PULTOSCOPE_LCD5110_final2_DDS_Z Ошибки при компиляции...
Тема в разделе "Arduino & Shields", создана пользователем blackcatw, 9 окт 2016.
  1. blackcatw
    blackcatw Нерд
    Решил собрать образец пульсоскопа (ограниченного по функциональности осцилографа)
    вот отсюда видимо разные версии IDE и поэтому на выдаёт ошибку
    Arduino: 1.6.9 (Linux), Плата:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp.o (symbol from plugin): In function `Adafruit_GFX::drawLine(int, int, int, int, unsigned int)':
    (.text+0x0): multiple definition of `Adafruit_GFX::drawLine(int, int, int, int, unsigned int)'
    sketch/Adafruit_GFX_Library/Adafruit_GFX.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `Adafruit_GFX::drawRect(int, int, int, int, unsigned int)'
    (.text+0x0): multiple definition of `Adafruit_GFX::drawFastVLine(int, int, int, unsigned int)'
    (.text+0x0): multiple definition of `Adafruit_GFX::drawFastHLine(int, int, int, unsigned int)'
    (Чуток вырезано)
    libraries/Adafruit-PCD8544-Nokia-5110-LCD-library/Adafruit_PCD8544.cpp.o (symbol from plugin): In function `pcd8544_buffer':
    (.text+0x0): multiple definition of `pcd8544_buffer'
    sketch/Adafruit_GFX_Library/Adafruit_PCD8544.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `Adafruit_PCD8544::drawPixel(int, int, unsigned int)'
    (.text+0x0): multiple definition of `Adafruit_PCD8544::getPixel(signed char, signed char)'
    (.text+0x0): multiple definition of `Adafruit_PCD8544::Adafruit_PCD8544(signed char, signed char, signed char, signed char, signed char)'
    (чуток вырезано)
    libraries/FreqCount/FreqCount.cpp.o (symbol from plugin): In function `FreqCountClass::begin(unsigned int)':
    (.text+0x0): multiple definition of `FreqCountClass::begin(unsigned int)'
    sketch/FreqCount/FreqCount.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `FreqCountClass::available()'
    (.text+0x0): multiple definition of `FreqCountClass::read()'
    (.text+0x0): multiple definition of `FreqCountClass::end()'
    (чуток вырезано)
    libraries/PWM/utility/BTimerDefs.cpp.o (symbol from plugin): In function `GetPrescaler_8(int)':
    (.text+0x0): multiple definition of `GetPrescaler_8(int)'
    sketch/PWM/utility/BTimerDefs.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `GetPrescaler_16()'
    (.text+0x0): multiple definition of `GetFrequency_16()'
    (чуток вырезанно)
    libraries/CyberLib/CyberLib.cpp.o (symbol from plugin): In function `UART_Init(unsigned long)':
    (.text+0x0): multiple definition of `UART_Init(unsigned long)'
    sketch/CyberLib/CyberLib.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `UART_SendByte(unsigned char)'
    (.text+0x0): multiple definition of `UART_ReadByte(unsigned char&)'
    (чуток вырезанно)
    (.text+0x0): multiple definition of `func'
    (.text+0x0): multiple definition of `dub_tcnt1'
    (.text+0x0): multiple definition of `StopTimer1()'
    (.text+0x0): multiple definition of `ResumeTimer1()'
    (.text+0x0): multiple definition of `RestartTimer1()'
    (.text+0x0): multiple definition of `__vector_13'
    (.text+0x0): multiple definition of `find_similar(unsigned int*, unsigned char, unsigned char)'
    (чуток вырезанно)
    (.text+0x0): multiple definition of `delay_ms(unsigned int)'
    collect2: error: ld returned 1 exit status
    exit status 1
    Ошибка компиляции для платы Arduino Pro or Pro Mini.
    Этот отчёт будет иметь больше информации с
    включенной опцией Файл -> Настройки ->
    "Показать подробный вывод во время компиляции"
    Сможет кто-нибудь подсказать где и что исправить? Я что-то помню, на тему изменений, что нужно где-то что-то изменить, так как IDE притерпела изменения и некоторые скечи нужно как-то изменить...
  2. rkit
    Выкинуть из скетча Adafruit_GFX_Library, ошибки-то читай.
  3. blackcatw
    blackcatw Нерд
    Тогда, судя по логике, придётся выкинуть и все остальные библиотеки...
    При выкидывании библиотеки получаются уже ошибки в коде скетча.
  4. rkit
    Не знаю, что это за "логика" такая. Еще раз предложу просто прочитать ошибки.
  5. blackcatw
    blackcatw Нерд
    блиотеки / Adafruit_GFX_Library / Adafruit_GFX.cpp.o (символ из плагина): В функции `Adafruit_GFX :: DrawLine (INT, INT, INT, INT, неподписанные INT) ':
    (.text + 0x0): кратное определение `Adafruit_GFX :: DrawLine (INT, INT, INT, INT, неподписанные INT) '
    DrawLine - неподписанные INT.
