Код ( (Unknown Language)): #define PIN_SCE 7 #define PIN_RESET 6 #define PIN_DC 5 #define PIN_SDIN 4 #define PIN_SCLK 3 #define LCD_C LOW #define LCD_D HIGH #define LCD_X 84 #define LCD_Y 6 #define note_len 100000 #define play_c 3830 #define play_d 3400 #define play_e 3038 int speakerOut = 13; int barWidth = 16; int barHeight = 4; int ballPerimeter = 4; unsigned int bar1X = 0; unsigned int bar1Y = 0; unsigned int bar2X = 0; unsigned int bar2Y = LCD_Y * 8 - barHeight; int ballX = 0; int ballY = 0; boolean isBallUp = false; boolean isBallRight = true; byte pixels[LCD_X][LCD_Y]; unsigned long lastRefreshTime; const int refreshInterval = 80; byte gameState = 1; byte ballSpeed = 2; byte player1WinCount = 0; byte player2WinCount = 0; byte hitCount = 0; void setup(){ //Serial.begin(9600); pinMode(speakerOut, OUTPUT); playTone(play_c); LcdInitialise(); restartGame(); } void loop(){ unsigned long now = millis(); if(now - lastRefreshTime > refreshInterval){ update(); refreshScreen(); lastRefreshTime = now; } } void restartGame(){ ballSpeed = 1; gameState = 1; ballX = random(0, 60); ballY = 20; isBallUp = false; isBallRight = true; hitCount = 0; } void refreshScreen(){ if(gameState == 1){ for(int y = 0; y < LCD_Y; y++){ for(int x = 0; x < LCD_X; x++){ byte pixel = 0x00; int realY = y * 8; // draw ball if in the frame if(x >= ballX && x <= ballX + ballPerimeter -1 && ballY + ballPerimeter > realY && ballY < realY + 8 ){ byte ballMask = 0x00; for(int i = 0; i < realY + 8 - ballY; i++){ ballMask = ballMask >> 1; if(i < ballPerimeter) ballMask = 0x80 | ballMask; } pixel = pixel | ballMask; } // draw bars if in the frame if(x >= bar1X && x <= bar1X + barWidth -1 && bar1Y + barHeight > realY && bar1Y < realY + 8 ){ byte barMask = 0x00; for(int i = 0; i < realY + 8 - bar1Y; i++){ barMask = barMask >> 1; if(i < barHeight) barMask = 0x80 | barMask; } pixel = pixel | barMask; } if(x >= bar2X && x <= bar2X + barWidth -1 && bar2Y + barHeight > realY && bar2Y < realY + 8 ){ byte barMask = 0x00; for(int i = 0; i < realY + 8 - bar2Y; i++){ barMask = barMask >> 1; if(i < barHeight) barMask = 0x80 | barMask; } pixel = pixel | barMask; } LcdWrite(LCD_D, pixel); } } } else if(gameState == 2){ } } void update(){ if(gameState == 1){ int barMargin = LCD_X - barWidth; int pot1 = analogRead(A0); //read potentiometers and set the bar positions int pot2 = analogRead(A1); bar1X = pot1 / 2 * LCD_X / 512; bar2X = pot2 / 2 * LCD_X / 512; if(bar1X > barMargin) bar1X = barMargin; if(bar2X > barMargin) bar2X = barMargin; //move the ball now if(isBallUp) ballY -= ballSpeed; else ballY += ballSpeed; if(isBallRight) ballX += ballSpeed; else ballX -= ballSpeed; //check collisions if(ballX < 1){ isBallRight = true; ballX = 0; } else if(ballX > LCD_X - ballPerimeter - 1){ isBallRight = false; ballX = LCD_X - ballPerimeter; } if(ballY < barHeight){ if(ballX + ballPerimeter >= bar1X && ballX <= bar1X + barWidth){ // ball bounces from bar1 isBallUp = false; playTone(play_c); if(ballX + ballPerimeter/2 < bar1X + barWidth/2) isBallRight = false; else isBallRight = true; ballY = barHeight; if(++hitCount % 10 == 0 && ballSpeed < 5) ballSpeed++; }else{ //player2 wins gameState = 2; player2WinCount++; } } if(ballY + ballPerimeter > LCD_Y * 8 - barHeight){ if(ballX + ballPerimeter >= bar2X && ballX <= bar2X + barWidth){ //ball bounces from bar2 isBallUp = true; playTone(play_c); if(ballX + ballPerimeter/2 < bar2X + barWidth/2) isBallRight = false; else isBallRight = true; ballY = LCD_Y * 8 - barHeight - ballPerimeter; if(++hitCount % 10 == 0 && ballSpeed < 5) ballSpeed++; }else{ // player 1 wins gameState = 2; player1WinCount++; playTone(play_c); } } }else if(gameState == 2){ for(int i =0; i < 4; i++){ playTone(play_d); LcdWrite(LCD_C, 0x0D ); // LCD in inverse mode. delay(300); LcdWrite(LCD_C, 0x0C ); // LCD in inverse mode. delay(300); } restartGame(); } } void