Код (Text): Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 0 at processing.app.Sketch.setCurrentCode(Sketch.java:1182) at processing.app.Sketch.load(Sketch.java:220) at processing.app.Sketch.<init>(Sketch.java:142) at processing.app.Editor.handleOpenInternal(Editor.java:2157) at processing.app.Editor.<init>(Editor.java:304) at processing.app.Base.handleOpen(Base.java:704) at processing.app.Base.handleOpen(Base.java:669) at processing.app.Base.handleOpenPrompt(Base.java:658) at processing.app.Editor$4.actionPerformed(Editor.java:497) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242) at javax.swing.AbstractButton.doClick(AbstractButton.java:357) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266) at java.awt.Component.processMouseEvent(Component.java:6263) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6028) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4630) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.EventQueue.dispatchEvent(EventQueue.java:599) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122) Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 0 at processing.app.Sketch.setCurrentCode(Sketch.java:1182) at processing.app.Sketch.load(Sketch.java:220) at processing.app.Sketch.<init>(Sketch.java:142) at processing.app.Editor.handleOpenInternal(Editor.java:2157) at processing.app.Editor.<init>(Editor.java:304) at processing.app.Base.handleOpen(Base.java:704) at processing.app.Base.handleOpen(Base.java:669) at processing.app.Base.handleOpenPrompt(Base.java:658) at processing.app.Editor$4.actionPerformed(Editor.java:497) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242) at javax.swing.AbstractButton.doClick(AbstractButton.java:357) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266) at java.awt.Component.processMouseEvent(Component.java:6263) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6028) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4630) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.EventQueue.dispatchEvent(EventQueue.java:599) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122) Можно ли как-то после этого вернуть код?
Судя по всему, у Вас упала Arduino IDE (Exception -- ошибка на уровне языка Java, на котором она написана). Не знаю, как уж Вам удалось её уронить. Если Вы не нажимали save -- то код не вернуть. Или и файлы пропали?
Все админы (программеры, пользователи) делятся на тех кто уже делает бэкапы, и на на тех, кто этого еще не делает.
