____ __ / _/_____ / /__ _____ ____ _ / / / ___// //_// ___// __ `/ _/ / (__ )/ ,< / / / /_/ / /___//____//_/|_|/_/ \__,_/ Based on Espruino 1v90.77 (c) 2016 G.Williams, Amperka LLC Support the work of core developers: http://espruino.com/Donate >ERROR: SD card must be setup with E.connectSDCard first WARNING: Module "@amperka/led" not found Uncaught Error: Field or method "connect" does not already exist, and can't create it on undefined at line 1 col 36 var myLed = require('@amperka/led').connect(P1); ^ Uncaught Error: Field or method "turnOn" does not already exist, and can't create it on undefined at line 1 col 6 myLed.turnOn(); ^ =undefined > никак не могу с этим разобраться помогите пажалуйста
