срочно требуется помощь
Тема в разделе "Флудилка", создана пользователем lol, 1 июл 2019.
  1. lol
    lol Нерд
    Такая проблема: скетч нормально копилится, но переменная не принимает нужного значения
    pres = P,2 / 1,333;
    вот весь скетч
    #include <SFE_BMP180.h>
    #include <Wire.h>
    #include <OneWire.h>
    LiquidCrystal_I2C lcd(0x20, 20, 4);
    SFE_BMP180 pressure;
    #define ALTITUDE 1655.0
    #include <DallasTemperature.h>
    #define ONE_WIRE_BUS 5
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensor(&oneWire);
    int pres;
      lcd.init();
      lcd.backlight();
      Serial.println("REBOOT");
      sensor.begin();
      // устанавливаем разрешение датчика от 9 до 12 бит
      sensor.setResolution(12);
      // Initialize the sensor (it is important to get calibration values stored on the device).
      if (pressure.begin())
        Serial.println("BMP180 init success");
      else
        // Oops, something went wrong, this is usually a connection problem,
        // see the comments at the top of this sketch for the proper connections.
        Serial.println("BMP180 init fail\n\n");
        while (1); // Pause forever.
      char status;
      double T, P, p0, a;
      float temperature;
      // отправляем запрос на измерение температуры
      sensor.requestTemperatures();
      // считываем данные из регистра датчика
      temperature = sensor.getTempCByIndex(0);
      // Loop here getting pressure readings every 10 seconds.
      // If you want sea-level-compensated pressure, as used in weather reports,
      // you will need to know the altitude at which your measurements are taken.
      // We're using a constant called ALTITUDE in this sketch:
      Serial.println();
      Serial.print("provided altitude: ");
      Serial.print(ALTITUDE, 0);
      Serial.print(" meters, ");
      Serial.print(ALTITUDE * 3.28084, 0);
      Serial.println(" feet");
      // If you want to measure altitude, and not pressure, you will instead need
      // to provide a known baseline pressure. This is shown at the end of the sketch.
      // You must first get a temperature measurement to perform a pressure reading.
      // Start a temperature measurement:
      // If request is successful, the number of ms to wait is returned.
      // If request is unsuccessful, 0 is returned.
      status = pressure.startTemperature();
      if (status != 0)
        // Wait for the measurement to complete:
        delay(status);
        // Retrieve the completed temperature measurement:
        // Note that the measurement is stored in the variable T.
        // Function returns 1 if successful, 0 if failure.
        status = pressure.getTemperature(T);
        if (status != 0)
          // Print out the measurement:
          Serial.print("temperature: ");
          Serial.print(T, 2);
          Serial.print(" deg C, ");
          Serial.print((9.0 / 5.0)*T + 32.0, 2);
          Serial.println(" deg F");
          // Start a pressure measurement:
          // The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
          status = pressure.startPressure(3);
          if (status != 0)
            delay(status);
            // Retrieve the completed pressure measurement:
            // Note that the measurement is stored in the variable P.
            // Note also that the function requires the previous temperature measurement (T).
            // (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
            status = pressure.getPressure(P, T);
            if (status != 0)
              Serial.print("absolute pressure: ");
              Serial.print(P, 2);
              Serial.print(" mb, ");
              Serial.print(P * 0.0295333727, 2);
              Serial.println(" inHg");
              // The pressure sensor returns abolute pressure, which varies with altitude.
              // To remove the effects of altitude, use the sealevel function and your current altitude.
              // This number is commonly used in weather reports.
              // Parameters: P = absolute pressure in mb, ALTITUDE = current altitude in m.
              // Result: p0 = sea-level compensated pressure in mb
              p0 = pressure.sealevel(P, ALTITUDE); // we're at 1655 meters (Boulder, CO)
              Serial.print("relative (sea-level) pressure: ");
              Serial.print(p0, 2);
              Serial.print(p0 * 0.0295333727, 2);
              // On the other hand, if you want to determine your altitude from the pressure reading,
              // use the altitude function along with a baseline pressure (sea-level or other).
              // Parameters: P = absolute pressure in mb, p0 = baseline pressure in mb.
