Помогите разобратся с роботом
Тема в разделе "Глядите, что я сделал", создана пользователем keeper, 27 июл 2014.
  1. keeper
    keeper Нерд
    делал робота по мануалу отсюда
    скетч
    // ���� ������ � ArduinoKit.ru
    #include <AFMotor.h>
    #include <Servo.h>
    #include <NewPing.h>
    #define TRIG_PIN A4 // Pin A4 on the Motor Drive Shield soldered to the ultrasonic sensor
    #define ECHO_PIN A5 // Pin A5 on the Motor Drive Shield soldered to the ultrasonic sensor
    #define MAX_DISTANCE 200 // sets maximum useable sensor measuring distance to 200cm
    #define MAX_SPEED 180 // sets speed of DC traction motors to 180/256 or about 70% of full speed - to get power drain down.
    #define MAX_SPEED_OFFSET 20 // this sets offset to allow for differences between the two DC traction motors
    #define COLL_DIST 10 // sets distance at which robot stops and reverses to 10cm
    #define TURN_DIST COLL_DIST+10 // sets distance at which robot veers away from object (not reverse) to 20cm (10+10)
    NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
    AF_DCMotor motor1(1, MOTOR12_1KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
    AF_DCMotor motor2(2, MOTOR12_1KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
    Servo myservo;  // create servo object to control a servo
    int pos = 0; // this sets up variables for use in the sketch (code)
      int maxDist = 0;
      int maxAngle = 0;
      int maxRight = 0;
      int maxLeft = 0;
      int maxFront = 0;
    int course = 0;
    int curDist = 0;
    String motorSet = "";
    int speedSet = 0;
    //-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
      myservo.attach(9);  // attaches the servo on pin 9 (SERVO_2 on the Motor Drive Shield to the servo object
      myservo.write(90); // tells the servo to position at 90-degrees ie. facing forward.
      delay(2000); // delay for two seconds
      checkPath(); // run the CheckPath routine to find the best path to begin travel
      motorSet = "FORWARD"; // set the director indicator variable to FORWARD
      myservo.write(90); // make sure servo is still facing forward
      moveForward(); // run function to make robot move forward
    //---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
    delay(50);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
      unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
      Serial.print("Ping: ");
      Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
      Serial.println("cm");
      checkForward(); // check that if the robot is supposed to be moving forward, that the drive motors are set to move forward - this is needed to overcome some issues with only using 4 AA NiMH batteries
      checkPath(); // set ultrasonic sensor to scan for any possible obstacles
    void checkPath() {
      int curLeft = 0;
      int curFront = 0;
      int curRight = 0;
      int curDist = 0;
      myservo.write(144); // set servo to face left 54-degrees from forward
      delay(120); // wait 120milliseconds for servo to reach position
      for(pos = 144; pos >= 36; pos-=18)    // loop to sweep the servo (& sensor) from 144-degrees left to 36-degrees right at 18-degree intervals.
        myservo.write(pos);  // tell servo to go to position in variable 'pos'
        delay(90); // wait 90ms for servo to get to position
        checkForward(); // check the robot is still moving forward
        curDist = readPing(); // get the current distance to any object in front of sensor
        if (curDist < COLL_DIST) { // if the current distance to object is less than the collision distance
          checkCourse(); // run the checkCourse function
          break; // jump out of this loop
        if (curDist < TURN_DIST) { // if current distance is less than the turn distance
          changePath(); // run the changePath function
        if (curDist > curDist) {maxAngle = pos;}
        if (pos > 90 && curDist > curLeft) { curLeft = curDist;}
        if (pos == 90 && curDist > curFront) {curFront = curDist;}
        if (pos < 90 && curDist > curRight) {curRight = curDist;}
      maxLeft = curLeft;
      maxRight = curRight;
      maxFront = curFront;
    void setCourse() { // set direction for travel based on a very basic distance map, simply which direction has the greatest distance to and object - turning right or left?
        if (maxAngle < 90) {turnRight();}
        if (maxAngle > 90) {turnLeft();}
        maxLeft = 0;
        maxRight = 0;
        maxFront = 0;
  2. keeper
    keeper Нерд
    void checkCourse() { // we're about to hit something so move backwards, stop, find where the empty path is.
    moveBackward();
    delay(500);
    moveStop();
    setCourse();
    void changePath() {
    if (pos < 90) {veerLeft();} // if current pos of sensor is less than 90-degrees, it means the object is on the right hand side so veer left
    if (pos > 90) {veerRight();} // if current pos of sensor is greater than 90-degrees, it means the object is on the left hand side so veer right
    int readPing() { // read the ultrasonic sensor distance
    delay(70);
    int cm = uS/US_ROUNDTRIP_CM;
    return cm;
    void checkForward() { if (motorSet=="FORWARD") {motor1.run(FORWARD); motor2.run(FORWARD); } } // make sure motors are going forward
    void checkBackward() { if (motorSet=="BACKWARD") {motor1.run(BACKWARD); motor2.run(BACKWARD); } } // make sure motors are going backward
    // In some cases, the Motor Drive Shield may just stop if the supply voltage is too low (due to using only four NiMH AA cells).
