Код (Text): #include #define PING_client static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x25}; static uint8_t myip[4] = { 172,16,100,25 }; static uint8_t pcip[4] = { 172,16,100,2 }; static uint8_t gwip[4] = { 172,16,100,1 }; static uint8_t fooip[4] = { 172,16,100,100 }; //unavailable pc. simulating a offline pc #define BUFFER_SIZE 700 static uint32_t timer,count; static uint8_t buf[BUFFER_SIZE+1]; int state=0; EtherShield es=EtherShield(); void setup(){ Serial.begin(19200); // Initialise SPI interface es.ES_enc28j60SpiInit(); // initialize enc28j60 es.ES_enc28j60Init(mymac); // init the ethernet/ip layer: es.ES_init_ip_arp_udp_tcp(mymac,myip,80); Serial.println("Starting"); delay(3000); } // Output a ip address from buffer from startByte void printIP( uint8_t *buf ) { for( int i = 0; i < 4; i++ ) { Serial.print( buf[i], DEC ); if( i<3 ) Serial.print( "." ); } } void printHex( uint8_t hexval ) { if( hexval < 16 ) { Serial.print("0"); } Serial.print( hexval, HEX ); Serial.print( " " ); timer = -9999999; // start timing out right away } void loop(){ pinMode(14, OUTPUT); // sets the digital pin as output pinMode(15, OUTPUT); // sets the digital pin as output digitalWrite(14,HIGH); digitalWrite(15,LOW); ping(pcip); ping(gwip); ping(fooip); } void ping(uint8_t *remIP){ uint32_t endtime,dat_p; uint16_t timeout=5000; //timeout ping after 2seconds endtime=millis(); //send an arp request to get the mac address of teh remoteIP // Serial.print("Senidng ARP Request to ");printIP(remIP);Serial.println(); es.ES_client_set_gwip(remIP); while(1){ if(millis()-endtime>=timeout){Serial.print("Timeout Waitin for Ping Reply ");Serial.print(endtime);Serial.println();state=0;break;}//timeout ping int plen=es.ES_enc28j60PacketReceive(BUFFER_SIZE,buf); dat_p=es.ES_packetloop_icmp_tcp(buf,plen); if(dat_p==0) { // we are idle here if (es.ES_client_waiting_gw() ){ continue; } } // if (!es.ES_client_waiting_gw() ){Serial.println("Got ARP Reply");state=1;break;} // report whenever a reply to our outgoing ping comes back if (plen > 0 && es.ES_packetloop_icmp_checkreply(buf,remIP)) { Serial.print(" "); Serial.print((micros() - timer) * 0.001, 3); Serial.println(" ms"); state=1;break; } if (micros() - timer >= 1000000) { //ping every 1 second Serial.print(count); Serial.print(". Pinging: "); printIP(remIP); Serial.print("-->"); timer = micros(); es.ES_client_icmp_request(buf,remIP); count++; } } } это оригинальный код, взятый с сайта. По логике добавил #include "EtherShield.h" При компеляции вылетает ошибка EtherShield_broadcast.pde: In function 'void ping(uint8_t*)': EtherShield_broadcast:85: error: 'class EtherShield' has no member named 'ES_packetloop_icmp_checkreply' EtherShield_broadcast:97: error: 'class EtherShield' has no member named 'ES_client_icmp_request' ES_packetloop_icmp_checkreply в EtherShield.h есть... Вроде как подсказывали, что проблема , где стоит в определение PING_client. И где - подключение библиотеки EtherShield.h НО не могу понять, что не так... Подскажите, кто может ) спасибо!
