Arduino: 1.8.1 (Windows XP), Плата:"Arduino/Genuino Uno" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Богдан\Мои документы\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Documents and Settings\Богдан\Мои документы\Downloads\compassCalibrationMatrix\compassCalibrationMatrix.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Богдан\Мои документы\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Documents and Settings\Богдан\Мои документы\Downloads\compassCalibrationMatrix\compassCalibrationMatrix.ino Using board 'uno' from platform in folder: C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19 Using core 'arduino' from platform in folder: C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19 Detecting libraries used... "C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\standard" "C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776\sketch\compassCalibrationMatrix.ino.cpp" -o "nul" "C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\standard" "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src" "C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776\sketch\compassCalibrationMatrix.ino.cpp" -o "nul" "C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\standard" "-IC:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src" "C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776\sketch\compassCalibrationMatrix.ino.cpp" -o "C:\DOCUME~1\625D~1\LOCALS~1\Temp\arduino_build_151776\preproc\ctags_target_for_gcc_minus_e.cpp" C:\Documents and Settings\Богдан\РњРѕРё документы\Downloads\compassCalibrationMatrix\compassCalibrationMatrix.ino:8:23: fatal error: TroykaIMU.h: No such file or directory compilation terminated. Используем библиотеку Wire версии 1.0 из папки: C:\Documents and Settings\Богдан\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\Wire exit status 1 Ошибка компиляции для платы Arduino/Genuino Uno.
Прошу прощения.... а что с путями? Может в конфигурации... я под Linux... но что-то не то. Не используйте пути с кирилицей - это первое!
И вообще windows это операционная система... или только продвинутая оболочка (с дырками и вирусами) для MSDOS? Я знавал OS/2 совсем почти не убиваема! Но тут....
Помогите!!! Arduino: 1.8.4 (Windows 10), Плата:"Arduino/Genuino Uno" D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -built-in-libraries D:\Arduino\libraries -libraries C:\Users\K751SJ-TY049T\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10804 -build-path C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990 -warnings=more -build-cache C:\Users\K751SJ~1\AppData\Local\Temp\arduino_cache_864213 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -verbose C:\Users\K751SJ~1\AppData\Local\Temp\arduino_modified_sketch_678490\sketch_dec13a.ino D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -built-in-libraries D:\Arduino\libraries -libraries C:\Users\K751SJ-TY049T\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10804 -build-path C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990 -warnings=more -build-cache C:\Users\K751SJ~1\AppData\Local\Temp\arduino_cache_864213 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -verbose C:\Users\K751SJ~1\AppData\Local\Temp\arduino_modified_sketch_678490\sketch_dec13a.ino Using board 'uno' from platform in folder: D:\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: D:\Arduino\hardware\arduino\avr Detecting libraries used... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\sketch\sketch_dec13a.ino.cpp" -o "nul" "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Arduino\libraries\LiquidCrystal\src" "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\sketch\sketch_dec13a.ino.cpp" -o "nul" "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Arduino\libraries\LiquidCrystal\src" "D:\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp" -o "nul" Generating function prototypes... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Arduino\libraries\LiquidCrystal\src" "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\sketch\sketch_dec13a.ino.cpp" -o "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\preproc\ctags_target_for_gcc_minus_e.cpp" "D:\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\preproc\ctags_target_for_gcc_minus_e.cpp" Компиляция скетча... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Arduino\libraries\LiquidCrystal\src" "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\sketch\sketch_dec13a.ino.cpp" -o "C:\Users\K751SJ~1\AppData\Local\Temp\arduino_build_376990\sketch\sketch_dec13a.ino.cpp.o" sketch_dec13a:5: error: variable or field 'setup' declared void void setup(1) ^ sketch_dec13a:10: error: variable or field 'loop' declared void void loop(1) ^ Используем библиотеку LiquidCrystal версии 1.0.7 из папки: D:\Arduino\libraries\LiquidCrystal exit status 1 variable or field 'setup' declared void