              // Result: a = altitude in m.
              pres = P,2 / 1,333;
              a = pressure.altitude(P, p0);
              Serial.print("computed altitude: ");
              Serial.print(a, 0);
              Serial.print(a * 3.28084, 0);
              lcd.setCursor(0, 0);
              lcd.print(pres);
              lcd.setCursor(6,0);
              lcd.print("mmrtst");
              lcd.setCursor(0,1);
              lcd.print(T,2);
              lcd.setCursor(5,1);
              lcd.print("T*C Input");
              lcd.setCursor(0,2);
              lcd.print(temperature);
              lcd.setCursor(5,2);
              lcd.print("T*C Output");
            else Serial.println("error retrieving pressure measurement\n");
          else Serial.println("error starting pressure measurement\n");
        else Serial.println("error retrieving temperature measurement\n");
      else Serial.println("error starting temperature measurement\n");
      delay(150);  // Pause for 5 seconds.
    пожалуйста помогите
  2. lol
    lol Нерд
    то есть по идее эта переменная для перевода из миллибар в мм.рт.ст
  3. Vovka
    Vovka Гик
    Что-то совсем не понял: что за Р, потом запятые... и всю эту "радость" присвоить целому числу.
    Определитесь что вы хотели...
    Daniil нравится это.
  4. lol
    lol Нерд
    это по библиотеке так , и в порт так же выводится. Тем более и без запятой не работает
  5. Tomasina
    pres = P / 1.333;
    а может и так:
    pres = P * 1.333;
    , я уже запутался. :cool:
  6. lol
    lol Нерд
    нет переменная на выходе всё равно показывает значение P и P,2
  7. Tomasina
    Покажите.
  8. lol
    lol Нерд
    что???
  9. Tomasina
    вот это. Скриншотом.
  10. lol
    lol Нерд
    очень смешно
  11. Tomasina
    Тогда сформулируйте мысль и результат так, чтобы было понятно не только вам.
    Igor68 и Daniil нравится это.
  12. Daniil
    Daniil Гуру
    "," в си используется только для перечисления чего-либо. Что вы перечисляете в математическом варажении?
    Присоединяюсь к непонятливым.
    NikitOS и Igor68 нравится это.
  13. lol
    lol Нерд
    P - переменная давления в миллибарах, pres - переменная для перевода из миллибар в миллиметры ртутного столба. Но при выводе на дисплей переменная pres выдаёт значение переменной P
  14. parovoZZ
    А что означает данная запись
    т.к.
    Не понимаю, как это пропустил компилятор? Наверняка же куча варнингов посыпалась. Но мы же не читаем. А зачем? Да они и вообще отключены. Вдруг на глазу мозоль натрет. Неудобняк будет перед программистами.
  15. lol
    lol Нерд
    я не знаю так есть в примере по bmp180
  16. parovoZZ
    Странно...Со словами
    компилятор-таки эту фразу съел...
  17. DIYMan
    DIYMan Guest
    И правильно сделал. И варнинг правильно показал. Потому что - приоритеты операторов, в результате переменной pres присваивается значение P, а всё, что после запятой - игнорируется, потому что - приоритеты операторов.
    Вот если бы было так - другое дело получилось бы на выходе:
    a = (b,c);
    Vovka и DetSimen нравится это.
  18. Igor68
    Igor68 Гуру
    Грубить компилятору, даже если он и убогий - свинство.
    Вот это
    pres = P,2 / 1,333;
    С дуба рухнули?
    У Вас же уже:
      char status;
      double T, P, p0, a;
      float temperature;
    И что для:
    int pres;
    это нормально?
    Если у Вас:
    double P;
    то и должно быть:
    double pres;
    а не:
    int pres;
    Конечно если вы не ходите избавиться от дробной части.
    Да и сделайте по нормальному:
    pres = P/1.333;
    ну или какая там "формула"
    NikitOS нравится это.
  19. b707
    вранье. нет там запятых и никогда не было.
    Похоже вы не въезжаете, что в программировании между запятой и точкой ПРИНЦИПИАЛЬНАЯ разница
  20. lol
    lol Нерд
    смотрите пример библиотеки Sparkfun BMP180
