Arduino UNO + Arduino Robot Lcd
Тема в разделе "Arduino & Shields", создана пользователем @Anatoly, 6 мар 2015.
  1. @Anatoly
    @Anatoly Нерд
    Добрый день.
    Возникла следующая проблема.
    Исходные данные: плата arduino uno,дисплей Arduino Robot LCD (http://amperka.ru/product/tft-lcd-160x128)
    Подключаю по-умолчанию, согласно схеме
    Скетч: (стандартный "TFTBitmapLogo")
    Arduino TFT Bitmap Logo example
    This example reads an image file from a micro-SD card
    and draws it on the screen, at random locations.
    In this sketch, the Arduino logo is read from a micro-SD card.
    There is a .bmp file included with this sketch.
    - open the sketch folder (Ctrl-K or Cmd-K)
    - copy the "arduino.bmp" file to a micro-SD
    - put the SD into the SD slot of the Arduino TFT module.
    This example code is in the public domain.
    Created 19 April 2013 by Enrico Gueli
    http://arduino.cc/en/Tutorial/TFTBitmapLogo
    // include the necessary libraries
    #include <SPI.h>
    #include <SD.h>
    #include <TFT.h>  // Arduino LCD library
    // pin definition for the Uno
    #define sd_cs  4
    #define lcd_cs 10
    #define dc    9
    #define rst    8
    // pin definition for the Leonardo
    //#define sd_cs  8
    //#define lcd_cs 7
    //#define dc    0
    //#define rst    1
    TFT TFTscreen = TFT(lcd_cs, dc, rst);
    // this variable represents the image to be drawn on screen
    PImage logo;
      // initialize the GLCD and show a message
      // asking the user to open the serial line
      TFTscreen.begin();
      TFTscreen.background(255, 255, 255);
      TFTscreen.stroke(0, 0, 255);
      TFTscreen.println();
      TFTscreen.println(F("Arduino TFT Bitmap Example"));
      TFTscreen.stroke(0, 0, 0);
      TFTscreen.println(F("Open serial monitor"));
      TFTscreen.println(F("to run the sketch"));
      // initialize the serial port: it will be used to
      // print some diagnostic info
      while (!Serial) {
        // wait for serial line to be ready
      // clear the GLCD screen before starting
      // try to access the SD card. If that fails (e.g.
      // no card present), the setup process will stop.
      Serial.print(F("Initializing SD card..."));
      if (!SD.begin(sd_cs)) {
        Serial.println(F("failed!"));
        return;
      Serial.println(F("OK!"));
      // initialize and clear the GLCD screen
      TFTscreen.begin();
      // now that the SD card can be access, try to load the
      // image file.
      logo = TFTscreen.loadImage("arduino.bmp");
      if (!logo.isValid()) {
        Serial.println(F("error while loading arduino.bmp"));
      // don't do anything if the image wasn't loaded correctly.
      if (logo.isValid() == false) {
        return;
      Serial.println(F("drawing image"));
      // get a random location where to draw the image.
      // To avoid the image to be draw outside the screen,
      // take into account the image size.
      int x = random(TFTscreen.width() - logo.width());
      int y = random(TFTscreen.height() - logo.height());
      // draw the image to the screen
      TFTscreen.image(logo, x, y);
      // wait a little bit before drawing again
      delay(1500);
    Проблема: Initializing SD card...failed
    Кто-нибудь знает в чем проблема?
      107,6 КБ
  2. X-Dron
    X-Dron Гик
    SD -карта точно правильно установлена?
  3. @Anatoly
    @Anatoly Нерд
    SD карта точно правильно установлена и работает. На Arduino Mega подключаю эту же карту и инициализации проходит без проблем.
    Поиск привел к тому, что здесь происходит конфликт подключения самого экрана и SD карта, т.к. они оба подключаются по SPI, экран как мастер, а SD как slave
    Самое интересное, что SD карта какое-то время поработала в начале, а потом все :(
  4. @Anatoly
    @Anatoly Нерд
  5. @Anatoly
    @Anatoly Нерд
    Подключил экран к МЕГЕ 2560 и все заработало! Вопрос: что не так с UNO?
