Web + реле
Тема в разделе "Arduino & Shields", создана пользователем jks123, 18 мар 2014.
  1. jks123
    jks123 Нерд
    увы знаний не хватает, но спасибо. попробую конечно как то в кучу слепить
  2. jks123
    jks123 Нерд
    #include "etherShield.h"
    #include "ETHER_28J60.h"
    int DPin3 = 3;
    int DPin4 = 4;
    int DPin5 = 5;
    int DPin6 = 6;
    int DPin7 = 7;
    int DPin8 = 8;
    int DPin9 = 9;
    static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24}; // this just needs to be unique for your network,
    static uint8_t ip[4] = {192, 168, 1, 100}; // IP address for the webserver
    static uint16_t port = 80; // Use port 80 - the standard for HTTP
    ETHER_28J60 e;
      e.setup(mac, ip, port);
      pinMode(DPin3, OUTPUT);
      pinMode(DPin4, OUTPUT);
      pinMode(DPin5, OUTPUT);
      pinMode(DPin6, OUTPUT);
      pinMode(DPin7, OUTPUT);
      pinMode(DPin8, OUTPUT);
      pinMode(DPin9, OUTPUT);
      char* params;
      if (params = e.serviceRequest())
        e.print("<H1>JKS home</H1>");
        if (strcmp(params, "?led1=on") == 0)
          if (!digitalRead(DPin4))
            digitalWrite(DPin4, HIGH);
        else if (strcmp(params, "?led2=on") == 0)
          if (!digitalRead(DPin5))
            digitalWrite(DPin5, HIGH);
        else if (strcmp(params, "?led3=on") == 0)
          if (!digitalRead(DPin6))
            digitalWrite(DPin6, HIGH);
        else if (strcmp(params, "?led4=on") == 0)
          if (!digitalRead(DPin7))
            digitalWrite(DPin7, HIGH);
        else if (strcmp(params, "?led5=on") == 0)
          if (!digitalRead(DPin8))
            digitalWrite(DPin8, HIGH);
        else if (strcmp(params, "?led6=on") == 0)
          if (!digitalRead(DPin9))
            digitalWrite(DPin9, HIGH);
        else if (strcmp(params, "?led7=on") == 0)
          if (!digitalRead(DPin3))
            digitalWrite(DPin3, HIGH);
        else if (strcmp(params, "?led1=off") == 0)// Modified -- 2011 03 15 # Ben Schueler
          if (digitalRead(DPin4))
            digitalWrite(DPin4, LOW);
        else if (strcmp(params, "?led2=off") == 0)// Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin5))
            digitalWrite(DPin5, LOW);
        else if (strcmp(params, "?led3=off") == 0)// Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin6))
            digitalWrite(DPin6, LOW);
        else if (strcmp(params, "?led4=off") == 0)// Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin7))
            digitalWrite(DPin7, LOW);
        else if (strcmp(params, "?led5=off") == 0) // Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin8))
            digitalWrite(DPin8, LOW);
        else if (strcmp(params, "?led6=off") == 0) // Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin9))
            digitalWrite(DPin9, LOW);
        else if (strcmp(params, "?led7=off") == 0) // Modified -- 2014 03 15 # Ben Schueler
          if (digitalRead(DPin3))
            digitalWrite(DPin3, LOW);
          e.print("<a href='?led1=off'><button style='border: 1px solid #ff0000; border-left: 10px solid #ff0000' type='button'>Printer ON</button></a>");
        else
          e.print("<a href='?led1=on'><button style='border: 1px solid #000; border-left: 10px solid #000' type='button'>Printer OFF</button></a>");
          e.print("<h1><a href='?led2=off'><button style='border: 1px solid #ff0000; border-left: 10px solid #ff0000' type='button'>LED 2 ON</button></a><h1>");
        else
          e.print("<h1><a href='?led2=on'><button style='border: 1px solid #000; border-left: 10px solid #000' type='button'>LED 2 OFF</button></a><h1>");
          e.print("<h1><a href='?led3=off'><button style='border: 1px solid #ff0000; border-left: 10px solid #ff0000' type='button'>LED 3 ON</button></a><h1>");
        else
          e.print("<h1><a href='?led3=on'><button style='border: 1px solid #000; border-left: 10px solid #000' type='button'>LED 3 OFF</button></a><h1>");
        e.respond();
        delay(50);
  3. jks123
    jks123 Нерд
    рабочий на 7 выходов, 3 веб кнопки, остальное только через адресс. Хелп, как добавить кнопок? при добавлении в таком виде то нано виснет.
  4. Alex19
    Alex19 Гуру
    Извините, немного выбыл из темы, последние 2 дня, покупал осциллограф + др у друга. Сейчас изучаю его.
    Попробую глянуть, но с первого взгляда, вроде норм. Даже как-то странно.
  5. jks123
    jks123 Нерд
    кстати на кану думал с китая осцилограф с генератором частоты в одной коробке взять, но в связи с калапсом приостановил закупки.