Код (Text): /* EHTERSHIELD_H library for Arduino etherShield Copyright (c) 2008 Xing Yu. All right reserved. This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details. You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */ #ifndef ETHERSHIELD_H #define ETHERSHIELD_H #include <inttypes.h> #include "ip_config.h" #include "enc28j60.h" #include "ip_arp_udp_tcp.h" #include "net.h" class EtherShield { public: EtherShield(); void ES_enc28j60SpiInit( void ); void ES_enc28j60Init( uint8_t* macaddr); void ES_enc28j60Init( uint8_t* macaddr, uint8_t csPin ); void ES_enc28j60clkout(uint8_t clk); uint8_t ES_enc28j60linkup(void); void ES_enc28j60PhyWrite(uint8_t address, uint16_t data); uint16_t ES_enc28j60PacketReceive(uint16_t len, uint8_t* packet); void ES_enc28j60PacketSend(uint16_t len, uint8_t* packet); uint8_t ES_enc28j60Revision(void); uint8_t ES_enc28j60Read( uint8_t address ); void ES_enc28j60EnableBroadcast( void ); void ES_enc28j60DisableBroadcast( void ); void ES_enc28j60EnableMulticast( void ); void ES_enc28j60DisableMulticast( void ); void ES_enc28j60PowerUp(); void ES_enc28j60PowerDown(); void ES_init_ip_arp_udp_tcp(uint8_t *mymac,uint8_t *myip,uint16_t port); // for a UDP server: uint8_t ES_eth_type_is_arp_and_my_ip(uint8_t *buf,uint16_t len); uint8_t ES_eth_type_is_ip_and_my_ip(uint8_t *buf,uint16_t len); void ES_make_echo_reply_from_request(uint8_t *buf,uint16_t len); void ES_make_tcp_synack_from_syn(uint8_t *buf); void ES_make_tcp_ack_from_any(uint8_t *buf,int16_t datlentoack,uint8_t addflags); void ES_make_tcp_ack_with_data(uint8_t *buf,uint16_t dlen); void ES_make_tcp_ack_with_data_noflags(uint8_t *buf,uint16_t dlen); void ES_init_len_info(uint8_t *buf); uint16_t ES_get_tcp_data_pointer(void); uint16_t ES_build_tcp_data(uint8_t *buf, uint16_t srcPort ); void ES_send_tcp_data(uint8_t *buf,uint16_t dlen ); // UDP - dirkx void ES_send_udp_data(uint8_t *buf,uint16_t dlen,uint16_t source_port, uint8_t *dest_ip, uint16_t dest_port); void ES_send_udp_data(uint8_t *buf, uint8_t *destmac,uint16_t dlen,uint16_t source_port, uint8_t *dest_ip, uint16_t dest_port); void ES_fill_buf_p(uint8_t *buf,uint16_t len, const prog_char *progmem_s); uint16_t ES_checksum(uint8_t *buf, uint16_t len,uint8_t type); void ES_fill_ip_hdr_checksum(uint8_t *buf); // return 0 to just continue in the packet loop and return the position // of the tcp data if there is tcp data part uint16_t ES_packetloop_icmp_tcp(uint8_t *buf,uint16_t plen); // functions to fill the web pages with data: uint16_t ES_fill_tcp_data_p(uint8_t *buf,uint16_t pos, const prog_char *progmem_s); uint16_t ES_fill_tcp_data(uint8_t *buf,uint16_t pos, const char *s); uint16_t ES_fill_tcp_data_len(uint8_t *buf,uint16_t pos, const char *s, uint16_t len ); // send data from the web server to the client: void ES_www_server_reply(uint8_t *buf,uint16_t dlen); // -- client functions -- uint8_t ES_client_store_gw_mac(uint8_t *buf); //, uint8_t *gwipaddr); void ES_client_set_gwip(uint8_t *gwipaddr); void ES_client_set_wwwip(uint8_t *wwwipaddr); void ES_client_tcp_set_serverip(uint8_t *ipaddr); void ES_client_arp_whohas(uint8_t *buf,uint8_t *ip_we_search); uint8_t ES_client_waiting_gw( void ); #if defined (TCP_client) || defined (WWW_client) || defined (NTP_client) uint8_t ES_client_tcp_req(uint8_t (*result_callback)(uint8_t fd,uint8_t statuscode,uint16_t data_start_pos_in_buf, uint16_t len_of_data),uint16_t (*datafill_callback)(uint8_t fd),uint16_t port ); void ES_tcp_client_send_packet(uint8_t *buf,uint16_t dest_port, uint16_t src_port, uint8_t flags, uint8_t max_segment_size, uint8_t clear_seqck, uint16_t next_ack_num, uint16_t dlength, uint8_t *dest_mac, uint8_t *dest_ip); uint16_t ES_tcp_get_dlength( uint8_t *buf ); #endif #ifdef DNS_client uint8_t ES_dnslkup_haveanswer(void); uint8_t ES_dnslkup_get_error_info(void); uint8_t *ES_dnslkup_getip( void ); void ES_dnslkup_set_dnsip(uint8_t *dnsipaddr); void ES_dnslkup_request(uint8_t *buf, uint8_t *hoststr ); uint8_t ES_udp_client_check_for_dns_answer(uint8_t *buf,uint16_t plen); uint8_t resolveHostname(uint8_t *buf, uint16_t buffer_size, uint8_t *hostname ); #endif #ifdef DHCP_client uint8_t ES_dhcp_state(void); void ES_dhcp_start(uint8_t *buf, uint8_t *macaddrin, uint8_t *ipaddrin, uint8_t *maskin, uint8_t *gwipin, uint8_t *dhcpsvrin, uint8_t *dnssvrin ); uint8_t ES_check_for_dhcp_answer(uint8_t *buf,uint16_t plen); uint8_t allocateIPAddress(uint8_t *buf, uint16_t buffer_size, uint8_t *mymac, uint16_t myport, uint8_t *myip, uint8_t *mynetmask, uint8_t *gwip, uint8_t *dnsip, uint8_t *dhcpsvrip ); #endif #define HTTP_HEADER_START ((uint16_t)TCP_SRC_PORT_H_P+(buf[TCP_HEADER_LEN_P]>>4)*4) #ifdef WWW_client // ----- http get #ifdef FLASH_VARS void ES_client_browse_url(prog_char *urlbuf, char *urlbuf_varpart, prog_char *hoststr, void (*callback)(uint8_t,uint16_t,uint16_t)); #else void ES_client_browse_url(char *urlbuf, char *urlbuf_varpart, char *hoststr, void (*callback)(uint8_t,uint16_t,uint16_t)); #endif // The callback is a reference to a function which must look like this: // void browserresult_callback(uint8_t statuscode,uint16_t datapos) // statuscode=0 means a good webpage was received, with http code 200 OK // statuscode=1 an http error was received // statuscode=2 means the other side in not a web server and in this case datapos is also zero // ----- http post // client web browser using http POST operation: // additionalheaderline must be set to NULL if not used. // method should be used if default POST to be overridden set NULL for dfault // postval is a string buffer which can only be de-allocated by the caller // when the post operation was really done (e.g when callback was executed). // postval must be urlencoded. #ifdef FLASH_VARS void ES_client_http_post(prog_char *urlbuf, prog_char *hoststr, prog_char *additionalheaderline, prog_char *method, char *postval,void (*callback)(uint8_t,uint16_t)); #else void ES_client_http_post(char *urlbuf, char *hoststr, char *additionalheaderline, char *method, char *postval,void (*callback)(uint8_t,uint16_t)); #endif // The callback is a reference to a function which must look like this: // void browserresult_callback(uint8_t statuscode,uint16_t datapos) // statuscode=0 means a good webpage was received, with http code 200 OK // statuscode=1 an http error was received // statuscode=2 means the other side in not a web server and in this case datapos is also zero #endif // WWW_client #ifdef NTP_client void ES_client_ntp_request(uint8_t *buf,uint8_t *ntpip,uint8_t srcport); uint8_t ES_client_ntp_process_answer(uint8_t *buf,uint32_t *time,uint8_t dstport_l); #endif // NTP_client // you can find out who ping-ed you if you want: void ES_register_ping_rec_callback(void (*callback)(uint8_t *srcip)); #ifdef PING_client void ES_client_icmp_request(uint8_t *buf,uint8_t *destip); // you must loop over this function to check if there was a ping reply: uint8_t ES_packetloop_icmp_checkreply(uint8_t *buf,uint8_t *ip_monitoredhost); #endif // PING_client #ifdef WOL_client void ES_send_wol(uint8_t *buf,uint8_t *wolmac); #endif // WOL_client #ifdef FROMDECODE_websrv_help uint8_t ES_find_key_val(char *str,char *strbuf, uint16_t maxlen,char *key); void ES_urldecode(char *urlbuf); #endif // FROMDECODE_websrv_help #ifdef URLENCODE_websrv_help void ES_urlencode(char *str,char *urlbuf); #endif // URLENCODE_websrv_help uint8_t ES_parse_ip(uint8_t *bytestr,char *str); void ES_mk_net_str(char *resultstr,uint8_t *bytestr,uint16_t len,char separator,uint8_t base); uint8_t ES_nextTcpState( uint8_t *buf,uint16_t plen ); uint8_t ES_currentTcpState( ); uint8_t ES_tcpActiveOpen( uint8_t *buf,uint16_t plen, uint8_t (*result_callback)(uint8_t fd,uint8_t statuscode,uint16_t data_start_pos_in_buf, uint16_t len_of_data),uint16_t (*datafill_callback)(uint8_t fd),uint16_t port ); void ES_tcpPassiveOpen( uint8_t *buf,uint16_t plen ); void ES_tcpClose( uint8_t *buf,uint16_t plen ); }; #endif
Спасибо, но как то не очень помогает. Ещё раз для ясности: мне нужно #include "EtherShield.h" перед #define PING_client ? как то не очень помогает. Прикладываю архив с библиотекой.
Хотя это тоже неверно. Макрос нужно определять либо в опциях проекта, которые передаются непосредственно компилятору (Arduino IDE это не позволяет, насколько мне известно), либо тогда в самом EtherShield.h . Иначе при компиляции EtherShield.cpp будут другие ошибки.
Код (Text): #ifdef PING_client void ES_client_icmp_request(uint8_t *buf,uint8_t *destip); // you must loop over this function to check if there was a ping reply: uint8_t ES_packetloop_icmp_checkreply(uint8_t *buf,uint8_t *ip_monitoredhost); #endif // PING_client кусок из EtherShield.h значит оно тут есть?
Да, но то только если макрос PING_client определен до соответствующего #ifdef, иначе весь кусок от #ifdef до #endif игнорируется.
Определить макрос. До того момента, как он используется в коде. Т.е. написать "#define PING_client" в заголовочном файле, который гарантированно включается во все файлы, где есть соответствующий #ifdef.
прописал во всех файла .h где нашел упоминание PING_client. Теперь вот такая ошибка: EtherShield\EtherShield.cpp.o: In function `EtherShield::ES_packetloop_icmp_checkreply(unsigned char*, unsigned char*)': C:\Program Files (x86)\Arduino\libraries\EtherShield/EtherShield.cpp:344: undefined reference to `packetloop_icmp_checkreply' EtherShield\EtherShield.cpp.o: In function `EtherShield::ES_client_icmp_request(unsigned char*, unsigned char*)': C:\Program Files (x86)\Arduino\libraries\EtherShield/EtherShield.cpp:340: undefined reference to `client_icmp_request'
