Тупик с переменными и данными локализации
Тема в разделе "Arduino & Shields", создана пользователем SirSaaryan, 21 янв 2016.
  1. SirSaaryan
    SirSaaryan Нуб
    АААА, хочу сделать локализацию. Помогите, код расскомментировал
    Arduino: 1.6.5 (Mac OS X), Плата"Arduino/Genuino Uno"
    sketch_jan21a:6: error: 'tempEn' does not name a type
    sketch_jan21a:7: error: 'pressEn' does not name a type
    sketch_jan21a:8: error: 'altEn' does not name a type
    sketch_jan21a:9: error: 'tempRu' does not name a type
    sketch_jan21a:10: error: 'pressRu' does not name a type
    sketch_jan21a:11: error: 'altRu' does not name a type
    sketch_jan21a.ino: In function 'void loop()':
    sketch_jan21a:32: error: 'temp' was not declared in this scope
    sketch_jan21a:32: error: 'tempRu' was not declared in this scope
    sketch_jan21a:33: error: 'press' was not declared in this scope
    sketch_jan21a:33: error: 'pressRu' was not declared in this scope
    sketch_jan21a:34: error: 'alt' was not declared in this scope
    sketch_jan21a:34: error: 'altRu' was not declared in this scope
    sketch_jan21a:38: error: 'temp' was not declared in this scope
    sketch_jan21a:38: error: 'tempEn' was not declared in this scope
    sketch_jan21a:39: error: 'press' was not declared in this scope
    sketch_jan21a:39: error: 'pressEn' was not declared in this scope
    sketch_jan21a:40: error: 'alt' was not declared in this scope
    sketch_jan21a:40: error: 'altEn' was not declared in this scope
    sketch_jan21a:54: error: 'temp' was not declared in this scope
    sketch_jan21a:60: error: 'press' was not declared in this scope
    sketch_jan21a:66: error: 'alt' was not declared in this scope
    sketch_jan21a.ino: At global scope:
    sketch_jan21a:83: error: 'tempEn' does not name a type
    sketch_jan21a:84: error: 'pressEn' does not name a type
    sketch_jan21a:85: error: 'altEn' does not name a type
    sketch_jan21a:86: error: 'tempRu' does not name a type
    sketch_jan21a:87: error: 'pressRu' does not name a type
    sketch_jan21a:88: error: 'altRu' does not name a type
    sketch_jan21a:93: error: redefinition of 'Adafruit_BMP085 bmp'
    sketch_jan21a:16: error: 'Adafruit_BMP085 bmp' previously declared here
    sketch_jan21a:94: error: redefinition of 'LiquidCrystal lcd'
    sketch_jan21a:17: error: 'LiquidCrystal lcd' previously declared here
    sketch_jan21a:95: error: redefinition of 'int analogPin'
    sketch_jan21a:18: error: 'int analogPin' previously defined here
    sketch_jan21a:96: error: redefinition of 'int val'
    sketch_jan21a:19: error: 'int val' previously defined here
    sketch_jan21a:97: error: redefinition of 'int menu'
    sketch_jan21a:20: error: 'int menu' previously defined here
    sketch_jan21a:98: error: redefinition of 'int lang'
    sketch_jan21a:21: error: 'int lang' previously defined here
    sketch_jan21a.ino: In function 'void setup()':
    sketch_jan21a:99: error: redefinition of 'void setup()'
    sketch_jan21a:22: error: 'void setup()' previously defined here
    sketch_jan21a:106: error: redefinition of 'void loop()'
    sketch_jan21a:29: error: 'void loop()' previously defined here
    sketch_jan21a:109: error: 'temp' was not declared in this scope
    sketch_jan21a:109: error: 'tempRu' was not declared in this scope
    sketch_jan21a:110: error: 'press' was not declared in this scope
    sketch_jan21a:110: error: 'pressRu' was not declared in this scope
    sketch_jan21a:111: error: 'alt' was not declared in this scope
    sketch_jan21a:111: error: 'altRu' was not declared in this scope
    sketch_jan21a:115: error: 'temp' was not declared in this scope
    sketch_jan21a:115: error: 'tempEn' was not declared in this scope
    sketch_jan21a:116: error: 'press' was not declared in this scope
    sketch_jan21a:116: error: 'pressEn' was not declared in this scope
    sketch_jan21a:117: error: 'alt' was not declared in this scope
    sketch_jan21a:117: error: 'altEn' was not declared in this scope