    Что за неподписанные? Могу предположить, что что-то не подходит по типам. При чём практически по всем подключаемым библиотекам.
  6. rkit
    Понятно. Ну я сказал, в чем проблема. А вообще очень советую изучать английский, если уж решил связаться с программирование.
  7. blackcatw
    blackcatw Нерд
    В итоге на вопрос я так и не получил ответа.
    Конечно "умничать" легче, чем помочь...
  8. rkit
    Я простым языком объяснил, что надо сделать, чтобы исправить приведенные ошибки. Дальше уж проблема получающего.
  9. blackcatw
    blackcatw Нерд
    Данным способом ошибка не исправляется. Т.к. в скетче появляются ошибки ссылки на библиотеку.
    Ваше объяснение не помогает.
  10. rkit
    Ах, так там другие ошибки появляются? Извиняюсь, у меня телепатических способностей нету.
  11. blackcatw
    blackcatw Нерд
    Они и не нужны. Просто внимательней читать нужно.
  12. rkit
    Перечитал четыре раза - текста новых ошибок не нашел
  13. blackcatw
    blackcatw Нерд
    Ну я не про текст писал. Я писал про то, что идут новые ошибки.
  14. blackcatw
    blackcatw Нерд
    In file included from /home/blackcat/Work/PULTOSCOPE_LCD5110_final2_DDS_Z/PULTOSCOPE_LCD5110_final2_DDS_Z.ino:3:0:
    /home/blackcat/Arduino/libraries/Adafruit-PCD8544-Nokia-5110-LCD-library/Adafruit_PCD8544.h:69:46: error: expected class-name before '{' token
    class Adafruit_PCD8544 : public Adafruit_GFX {
    /home/blackcat/Work/PULTOSCOPE_LCD5110_final2_DDS_Z/PULTOSCOPE_LCD5110_final2_DDS_Z.ino: In function 'void setup()':
    PULTOSCOPE_LCD5110_final2_DDS_Z:63: error: 'class Adafruit_PCD8544' has no member named 'setCursor'
    display.setCursor(10,0);
    PULTOSCOPE_LCD5110_final2_DDS_Z:64: error: 'class Adafruit_PCD8544' has no member named 'setTextColor'
    display.setTextColor(WHITE, BLACK); // 'inverted' text
    (далее для экономии места удалено, т.к. всё однотипно)
    PULTOSCOPE_LCD5110_final2_DDS_Z:555: error: 'class Adafruit_PCD8544' has no member named 'print'
    display.print(incomingBytes); // Печать строки в буффер дисплея
    exit status 1
  15. rkit
    Adafruit_GFX_Library, включенная в иде не совместима с библиотекой, используемой в скетче. Значит надо все-таки использовать бибиотеку из скетча, а библиотеку из иде отключить/удалить (не знаю, как это делается). Но я так чувствую, что там и дальше начнутся проблемы, которые придется весь вечер сидеть разгребать.
    Короче, проще будет взять иде той версии, под которую был написан скетч.
  16. blackcatw
    blackcatw Нерд
    Ну написал. Ошибки.
  17. ZAZ-965
    ZAZ-965 Гуру
    @blackcatw, автор пультоскопа зачем-то перенес содержимое библиотеки Adafruit-PCD8544-Nokia-5110-LCD-library в библиотеку Adafruit-GFX-Library. Поэтому, или временно удалите библиотеку Adafruit-PCD8544-Nokia-5110-LCD-library или из библиотеки Adafruit-GFX-Library удалите Adafruit_PCD8544.cpp и Adafruit_PCD8544.h
  18. blackcatw
    blackcatw Нерд
    Блин... АЛЕЛЛУЯ!!! Вы мистер очевидность....
    Я в первых строках об этом написал...
  19. blackcatw
    blackcatw Нерд
    Хм... Что-то видимо не совсем так....
    Попробовал через IDE среду вызвать пример pcdtest.ino в начале скетча, тоже есть объявление
    #include <SPI.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_PCD8544.h>
    И скомпилировалось нормально.... Может что-то где-то напутанно?
  20. shpock
    shpock Гик
    Скачал я этот скетч PULTOSCOPE_LCD5110_final2_DDS_Z, побыстряку собрал все это чудо, запустил компилятор на Arduino: 1.6.8 (Windows 10) (у автора поста под Linux) - и посыпались ошибочки.
    Так вот у меня первая проблемка из-за того что ищет файл WProgram.h, тоисть скетч ваялся на Arduino: 1.0.? (а точнее библиотеки).
    нужно везде в библиотеках где #include "WProgram.h", заменить на
    #if defined(ARDUINO) && ARDUINO >= 100
      #include "Arduino.h"
    #else
    #endif
    дальше было несколько матов на константы, которые не описаны как константы )), изменил.
    Дальше полетели ошибки на таймеры....... Я компилировал для Леонардо. Решил попробовать для УНО, и опа, все заработало. Для Про и Про Мини тоже компилируется.
    Вот как то так.