  6. Alex19
    Alex19 Гуру
    Попробуйте этот код, если он заработает, можно будет строить предположения
    int DPin3 = 3;
    int DPin4 = 4;
    int DPin5 = 5;
    int DPin6 = 6;
    int DPin7 = 7;
    int DPin8 = 8;
    int DPin9 = 9;
    ETHER_28J60 e;
      char* params;
        else
        else
        else
        else
        else
        e.respond();
        delay(100);
    Не боитесь, вдруг бракованный или повредят при транспортировке
    UPD.
    Это Вы о чем?
  7. Megakoteyka
    Megakoteyka Оракул Модератор
    Давайте будем подобные вопросы обсуждать в личке. Не надо засорять Амперку политикой.
  8. jks123
    jks123 Нерд
    такая же ситуация с Вашим кодом, в вебке только три кнопки нажать низя, через адрес можно включить 5 выходов и потом полностью висит
  9. Megakoteyka
    Вставляйте в код вывод отладочных сообщений и анализируйте, в каком именно месте происходит зависание.
    Alex19 нравится это.
  10. jks123
    jks123 Нерд
    пардон, эт кукисы -кнопок нет вообще. включение через адрес
  11. jks123
    jks123 Нерд
    Сори за тупость, а как?
  12. Alex19
    Alex19 Гуру
    Сочувствую у самого много друзей и знакомых там.
    Будем исправятся.
    Очень странно. Все что было добавлено к Вашему последнему коду, это всего лишь кнопки. При этом я сознательно добавлял с пином 6, как проверенный. Даже не знаю, за что ухватится.
    Да наверно только так, можно вставлять Serial.println("0"), Serial.println("1") и т.д.
    Еще как вариант.
    Может быть дело в нестабильной библиотеки. Как вариант, попробовать поискать другие, просто ума не приложу, что может быть еще.
  13. Alex19
    Alex19 Гуру
    Сейчас сделаю
  14. jks123
    jks123 Нерд
    ладно, попробую библиотеки новее
  15. Alex19
    Alex19 Гуру
    int DPin3 = 3;
    int DPin4 = 4;
    int DPin5 = 5;
    int DPin6 = 6;
    int DPin7 = 7;
    int DPin8 = 8;
    int DPin9 = 9;
    ETHER_28J60 e;
      char* params;
        Serial.println("1");
          Serial.println("2");
            Serial.println("3");
          Serial.println("4");
            Serial.println("5");
          Serial.println("6");
            Serial.println("7");
          Serial.println("8");
            Serial.println("9");
          Serial.println("10");
            Serial.println("11");
          Serial.println("12");
            Serial.println("13");
          Serial.println("14");
            Serial.println("15");
          Serial.println("16");
            Serial.println("17");
          Serial.println("18");
            Serial.println("19");
          Serial.println("20");
            Serial.println("21");
          Serial.println("22");
            Serial.println("23");
          Serial.println("24");
            Serial.println("25");
          Serial.println("26");
            Serial.println("27");
          Serial.println("28");
            Serial.println("29");
          Serial.println("30");
        else
          Serial.println("31");
          Serial.println("32");
        else
          Serial.println("33");
          Serial.println("34");
        else
          Serial.println("35");
          Serial.println("36");
        else
          Serial.println("37");
          Serial.println("38");
        else
          Serial.println("39");
        e.respond();
        Serial.println("40");
        delay(100);
      Serial.println("41");
      delay(40);
  16. Alex19
    Alex19 Гуру
    Заливаете код, открываете монитор порта. Открываете страницу в браузере.
    И смотрите, что приходит.
    Если ардуина повиснет, то передача прекратится.
    По цифрам, можно увидеть последнюю операцию, которая прошла успешно.
    Это общая схема отладки, но ступил, спасибо Megakoteyka напомнил.
    Включается сериал Serial.begin(9600); в setup и потом после каждой операции прописывается Serial.println
    с цифрой к примеру, для понимания, где происходит остановка.
    UPD. В Serial.println можно так же вставлять переменные, константы и тем самым проверять их значения. Не удобный, но все же способ отладки.
    Сам ищу нормальный как в C#. Но, все что нашел, только под AVR на котом построены почти все ардуины, но там знаний пока не хватает.
  17. Megakoteyka
    Можно выводить разбираемую строку и вставлять в ветки условий вывод строчек с описанием сработавшего условия.
    Просто "0" и "1" не особо информативно, лучше "что-то случилось".
    Есть классический подход к отладке программ с использованием условной компиляции.
    В начале программы определяем метку DEBUG
    #define DEBUG
    В "интересных" местах кода вставляем
    #if(DEBUG)
    Serial.println("программа сделала то-то и то-то");
    #endif
    Теперь мы можем просматривать лог работы программы в мониторе последовательного порта.
    Если закомментируем объявление метки DEBUG, компилятор пропустит весь код, находящийся между #if(DEBUG) и #endif и мы получим версию программы без логов.
  18. jks123
    jks123 Нерд
    41 безконечно. в браузере пусто
  19. jks123
    jks123 Нерд
    может контроллер косячный?!
  20. Alex19
    Alex19 Гуру
    Открываете страницу в браузере, я не правильно выразился.
    Сделайте запрос, попробуйте включить какой-то пин