    // The above functions simply remind the Shield that if it's supposed to go forward, then make sure it is going forward and vice versa.
    void moveStop() {motor1.run(RELEASE); motor2.run(RELEASE);} // stop the motors.
    void moveForward() {
    motor1.run(FORWARD); // turn it on going forward
    motor2.run(FORWARD); // turn it on going forward
    for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
    delay(5);
    void moveBackward() {
    motorSet = "BACKWARD";
    motor1.run(BACKWARD); // turn it on going forward
    motor2.run(BACKWARD); // turn it on going forward
    delay(5);
    void turnRight() {
    motorSet = "RIGHT";
    motor1.run(FORWARD); // turn motor 1 forward
    motor2.run(BACKWARD); // turn motor 2 backward
    delay(400); // run motors this way for 400ms
    motor1.run(FORWARD); // set both motors back to forward
    void turnLeft() {
    motorSet = "LEFT";
    motor1.run(BACKWARD); // turn motor 1 backward
    motor2.run(FORWARD); // turn motor 2 forward
    void veerRight() {motor2.run(BACKWARD); delay(400); motor2.run(FORWARD);} // veering right? set right motor backwards for 400ms
    void veerLeft() {motor1.run(BACKWARD); delay(400); motor1.run(FORWARD);} // veering left? set left motor backwards for 400ms
    [/CODE]
    проблема вот в чем приподключении питания через мотор шилд работают только сервы движки малчат при подключении через юсб все работает вроде нормально
    питание крона 9в
    в чем может быть проблема
    и при включении плата издаёт ровномерное пищание это нормально ?
  3. Apofiz
    Apofiz Гик
    Какая плата если сама ардуинка то естественно не нормально. Да и схему бы вашего подключения в живую увидеть(надеюсь понимаете что приведенные вами скетчи тут не причем) у вас что то с питанием напутано. И еще вас не смутило что в оригинальном проекте питание
    а это 1.2в Х4=4.8 вольта а у вас 9 вольт
  4. keeper
    keeper Нерд
    пробовал на 4x1.2 таже ситуация
  5. keeper
    keeper Нерд
    пробовал питание и через мотор шилд подать тожесамое
  6. Apofiz
    Apofiz Гик
    На мотор шилде внизу платы если смотреть разьемы сервы вверху а питание в низу есть переключатель фишка питания ее пробовали переключить? И как в оригинале подать питание через мотор шилд.
  7. keeper
    keeper Нерд
    для чего служит этот переключатель
  8. Apofiz
    Apofiz Гик
    Там же написано питание или 5вольт или ДЕВЯТЬ походу вы шо то спалили что какая плата писчит то и у вас он в положении 5 вольт стоит а вы ему 9 подавали!
  9. keeper
    keeper Нерд
    пины надо перемычкой соединить на нужное количество вольт
  10. Apofiz
    Apofiz Гик
    Для питания ардуинки а для питания самого мотор шилда? Там то походу напрямую идет.
  11. keeper
    keeper Нерд
    на эти кантакты надо перемычки какие ставить или это выходы
  12. Apofiz
    Apofiz Гик
    Чи я слепой в оригинальной статье никаких перемычек я не вижу в упор все там напрямую подается сразу на пины +5V или Vin А выставляется напряжение питания 5 или 9 вольт перемычкой что рядом EXT RWR и вы не переключив ее подали тудой 9 вольт вот и упалили походу микруху отвечающую за двигатели сервы работают а двигатели нет и писчит что то как вы говорите (Впрочем это мое личное мнение ИХМО и может быть отличным от вашего). Это выходы выведенные паралельно пинам 5в корпус корпус V in (такой платы нет на руках ну судя по фото так все и есть)
  13. keeper
    keeper Нерд
    но при подаче питания с юсб все работает нормально
    а при подаче с внешнего питания неважно 9 или 6 вольт одноразово не работает
  14. Apofiz
    Apofiz Гик
    На мотор шилде вы перемычку Ext Pwr переставляли? при питании 9 вольт
  15. keeper
    keeper Нерд
    есть скайп может так легче разобраться будет ?
  16. Apofiz
    Apofiz Гик
    Не скайпа нет. Дык в чем проблема у перемычки 2 положения 5 вольт и 9 вольт вы при питании через мотор шилд 9 вольтами перемычку переставляли в положение 9 вольт?
  17. keeper
    keeper Нерд
    вот с этими выводами я не уверен что они для перемычек в оригинаде они вообще не впаяны
  18. Apofiz
    Apofiz Гик
    Естествненно это не для перемычек это вообще по моему выходы для подключения еще чего нибуть перемычка рядом надеюсь внешнее питание вы подключаете в разьем справа М+ gnd
  19. keeper
    keeper Нерд
    поверьте я знаю что такон gnd и +
  20. Apofiz
    Apofiz Гик
    Вот и схема шилда нашлась http://yourduino.com/docs/Multi-MotorShieldSchematic.jpg И мы так и не выяснили
    Дык какая плата пищит то?