    sketch_jan21a:131: error: 'temp' was not declared in this scope
    sketch_jan21a:137: error: 'press' was not declared in this scope
    sketch_jan21a:143: error: 'alt' was not declared in this scope
    Multiple libraries were found for "LiquidCrystalRus.h"
    Used: /Users/SirSaaryan/Documents/Arduino/libraries/LiquidCrystalRus-master
    Not used: /Users/SirSaaryan/Documents/Arduino/libraries/RoboCraft-LiquidCrystalRus-ce8603e
    Это сообщение будет содержать больше информации чем
    "Отображать вывод во время компиляции"
    включено в Файл > Настройки
    // Meteostation with working menu
    // Menu is working via potentiometr
    // I've lost my DHT22, so now I use BMP180
    // Narek Saaryan
    // 20.12.2016
    tempEn = "Temp.= ";
    pressEn = "Pres.= ";
    altEn = "Alt.= ";
    tempRu = "Темп.= ";
    pressRu = "Давл.= ";
    altRu = "Выс.= ";
    #include <LiquidCrystal.h>
    #include <Wire.h>
    #include "Adafruit_BMP085.h"
    #include <LiquidCrystalRus.h>
    Adafruit_BMP085 bmp;
    LiquidCrystal lcd(4, 5, 10, 11, 12, 13);
    int analogPin = 0;
    int val = 0;
    int menu = 0;
    int lang = 0; //English
    lcd.begin(16, 2);
    if (!bmp.begin()) {
      lcd.println("404");
      while (1) {}
       if (lang == 1)
        temp = tempRu;
        press = pressRu;
        alt = altRu;
       else
        temp = tempEn;
        press = pressEn;
        alt = altEn;
       val = analogRead(analogPin); //обозначаем вход потенциометра
       if (val <= 1024 && val >= 751) //Тут мы показываем
       menu = 0;                     //При каких значениях
       if (val <= 750 && val >= 501)  //Потенциометра
       menu = 1;                      //Нужно открывать
       if (val <= 500 && val >= 251)  //Какое меню
       menu = 2;                      // С помощью присвоения
       if (val < 250)                 //Числа переменой меню
       menu = 3;
       switch (menu) {
        case 0:
        lcd.clear();
        lcd.print(temp);
        lcd.print(bmp.readTemperature());
        lcd.println(" *C  ");
        break;
        case 1:
        lcd.clear();
        lcd.print(press);
        lcd.print(bmp.readPressure());
        lcd.println(" Pa");
        break;
        case 2:
        lcd.clear();
        lcd.print(alt);
        lcd.print(bmp.readAltitude(100525));
        lcd.println(" m.  ");
        break;
        case 3:
        lcd.clear();
        lcd.print("Settings");
        lcd.setCursor(0, 1);
        lcd.print("Coming soon");
        break;
       delay(1000);
  2. Mestniy
    Mestniy Гуру
    Попробуй....
    // Narek Saaryan
    // 20.12.2016
    String tempEn = "Temp.= ";
    String pressEn = "Pres.= ";
    String altEn = "Alt.= ";
    String tempRu = "Темп.= ";
    String pressRu = "Давл.= ";
    String altRu = "Выс.= ";
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    int analogPin = 0;
    int val = 0;
    int menu = 0;
    lcd.begin(16, 2);
    if (!bmp.begin()) {
      lcd.println("404");
      while (1) {}
       if (lang == 1)
        temp = tempRu;
        press = pressRu;
        alt = altRu;
       else
        temp = tempEn;
        press = pressEn;
        alt = altEn;
       menu = 3;
       switch (menu) {
        case 0:
        lcd.clear();
        lcd.print(temp);
        break;
        case 1:
        lcd.clear();
        lcd.print(press);
        lcd.println(" Pa");
        break;
        case 2:
        lcd.clear();
        lcd.print(alt);
        break;
        case 3:
        lcd.clear();
        break;
       delay(1000);
    SirSaaryan нравится это.
  3. Mestniy
    Mestniy Гуру
    Adafruit_BMP085.h- это че за библиотека?
  4. SirSaaryan
    SirSaaryan Нуб
    Дружище, вот! BMP -- датчик температуры и давления! Отличная вещь и по приемлемой цене. У меня 180, но по 85 работает!
    Эхх, а у меня вот еще ошибочки полезли! Я вижу ты гик, можешь помочь? Предыдущие ошибки ушли, новые пришли. Я эти переменные как-то должен объявить в цикле? Если да, то как?