LcdInitialise(void){ pinMode(PIN_SCE, OUTPUT); pinMode(PIN_RESET, OUTPUT); pinMode(PIN_DC, OUTPUT); pinMode(PIN_SDIN, OUTPUT); pinMode(PIN_SCLK, OUTPUT); delay(200); digitalWrite(PIN_RESET, LOW); delay(500); digitalWrite(PIN_RESET, HIGH); LcdWrite(LCD_C, 0x21 ); // LCD Extended Commands. LcdWrite(LCD_C, 0xB1 ); // Set LCD Vop (Contrast). LcdWrite(LCD_C, 0x04 ); // Set Temp coefficent. //0x04 LcdWrite(LCD_C, 0x14 ); // LCD bias mode 1:48. //0x13 LcdWrite(LCD_C, 0x0C ); // LCD in normal mode. LcdWrite(LCD_C, 0x20 ); LcdWrite(LCD_C, 0x80 ); //select X Address 0 of the LCD Ram LcdWrite(LCD_C, 0x40 ); //select Y Address 0 of the LCD Ram - Reset is not working for some reason, so I had to set these addresses LcdWrite(LCD_C, 0x0C ); } void LcdWrite(byte dc, byte data){ digitalWrite(PIN_DC, dc); digitalWrite(PIN_SCE, LOW); shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data); digitalWrite(PIN_SCE, HIGH); } void playTone(int note) { long elapsed_time = 0; while (elapsed_time < note_len) { digitalWrite(speakerOut,HIGH); delayMicroseconds(note / 2); digitalWrite(speakerOut, LOW); delayMicroseconds(note / 2); elapsed_time += (note); } }
Код ( (Unknown Language)): #include <TVout.h> #include <fontALL.h> #define WHEEL_ONE_PIN 1 //analog #define WHEEL_TWO_PIN 0 //analog #define BUTTON_ONE_PIN 2 //digital to start game // #define BUTTON_TWO_PIN 3 //digital to reset and go back to main menu #define PADDLE_HEIGHT 14 #define PADDLE_WIDTH 1 #define RIGHT_PADDLE_X (TV.hres()-4) #define LEFT_PADDLE_X 2 #define IN_GAMEA 0 //in game state - draw constants of the game box #define IN_GAMEB 0 //in game state - draw the dynamic part of the game #define IN_MENU 1 //in menu state #define GAME_OVER 2 //game over state #define LEFT_SCORE_X (TV.hres()/2-15) #define RIGHT_SCORE_X (TV.hres()/2+10) #define SCORE_Y 4 #define MAX_Y_VELOCITY 6 #define PLAY_TO 7 #define LEFT 0 #define RIGHT 1 #define note_len 16000 #define play_c 3830 #define play_d 3400 #define play_e 3038 int speakerOut = 11; int trigPin = 3; int echoPin = 4; long distance; TVout TV; unsigned char x,y; boolean button1Status = false; // boolean button2Status = false; int wheelOnePosition = 0; int wheelTwoPosition = 0; int rightPaddleY = 0; int leftPaddleY = 0; unsigned char ballX = 0; unsigned char ballY = 0; char ballVolX = 2; char ballVolY = 2; int leftPlayerScore = 0; int rightPlayerScore = 0; int frame = 0; int state = IN_MENU; void processInputs() { //wheelOnePosition = analogRead(WHEEL_ONE_PIN); distance = getDistance(); if (distance > 25) distance = 25; wheelOnePosition = 1024 - distance * 40; // delay(50); wheelTwoPosition = analogRead(WHEEL_TWO_PIN); // delay(50); button1Status = (digitalRead(BUTTON_ONE_PIN)); // button2Status = (digitalRead(BUTTON_TWO_PIN) == LOW); if ((button1Status == 0)&& (state == GAME_OVER)) { Serial.println("game over, drawing menu"); drawMenu (); } delay(50); //Serial.println(button1Status); //Serial.println(state); //Serial.println(button2Status); //Serial.println(wheelOnePosition); //Serial.println(wheelTwoPosition); } void drawGameScreen() { // TV.clear_screen(); //draw right paddle rightPaddleY = ((wheelOnePosition /8) * (TV.vres()-PADDLE_HEIGHT))/ 128; x = RIGHT_PADDLE_X; for(int i=0; i<PADDLE_WIDTH; i++) { TV.draw_line(x+i,rightPaddleY,x+i,rightPaddleY+PADDLE_HEIGHT,1); } //draw left paddle leftPaddleY = ((wheelTwoPosition /8) * (TV.vres()-PADDLE_HEIGHT))/ 128; x = LEFT_PADDLE_X; for(int i=0; i<PADDLE_WIDTH; i++) { TV.draw_line(x+i,leftPaddleY,x+i,leftPaddleY+PADDLE_HEIGHT,1); } //draw score TV.print_char(LEFT_SCORE_X,SCORE_Y,'0'+leftPlayerScore); TV.print_char(RIGHT_SCORE_X,SCORE_Y,'0'+rightPlayerScore); //draw ball TV.set_pixel(ballX, ballY, 2); } //player == LEFT or RIGHT void playerScored(byte player) { if(player == LEFT) leftPlayerScore++; if(player == RIGHT) rightPlayerScore++; //check for win if(leftPlayerScore == PLAY_TO || rightPlayerScore == PLAY_TO) { state = GAME_OVER; } ballVolX = -ballVolX; } void drawBox() { TV.clear_screen(); //draw net for(int i=1; i<TV.vres() - 4; i+=6) { TV.draw_line(TV.hres()/2,i,TV.hres()/2,i+3,1); } // had to make box a bit smaller to fit tv TV.draw_line(0, 0, 0,95,1 ); // left TV.draw_line(0, 0, 126,0,1 ); // top TV.draw_line(126, 0, 126,95,1 ); // right TV.draw_line(0, 95, 126,95,1 ); // bottom state = IN_GAMEB; } void drawMenu() { x = 0; y = 0; char volX =3; char volY = 3; TV.clear_screen(); TV.select_font(font8x8); TV.print(10, 5, "Arduino Pong"); TV.select_font(font4x6); TV.print(22, 35, "Press Button"); TV.print(30, 45, "To Start"); delay(1000); while(!button1Status) { Serial.println("menu"); Serial.println(button1Status); processInputs(); TV.delay_frame(3); if(x + volX < 1 || x + volX > TV.hres() - 1) volX = -volX; if(y + volY < 1 || y + volY > TV.vres() - 1) volY = -volY; if(TV.get_pixel(x + volX, y + volY)) { TV.set_pixel(x + volX, y + volY, 0); if(TV.get_pixel(x + volX, y - volY) == 0) { volY = -volY; } else if(TV.get_pixel(x - volX, y + volY) == 0) { volX = -volX; } else { volX = -volX; volY = -volY; } } TV.set_pixel(x, y, 0); x += volX; y += volY; TV.set_pixel(x, y, 1); } TV.select_font(font4x6); state = IN_GAMEA; } void setup() { //Serial.begin(9600); pinMode(trigPin,OUTPUT); pinMode(echoPin,INPUT); x=0; y=0; TV.begin(_PAL); //for devices with only 1k sram(m168) use TV.begin(_NTSC,128,56) ballX = TV.hres() / 2; ballY = TV.vres() / 2; // pinMode(BUTTON_ONE_PIN, INPUT); // sets the digital pin as output } void loop() { processInputs(); if(state == IN_MENU) { drawMenu(); } if(state == IN_GAMEA) { //Serial.println("gamA"); //Serial.println(button1Status); drawBox(); } if(state == IN_GAMEB) { if(frame % 1 == 0) { //every third frame ballX += ballVolX; ballY += ballVolY; // change if hit top or bottom if(ballY <= 1 || ballY >= TV.vres()-1) { ballVolY = -ballVolY; delay(100); // TV.tone( 2000,30 ); playTone(play_c); } // test left side for wall hit if(ballVolX < 0 && ballX == LEFT_PADDLE_X+PADDLE_WIDTH-1 && ballY >= leftPaddleY && ballY <= leftPaddleY + PADDLE_HEIGHT) { ballVolX = -ballVolX; ballVolY += 2 * ((ballY - leftPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2); delay(100); // TV.tone(2000,30 ); playTone(play_d); } // test right side for wall hit if(ballVolX > 0 && ballX == RIGHT_PADDLE_X && ballY >= rightPaddleY && ballY <= rightPaddleY + PADDLE_HEIGHT) { ballVolX = -ballVolX; ballVolY += 2 * ((ballY - rightPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2); delay(100); //TV.tone( 2000,30 ); playTone(play_d); } //limit vertical speed if(ballVolY > MAX_Y_VELOCITY) ballVolY = MAX_Y_VELOCITY; if(ballVolY < -MAX_Y_VELOCITY) ballVolY = -MAX_Y_VELOCITY; // Scoring if(ballX <= 1) { playerScored(RIGHT); // sound delay(100); //TV.tone( 500,300 ); playTone(play_e); } if(ballX >= TV.hres() - 1) { playerScored(LEFT); // sound delay(100); //TV.tone( 500,300 ); playTone(play_e); } } // if(button1Status) Serial.println((int)ballVolX); drawGameScreen(); } if(state == GAME_OVER) { drawGameScreen(); TV.select_font(font8x8); TV.print(29,25,"GAME"); TV.print(68,25,"OVER"); while(!button1Status) { processInputs(); delay(50); } TV.select_font(font4x6); //reset the font //reset the scores leftPlayerScore = 0; rightPlayerScore = 0; state = IN_MENU; } TV.delay_frame(1); if(++frame == 60) frame = 0; //increment and/or reset frame counter } void playTone(int note) { long elapsed_time = 0; while (elapsed_time < note_len) { digitalWrite(speakerOut,HIGH); delayMicroseconds(note / 2); digitalWrite(speakerOut, LOW); delayMicroseconds(note / 2); elapsed_time += (note); } } long getEchoTiming() { digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); long duration = pulseIn(echoPin,HIGH); return duration; } long getDistance() { long distacne_cm = getEchoTiming()/29/2; return distacne_cm; }
