поправить код - платформа turtle
Тема в разделе "Arduino & Shields", создана пользователем Максим B, 6 июл 2015.
  1. Максим B
    Максим B Гуру
    Есть такой код:
    #include <IRremote.h>
    int RECV_PIN = 13;
    int pinLB=6;//定义I1接口
    int pinLF=9;//定义I2接口
    int pinRB=3;//定义I3接口
    int pinRF=5;//定义I4接口
    long advence = 0xFF629D;
    long back = 0xFFA857;
    long stop = 0xFF02FD;
    long left = 0xFF22DD;
    long right = 0xFFC23D;
    IRrecv irrecv(RECV_PIN);
    decode_results results;
    void dump(decode_results *results) {
      int count = results->rawlen;
      if (results->decode_type == UNKNOWN)
         Serial.println("Could not decode message");
      else
        if (results->decode_type == NEC)
           Serial.print("Decoded NEC: ");
        else if (results->decode_type == SONY)
           Serial.print("Decoded SONY: ");
        else if (results->decode_type == RC5)
           Serial.print("Decoded RC5: ");
        else if (results->decode_type == RC6)
           Serial.print("Decoded RC6: ");
         Serial.print(results->value, HEX);
         Serial.print(" (");
         Serial.print(results->bits, DEC);
         Serial.println(" bits)");
         Serial.print("Raw (");
         Serial.print(count, DEC);
         Serial.print("): ");
      for (int i = 0; i < count; i++)
          if ((i % 2) == 1) {
          Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
        else
          Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
        Serial.print(" ");
          Serial.println("");
      pinMode(RECV_PIN, INPUT);
      pinMode(pinLB,OUTPUT);
      pinMode(pinLF,OUTPUT);
      pinMode(pinRB,OUTPUT);
      pinMode(pinRF,OUTPUT);
      irrecv.enableIRIn(); // Start the receiver
    int on = 0;
    unsigned long last = millis();
      if (irrecv.decode(&results))
        // If it's been at least 1/4 second since the last
        // IR received, toggle the relay
        if (millis() - last > 250)
           on = !on;
    //       digitalWrite(8, on ? HIGH : LOW);
           digitalWrite(13, on ? HIGH : LOW);
           dump(&results);
        if (results.value == advence )
        {digitalWrite(pinRB,LOW);//使直流电机(右)GO
        digitalWrite(pinRF,HIGH);
        digitalWrite(pinLB,LOW);//使直流电机(左)GO
        digitalWrite(pinLF,HIGH);}
        if (results.value == back )
         {digitalWrite(pinRB,HIGH);//使直流电机(右)BACK
         digitalWrite(pinRF,LOW);}
        if (results.value == left )
        { digitalWrite(pinRB,LOW);//使直流电机(右) STOP
         digitalWrite(pinLB,HIGH);//使直流电机(左)GO
         digitalWrite(pinLF,LOW);}
        if (results.value == right )
        { digitalWrite(pinRB,HIGH);//使直流电机(右)GO
         digitalWrite(pinLB,HIGH);//使直流电机(左)STOP
        if (results.value == stop )
         digitalWrite(pinRB,HIGH);//使直流电机(右)STOP
        last = millis();
        irrecv.resume(); // Receive the next value
    Робот не хочет поворачивать нормально ни влево, ни вправо - в чем причина?
  2. Максим B
    Максим B Гуру
    Все разобарлся. Оставлю это здесь.
    int RECV_PIN = 13;
    int pinLB=3;//定义I1接口
    int pinLF=2;//定义I2接口
    int pinRB=5;//定义I3接口
    int pinRF=4;//定义I4接口
      else
         Serial.print(" (");
          if ((i % 2) == 1) {
        else
        Serial.print(" ");
          Serial.println("");
    int on = 0;
           on = !on;
           dump(&results);
         digitalWrite(pinLB,LOW);//使直流电机(左)STOP
        last = millis();
  3. Максим B
    Максим B Гуру
    Только почему с одной стороны моторчик крутиться быстрее чем с другой??? Моторчик менял на заведомо исправный .
