Помогите пожалуйста с кодом для работы с SDcard
Тема в разделе "Arduino & Shields", создана пользователем Roman77, 10 авг 2015.
  1. Roman77
    Roman77 Нуб
    Использую Arduino UNO + SD Card SHield от Seeed Studio. Не получается открыть файл с SD (16M) для чтения и выдать в COM порт. Исходник в файле 1.txt. Монитор выдает следующее сообщение:
    Initializing SD card...Wiring is correct and a card is present.
    Card type: SD2
    Volume type is FAT16
    Volume size (bytes): 1014743040
    Volume size (Kbytes): 990960
    Volume size (Mbytes): 967
    Files found on the card (name, date and size in bytes):
    DATA.TXT 2015-08-10 22:57:44 8
    reading data.txt from card...
    error opening data.txt from card
    • 1.txt
      5,3 КБ
  2. Megakoteyka
    Megakoteyka Оракул Модератор
    Отформатируйте код нажатием Ctrl+T в Arduino IDE, потом вставьте код на форум при помощи тэга CODE.
  3. Roman77
    Roman77 Нуб
      SD card test
    This example shows how use the utility libraries on which the'
    SD library is based in order to get info about your SD card.
    Very useful for testing a card when you're not sure whether its working or not.
    The circuit:
      * SD card attached to SPI bus as follows:
    ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
    ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
    ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
    ** CS - depends on your SD card shield or module.
    ** Pin 4 used here for consistency with other Arduino examples
    created  28 Mar 2011
    by Limor Fried
    modified 9 Apr 2012
    by Tom Igoe
    // include the SD library:
    #include <SPI.h>
    #include <SD.h>
    // set up variables using the SD utility library functions:
    Sd2Card card;
    SdVolume volume;
    SdFile root;
    // change this to match your SD shield or module;
    // Arduino Ethernet shield: pin 4
    // Adafruit SD shields and modules: pin 10
    // Sparkfun SD shield: pin 8
    const int chipSelect = 4;
      // Open serial communications and wait for port to open:
      while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      Serial.print("\nInitializing SD card...");
      // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
      // Note that even if it's not used as the CS pin, the hardware SS pin
      // (10 on most Arduino boards, 53 on the Mega) must be left as an output
      // or the SD library functions will not work.
      pinMode(10, OUTPUT);    // change this to 53 on a mega
      // we'll use the initialization code from the utility libraries
      // since we're just testing if the card is working!
      if (!card.init(SPI_HALF_SPEED, chipSelect)) {
        Serial.println("initialization failed. Things to check:");
        Serial.println("* is a card is inserted?");
        Serial.println("* Is your wiring correct?");
        Serial.println("* did you change the chipSelect pin to match your shield or module?");
        return;
      } else {
        Serial.println("Wiring is correct and a card is present.");
      // print the type of card
      Serial.print("\nCard type: ");
      switch (card.type()) {
        case SD_CARD_TYPE_SD1:
          Serial.println("SD1");
          break;
        case SD_CARD_TYPE_SD2:
          Serial.println("SD2");
          break;
        case SD_CARD_TYPE_SDHC:
          Serial.println("SDHC");
          break;
        default:
          Serial.println("Unknown");
      // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
      if (!volume.init(card)) {
        Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
        return;
      // print the type and size of the first FAT-type volume
      uint64_t volumesize64;
      uint32_t volumesize32;
      Serial.print("\nVolume type is FAT");
      Serial.println(volume.fatType(), DEC);
      Serial.println();
      volumesize64 = volume.blocksPerCluster();    // clusters are collections of blocks
      volumesize64 *= volume.clusterCount();      // we'll have a lot of clusters
      volumesize64 *= 512;                            // SD card blocks are always 512 bytes
      Serial.print("Volume size (bytes): ");
      printLLNumber(volumesize64, DEC);
      Serial.println();
      Serial.print("Volume size (Kbytes): ");
      volumesize32 = volumesize64 / 1024;
      Serial.println(volumesize32);
      Serial.print("Volume size (Mbytes): ");
      volumesize32 /= 1024;
      /*uint64_t volumesize;
      Serial.println();
      volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
      volumesize *= volume.clusterCount();      // we'll have a lot of clusters
      volumesize *= 512;                            // SD card blocks are always 512 bytes
      Serial.println(volumesize,DEC);
      volumesize /= 1024;
      volumesize /= 1024;
      Serial.println("\nFiles found on the card (name, date and size in bytes): ");
      root.openRoot(volume);
      // list all files in the card with date and size
      root.ls(LS_R | LS_DATE | LS_SIZE);
      //---------------------------- здесь не открывается файл -------------------------------
      Serial.println("reading data.txt from card...");
      //открываем файл "data.txt" в корневом каталоге, и если он открылся
      File dataFile = SD.open("DATA.txt");
      if (dataFile) {
        //и если он открылся в цикле до конца файла
        //читаем по одному байту из файла и выводим в COM порт
        while (dataFile.available()) {
          Serial.write(dataFile.read());
        //закрываем файл
        dataFile.close();
      else {
        Serial.println("error opening data.txt from card");
    void loop(void) {
    void printLLNumber(uint64_t n, uint8_t base)
      unsigned char buf[16 * sizeof(long)];
      unsigned int i = 0;
      if (n == 0)
        Serial.print((char)'0');
        return;
      while (n > 0)
        buf[i++] = n % base;
        n /= base;
      for (; i > 0; i--)
        Serial.print((char) (buf[i - 1] < 10 ?
                            '0' + buf[i - 1] :
                            'A' + buf[i - 1] - 10));
  4. Roman77
    Roman77 Нуб
    Менял карточки, не помогает. Карточки определяет информацию о файлах на карте выдает, но не может создать файл или открыть файл для чтения. Также пробовал вставить код ниже, выдает сообщение
    Card type: SD2
    Creating example.txt...
    example.txt doesn't exist.
    Removing example.txt...
      Serial.println("Creating example.txt...");
      myFile = SD.open("example.txt", FILE_WRITE);
      myFile.close();
      // Check to see if the file exists:
      if (SD.exists("example.txt")) {
        Serial.println("example.txt exists.");
      else {
        Serial.println("example.txt doesn't exist.");
      // delete the file:
      Serial.println("Removing example.txt...");
      SD.remove("example.txt");
      else {
