Проблемы с GY-87
Тема в разделе "Схемотехника, компоненты, модули", создана пользователем ToxaRU, 30 авг 2015.
  1. ToxaRU
    ToxaRU Гик
    Есть готовый скетчь с компенсацией магнитометра по героскопу
      Tilt compensated HMC5883L + MPU6050 (GY-86 / GY-87). Output for HMC5883L_compensation_processing.pde
      Read more: http://www.jarzebski.pl/arduino/czujniki-i-sensory/3-osiowy-magnetometr-hmc5883l.html
      GIT: https://github.com/jarzebski/Arduino-HMC5883L
      Web: http://www.jarzebski.pl
      (c) 2014 by Korneliusz Jarzebski
    #include <Wire.h>
    #include <HMC5883L.h>
    #include <MPU6050.h>
    HMC5883L compass;
    MPU6050 mpu;
    float heading1;
    float heading2;
      // Initialize MPU6050
      while(!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
        delay(500);
      // Enable bypass mode
      mpu.setI2CMasterModeEnabled(false);
      mpu.setI2CBypassEnabled(true) ;
      mpu.setSleepEnabled(false);
      // Initialize Initialize HMC5883L
      while (!compass.begin())
        delay(500);
      // Set measurement range
      compass.setRange(HMC5883L_RANGE_1_3GA);
      // Set measurement mode
      compass.setMeasurementMode(HMC5883L_CONTINOUS);
      // Set data rate
      compass.setDataRate(HMC5883L_DATARATE_30HZ);
      // Set number of samples averaged
      compass.setSamples(HMC5883L_SAMPLES_8);
      // Set calibration offset. See HMC5883L_calibration.ino
      compass.setOffset(0, 0);
    // No tilt compensation
    float noTiltCompensate(Vector mag)
      float heading = atan2(mag.YAxis, mag.XAxis);
      return heading;
    // Tilt compensation
    float tiltCompensate(Vector mag, Vector normAccel)
      // Pitch & Roll
      float roll;
      float pitch;
      roll = asin(normAccel.YAxis);
      pitch = asin(-normAccel.XAxis);
      if (roll > 0.78 || roll < -0.78 || pitch > 0.78 || pitch < -0.78)
        return -1000;
        // Some of these are used twice, so rather than computing them twice in the algorithem we precompute them before hand.
      float cosRoll = cos(roll);
      float sinRoll = sin(roll);
      float cosPitch = cos(pitch);
      float sinPitch = sin(pitch);
      float Xh = mag.XAxis * cosPitch + mag.ZAxis * sinPitch;
      float Yh = mag.XAxis * sinRoll * sinPitch + mag.YAxis * cosRoll - mag.ZAxis * sinRoll * cosPitch;
      float heading = atan2(Yh, Xh);
      return heading;
    // Correct angle
    float correctAngle(float heading)
      if (heading < 0) { heading += 2 * PI; }
      if (heading > 2 * PI) { heading -= 2 * PI; }
      return heading;
      // Read vectors
      Vector mag = compass.readNormalize();
      Vector acc = mpu.readScaledAccel();
      // Calculate headings
      heading1 = noTiltCompensate(mag);
      heading2 = tiltCompensate(mag, acc);
      if (heading2 == -1000)
        heading2 = heading1;
      // Set declination angle on your location and fix heading
      // You can find your declination on: http://magnetic-declination.com/
      // (+) Positive or (-) for negative
      // For Bytom / Poland declination angle is 4'26E (positive)
      // Formula: (deg + (min / 60.0)) / (180 / M_PI);
      float declinationAngle = (4.0 + (26.0 / 60.0)) / (180 / M_PI);
      heading1 += declinationAngle;
      heading2 += declinationAngle;
      // Correct for heading < 0deg and heading > 360deg
      heading1 = correctAngle(heading1);
      heading2 = correctAngle(heading2);
      // Convert to degrees
      heading1 = heading1 * 180/M_PI;
      heading2 = heading2 * 180/M_PI;
      // Output
      Serial.print(heading1);
      Serial.print(":");
      Serial.println(heading2);
      delay(100);
    не компилируется зависает на строке инициализации while(!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
    В чем может быть проблема? Скетч полезный может еще кому пригодится)))
  2. ToxaRU
    ToxaRU Гик
    Проблема решена .
