading = digitalRead(buttonPin); // If the switch changed, due to noise or pressing: if (reading != lastButtonState) { // reset the debouncing timer lastDebounceTime = millis(); } if ((millis() - lastDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: // if the button state has changed: if (reading != buttonState) { buttonState = reading; // only toggle the LED if the new button state is HIGH if (buttonState == HIGH) { relayState = !relayState; } } } digitalWrite(relayPin, relayState); // save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonState = reading; if (client) { client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html"); client.println(""); client.println("<!DOCTYPE HTML>"); client.println("<html>"); client.println("<head><title>ESP8266 RELAY Control</title></head>"); client.print("<h1>Relay is now: </h1>"); if(relayState == HIGH) { client.print("<div style=\"text-align: center;width: 198px;color:white ;padding: 10px 30px;background-color: #ff9900;margin: 0 auto;\">OFF</div>"); } else { client.print("<div style=\"text-align: center;width: 198px;color:white ;padding: 10px 30px;background-color: #43a209;margin: 0 auto;\">ON</div>"); } client.println("<br><br>"); client.println("<div>"); client.println("<div style=\"text-align: center;font-size: 50px;width: 298px;color:white ;padding: 10px 30px;background-color: #ff9900;margin: 0 auto;\">Turn <a href=\"/LED=OFF\">OFF</a> RELAY<br></div>"); client.println("<div style=\"text-align: center;font-size: 50px;width: 298px;color:white ;padding: 10px 30px;background-color: #43a209;margin: 0 auto;\">Turn <a href=\"/LED=ON\">ON</a> RELAY<br></div>"); client.println("</div>"); client.println("</html>"); delay(1); Serial.println("Client disonnected"); Serial.println(""); } } моя проблема в том что я хочу выключать и включать реле из веб формы, и с кнопки, но что то не то я пишу в коде,
А если закинуть странички в SPIFFS ? Там же нельзя использовать Си-код. Нашёл пример для ESP32, там для переменных используют в коде страничек что то типа %BUTTON, и это потом вызывает одноименные переменные в Си-коде, насколько я понял. Если не сложно, пожалуйста, ткните носом где рассказано как на ESP8266 привязать переменные, или строки (в случае с get/post), к событиям на веб страничках находящихся в SPIFFS ? Надеюсь Вы поняли о чем я спрашиваю?
Вроде бы, что-то подобное есть на амперка вики. И даже набор готовый для этого есть: https://amperka.ru/product/matryoshka-iot
