Пытаюсь залить скетч в тиньку13 через ардуино, подключение такое http://habrastorage.org/files/010/b15/fa1/010b15fa175f46b180a51372c2a222f0.png Почему не компилируется скетч из примеров - Arduino ISP ???? и выдает просто килограммы ошибок: ArduinoISP.ino: In function 'void setup()': ArduinoISP:69: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void loop()': ArduinoISP:126: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'uint8_t getch()': ArduinoISP:132: error: 'Serial' was not declared in this scope ArduinoISP:133: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void spi_init()': ArduinoISP:159: error: 'SPCR' was not declared in this scope ArduinoISP:160: error: 'SPSR' was not declared in this scope ArduinoISP:161: error: 'SPDR' was not declared in this scope ArduinoISP.ino: In function 'void spi_wait()': ArduinoISP:167: error: 'SPSR' was not declared in this scope ArduinoISP:167: error: 'SPIF' was not declared in this scope ArduinoISP.ino: In function 'uint8_t spi_send(uint8_t)': ArduinoISP:172: error: 'SPDR' was not declared in this scope ArduinoISP.ino: In function 'void empty_reply()': ArduinoISP:189: error: 'Serial' was not declared in this scope ArduinoISP:194: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void breply(uint8_t)': ArduinoISP:200: error: 'Serial' was not declared in this scope ArduinoISP:206: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void start_pmode()': ArduinoISP:257: error: 'SS' was not declared in this scope ArduinoISP:259: error: 'SCK' was not declared in this scope ArduinoISP:264: error: 'MISO' was not declared in this scope ArduinoISP:265: error: 'MOSI' was not declared in this scope ArduinoISP.ino: In function 'void end_pmode()': ArduinoISP:271: error: 'MISO' was not declared in this scope ArduinoISP:272: error: 'MOSI' was not declared in this scope ArduinoISP:273: error: 'SCK' was not declared in this scope ArduinoISP:274: error: 'SS' was not declared in this scope ArduinoISP.ino: In function 'void write_flash(int)': ArduinoISP:315: error: 'Serial' was not declared in this scope ArduinoISP:320: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void program_page()': ArduinoISP:387: error: 'Serial' was not declared in this scope ArduinoISP:392: error: 'Serial' was not declared in this scope ArduinoISP:396: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'char flash_read_page(int)': ArduinoISP:410: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'char eeprom_read_page(int)': ArduinoISP:424: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void read_page()': ArduinoISP:436: error: 'Serial' was not declared in this scope ArduinoISP:439: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'void read_signature()': ArduinoISP:449: error: 'Serial' was not declared in this scope ArduinoISP:452: error: 'Serial' was not declared in this scope ArduinoISP.ino: In function 'int avrisp()': ArduinoISP:477: error: 'Serial' was not declared in this scope ArduinoISP:540: error: 'Serial' was not declared in this scope
выбрана плата тини13, в hardware закинул ядро тини 13, программатор - arduino as ISP, причем если выбрать плату уно, то все нормально компилируется... косяк в ядре тини13? допустим загрузил уно этим скетчем, потом выбрал тини13 и прошиваю скетчем Blink, то IDE выдает ошибку avrdude: stk500_getsync(): not in sync: resp=0x00
Вы что, пытаетесь скетч Arduino ISP прошить в ATtiny13 ? Судя по ошибкам компиляции... Алгоритм: 1) выбираем плату Uno; 2) компилируем и прошиваем скетч Arduino ISP; 3) выбираем плату Tiny; 4) компилируем и прошиваем скетч Blink; У вас проблема в шаге (2) - не проходит компиляция скетча, превращающего Uno в программатор.
Согласен с Unixon . Просто хотел добавить, вывод в Serial порт не будет работать , поэтому в скетче строки с портом надо удалить. Я пробовал прошивать "tiny" они отлично прошиваются , даже ради эксперимента собрал пару схем для проверки работы SLEEP MODe и WATCH DOG. Отлично работают и прошиваются через ардуину. Ссылка для примера прошивки tiny http://habrahabr.ru/post/234477/
Я понял Вас, но я просто уже всяко пытался. Я понимаю уже, что скетч ISP нужен для уно. В этом случае УНО прошивается, но тини всеравно не прошивается тем же Блинком, причем IDE сообщает (как я сказал): avrdude: stk500_getsync(): not in sync: resp=0x00 Done uploading а кто знает, что означает данная ошибка? avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny13 что за беда?
В общем проблему решил, не знаю надолго или нет. Решилась она также непонятна как и началась... проделав несколько раз к ряду одну и туже операцию - прошивка уно isp, перетыканием проводов в ТЕЖЕ самые дырки, загрузка блинка (пин для светодиода был верно прописан, в соответствии с подключенным физически) и все заморгало ... Всем спасибо кто откликнулся
Чтобы не создавать новую тему, напишу тут же. Проблема в следующем. То ли вышла новая версия ide. То ли причина в том, что я удалил прошлые файлы прошивки ядра Tiny, а новые, которые вставляю в hardware не подходят. В общем таким способом не получается прошить скетч в Tiny13. Сообщение при компиляции Сообщение при прошивке Если кто пользуется таким способом для прошивки Tiny и прошивка проходит у вас отлично без ошибок, не могли бы Вы сказать, а лучше выложить: 1. файлы ядра прошивки Tiny 2. написать версию вашей ардуино ide
уж не знаю, что там нужно для УНО, мытарства продолжаются, пробовал 5-6 версий IDE, и аналогичное кол-во версий файлов ядер для тини....
Причем это все на стадии компиляции и выбранной плате Attiny13, так что я думаю, что в подключении проблем быть не может. В общем задал вопрос на arduino.cc
!!!!!!!!! СПАСИБО! Заработало, но не сразу. В Readme написано, что версия 1.0.5, ее и поставил, с актуальной на данный момент 1.5.8 не заработало. и вот еще ... а если вдруг мне в будущем надо будет прошивать таким способом тини45,85,2313... мне на каждый мк прийдется вот такие файлы искать днями? или есть какой то универсальный вариант? =(
там в boards.txt, надо не заменить, а добавить к содержимому. актуальная сейчас 1,0,6. на тот момент была 1,0,5. а как оно там с беттами дружит, незнаю, сам на эту тини13 времени убил уйму.
верно, так и сделал и основные платы появились в списке. спасибо а как насчет других тинь? 45, 85 и 2313? или вы их не программировали данным способом?
Почитайте тут(автор тот же) http://habrahabr.ru/post/247329/ Программа sinaprog, только мне в папке ports.txt понадобилось добавить свой com порт. Там есть тини45 и т.п. hex-файлы можно доставать из arduino ide.
