По мотивам статьи из журнала Linux Format. Вывод посредством midi. Код (C): #define MAXPADS 4 int STAGE0 = 8; int STAGE1 = 12; int speakerOut = 12; int val = 0 ; int piezoStart[] = {0,0,0,0}; int piezoIn[] = {0,1,2,3}; int piezoState[] = {0,0,0,0}; void setup() { pinMode(speakerOut, OUTPUT); for (int i=0; i<MAXPADS; i++) { pinMode(piezoIn[i], INPUT); } // Set MIDI baud rate: Serial.begin(31250); } void playDrum(int drum) { switch (drum) { case 0: //break; noteOn(0x99, 0x24, 0x7F); delay(200); break; case 1: break; //noteOn(0x99, 0x24, 0x7F); delay(100); break; case 2: // break; noteOn(0x99, 0x31, 0x7F); delay(100); break; case 3: noteOn(0x99, 0x28, 0x7F); delay(200); break; case 4: break; //noteOn(0x99, 0x33, 0x7F); delay(100); break; case 5: break; //noteOn(0x99, 0x33, 0x7F); delay(100); break; } } // plays a MIDI note. Doesn't check to see that // cmd is greater than 127, or that data values are less than 127: void noteOn(int cmd, int pitch, int velocity) { Serial.write(cmd); Serial.write(pitch); Serial.write(velocity); } void loop(){ STAGE0 = abs(analogRead(5) / 64); STAGE1 = abs(STAGE0 * 1.5); for (int i=0; i<MAXPADS; i++) { val = analogRead(piezoIn[i]); if(( val >= STAGE0) && (piezoState[i] == false)) { piezoState[i] = true; piezoStart[i] = val; } else if ( ((val - piezoStart[i]) > STAGE1) && (piezoState[i] == true)) { piezoState[i] = false; playDrum(i); } else if ((piezoState[i] == true) && ( val < STAGE0)) { piezoState[i] = false; } } delay(1); }
