Проект радиоуправляемой машинки на ардуино нано.Управление по nrf24L01.Не загружается скетч! #include <Servo.h> #include <SPI.h> #include "RF24.h" Servo servo1; RF24 radio(9,10); const uint64_t pipe = 0xF0F0F0F000LL; int msg[1]; int data; int pos; int fspeed; // forward speed int bspeed; // backward speed const int in1 = 2; // direction pin 1 const int in2 = 4; // direction pin 2 const int ena = 5; // PWM pin to change speed void setup() { pinMode(in1, OUTPUT); // connection to L298n pinMode(in2, OUTPUT); // connection to L298n pinMode(ena, OUTPUT); // connection to L298n servo1.attach(3); delay(50); radio.begin(); radio.openReadingPipe(1,pipe); radio.startListening(); } void loop() { if (radio.available())radio.read(msg, 1); if (msg[0] <127 && msg[0] >-1)data = msg[0], pos = map(data, 0, 126, 7, 67),servo1.write(pos); if (msg[0] >=128 && msg[0] <=189)data = msg[0], bspeed = map(data, 255, 201, 0, 255), backward(bspeed); if (msg[0] >=201 && msg[0] <=255)data = msg[0], fspeed = map(data, 189, 128, 0, 255), forward(fspeed); if (msg[0] >190 && msg[0] <200)data = msg[0], stop(); } void stop() { analogWrite(ena, 0); digitalWrite(in1, LOW); digitalWrite(in2, LOW); } void forward(int fspeed) { digitalWrite(in1, HIGH); digitalWrite(in2, LOW); analogWrite(ena, fspeed); } void backward(int bspeed) { digitalWrite(in1, LOW); digitalWrite(in2, HIGH); analogWrite(ena, bspeed); } Вот. if (msg[0] >=128 && msg[0] <=189)data = msg[0], bspeed = map(data, 255, 201, 0, 255), backward(bspeed);-эта строчка выделена красным,хз почему. а вот что пишет прога: C:\Users\Администратор\AppData\Local\Temp\sketch_priemnik-korablik-02\sketch_priemnik-korablik-02.ino: In function 'void loop()': sketch_priemnik-korablik-02:36: error: 'backward' was not declared in this scope sketch_priemnik-korablik-02:37: error: 'forward' was not declared in this scope sketch_priemnik-korablik-02:38: error: 'stop' was not declared in this scope exit status 1 'backward' was not declared in this scope Помогите пожалуйста. Если есть скетчи rc машинок,то скиньте пожалуйста.
@Иваныч ардуинщик, определите функции раньше их использования Код (C++): #include <Servo.h> #include <SPI.h> #include "RF24.h" Servo servo1; RF24 radio(9,10); const uint64_t pipe = 0xF0F0F0F000LL; int msg[1]; int data; int pos; int fspeed; // forward speed int bspeed; // backward speed const int in1 = 2; // direction pin 1 const int in2 = 4; // direction pin 2 const int ena = 5; // PWM pin to change speed void stop() { analogWrite(ena, 0); digitalWrite(in1, LOW); digitalWrite(in2, LOW); } void forward(int fspeed) { digitalWrite(in1, HIGH); digitalWrite(in2, LOW); analogWrite(ena, fspeed); } void backward(int bspeed) { digitalWrite(in1, LOW); digitalWrite(in2, HIGH); analogWrite(ena, bspeed); } void setup() { pinMode(in1, OUTPUT); // connection to L298n pinMode(in2, OUTPUT); // connection to L298n pinMode(ena, OUTPUT); // connection to L298n servo1.attach(3); delay(50); radio.begin(); radio.openReadingPipe(1,pipe); radio.startListening(); } void loop() { if (radio.available())radio.read(msg, 1); if (msg[0] <127 && msg[0] >-1)data = msg[0], pos = map(data, 0, 126, 7, 67),servo1.write(pos); if (msg[0] >=128 && msg[0] <=189)data = msg[0], bspeed = map(data, 255, 201, 0, 255), backward(bspeed); if (msg[0] >=201 && msg[0] <=255)data = msg[0], fspeed = map(data, 189, 128, 0, 255), forward(fspeed); if (msg[0] >190 && msg[0] <200)data = msg[0], stop(); } З.Ы. Win 7, IDE 1.6.11 - если имя пользователя латиницей, компилируется скетч из первого поста, если кириллицей, только при предварительном объявлении\определении функций. Историческую связь вижу в этом я - сперва "Иду на вы", опосля - Шит на вратах Царьграда.
Код (C++): if (msg[0] <127 && msg[0] >-1)data = msg[0], pos = map(data, 0, 126, 7, 67),servo1.write(pos); это работать будет, но совсем не так, как задумано.
