Доброго всего. Кто имел удачный опыт с уведомлениями через pushbullet.com откликнитесь поделитесь рабочим скетчем , плиз, для Nodemcu (8266) Стандартный пример библиотеки PushBullet.h выдает: exit status 1 Ошибка компиляции для платы NodeMCU 1.0 (ESP-12E Module). Код (C++): #include <ESP8266WiFi.h> #include <PushBullet.h> #include <WiFiClientSecure.h> WiFiClientSecure client; #define PORT 443 // wifi connection variables const char* ssid = ""; const char* password = ""; boolean wifiConnected = false; int incomingByte = 0; boolean connectWifi(); PushBullet pb = PushBullet("API", &client, 443); void setup() { // Initialise Serial connection Serial.begin(115200); // Initialise wifi connection wifiConnected = connectWifi(); if (!pb.checkConnection()) { Serial.println("Failed to connect to pushbullet.com"); return; } } void loop() { // check if the WiFi connection were successful if (wifiConnected) { if (Serial.available() > 0) { // read the incoming byte: incomingByte = Serial.read(); switch (incomingByte) { case 'l': Serial.println("Pushbullet link pushing"); pb.sendLinkPush("Hello, from google", "Google", "http://google.nl"); delay(5000); break; case 'n': Serial.println("Pushbullet note pushing"); pb.sendNotePush("Hello, from me", "Message"); delay(5000); break; case 'c': Serial.println("Pushbullet coping clipboard pushing"); pb.copyToClipboard("Hello from above our magnificent planet Earth."); delay(5000); break; case 's': Serial.println("Pushbullet sending sms"); pb.sendSMSPush("This is an SMS from the ESP8266", "+00000", "TARGET", "USER"); delay(5000); break; } } } } // connect to wifi – returns true if successful or false if not boolean connectWifi() { boolean state = true; int i = 0; WiFi.begin(ssid, password); Serial.println(""); Serial.println("Connecting to WiFi"); // Wait for connection Serial.print("Connecting"); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); if (i > 10) { state = false; break; } i++; } if (state) { Serial.println(""); Serial.print("Connected to "); Serial.println(ssid); Serial.print("IP address: "); Serial.println(WiFi.localIP()); } else { Serial.println(""); Serial.println("Connection failed."); } return state; }