    // Narek Saaryan
    // 20.12.2016
    #include <Wire.h>
    int analogPin = 0;
    int val = 0;
    int menu = 0;
    lcd.begin(16, 2);
    if (!bmp.begin()) {
      lcd.println("404");
      while (1) {}
       if (lang == 1)
        temp = tempRu;
        press = pressRu;
        alt = altRu;
       else
        temp = tempEn;
        press = pressEn;
        alt = altEn;
       menu = 3;
       switch (menu) {
        case 0:
        lcd.clear();
        lcd.print(temp);
        break;
        case 1:
        lcd.clear();
        lcd.print(press);
        lcd.println(" Pa");
        break;
        case 2:
        lcd.clear();
        lcd.print(alt);
        break;
        case 3:
        lcd.clear();
        break;
       delay(1000);
  5. SirSaaryan
    SirSaaryan Нуб
  6. AlexU
    AlexU Гуру
    В ошибках прозрачно указано, что не объявлены переменные 'temp', 'press', 'alt', используемые в коде.
    Но я бы Вам посоветовал немного оптимизировать код, например:
    код:
    заменить на:
    String temp[] = { String("Temp.= "), String("Темп.= ") };
    String press[] = { String("Pres.= "), String("Давл.= ") };
    String alt[] = { String("Alt.= "), String("Выс.= ") };
    убрать из кода условие (оно становиться не нужным):
       if (lang == 1)
         temp = tempRu;
         press = pressRu;
         alt = altRu;
        else
         temp = tempEn;
         press = pressEn;
         alt = altEn;
    код вывода строк 'lcd.print(temp);' и т.п. заменить на:
    lcd.print(temp[lang]);
    lcd.print(press[lang]);
    lcd.print(alt[lang]);
    Можно вместо String использовать C-строки:
     char *temp[] = { "Temp.= ", "Темп.= " };
    char *press[] = { "Pres.= ", "Давл.= " };
    char *alt[] = { "Alt.= ", "Выс.= " };
    PS: UP ещё раз ;)
  7. SirSaaryan
    SirSaaryan Нуб
    Спасибо огромнюшее! Спасли мини-проект начинающего ардуинщика от провала! За оптимизацию отдельное спасибо):):):)
  8. AlexU
    AlexU Гуру
    Жду ответной помощи. В стартовом топике в коде указано подключение заголовочного файла: #include <LiquidCrystalRus.h>.
    Где взяли библиотеку LiquidCrystalRus?
  9. AlexU
    AlexU Гуру
    Спасибо!
  10. SirSaaryan
    SirSaaryan Нуб
    Вот, пожалуйста!
    Ссылочка на статейку!
    #include <LineDriver.h>
    #include <LiquidCrystalExt.h>
    LiquidCrystalRus lcd(12, 11, 5, 4, 3, 2);
      lcd.begin(16, 2);
      lcd.print("Здравствуй, мир!");
      lcd.print(millis() / 1000);
    Пример фотографии с экранчиком.
    Была более старая (оригинальная) версия ликвида для кириллицы. Автор статьи её обновил
  11. AlexVS
    AlexVS Гик
    Блин, если вы не знаете даже того, что необходимо объявлять переменные, как вы собираетесь программировать?
  12. SirSaaryan
    SirSaaryan Нуб
    Аналогично фразе: "Блин, если вы не знаете даже того, что на нуль делить нельзя из-за непересечения прямых с точкой 0;0;", сказанной пятикласснику.
  13. SirSaaryan
    SirSaaryan Нуб
    и ошибка была не в том, что я не обьявил переменную, а в том, что я её неправильно объявил. Луркмоар эту тему
  14. AlexVS
    AlexVS Гик
    Пятиклассники получают знания не на форумах.
    sketch_jan21a:32: error: 'temp' was not declared in this scope - Переменная не объявлена
  15. Mestniy
    Mestniy Гуру
    У всех корректно библиотека LiquidCrystalRus.h работает? Пользуюсь Mega и LCD 2004. Делаю все как в ссылке, но пишет, так будто никакой библиотеки нет(каракули).
    http://robocraft.ru/blog/arduino/503.html
  16. AlexU
    AlexU Гуру
    Используемый LCD 2004 кириллицу поддерживает? Это первый вопрос. А второй: LiquidCrystalRus.h поддерживает только кодировку UTF-8, в какой кодировке "русские" строки хранятся в прошивке?
    Mestniy нравится это.
  17. Mestniy
    Mestniy Гуру
    Ясно. Спасибо. Но может кто пробовал подключать?
  18. SirSaaryan
    SirSaaryan Нуб
    при появлении в образовательной программе "программирования", обязательно похожу. А пока, форум -- второй дом
