Приветствую! Пытаюсь запустить libcamera-hello на своём RPI 3, но безуспешно. Имею следующее: Камера: Raspberry Pi High Quality Camera (Sony IMX477) ОС: Linux raspberrypi 5.10.63-v7+ #1459 SMP Wed Oct 6 16:41:10 BST 2021 armv7l GNU/Linux Содержимое config.txt: Код (Text): # For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. framebuffer_width=1600 framebuffer_height=900 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on # Automatically load overlays for detected cameras camera_auto_detect=1 # Automatically load overlays for detected DSI displays display_auto_detect=1 # Enable DRM VC4 V3D driver #dtoverlay=vc4-fkms-v3d #max_framebuffers=2 # Disable compensation for displays with overscan disable_overscan=1 [cm4] # Enable host mode on the 2711 built-in XHCI USB controller. # This line should be removed if the legacy DWC2 controller is required # (e.g. for USB device mode) or if USB support is not required. otg_mode=1 [all] [pi4] # Run as fast as firmware / board allows arm_boost=1 [all] Когда запускаю "libcamera-hello", как сказано тут https://www.raspberrypi.com/documentati ... ng-started, в разделе "Getting Started" в консоле получаю это: Код (Bash): pi@raspberrypi:~ $ libcamera-hello libEGL warning: DRI2: failed to authenticate [0:00:54.255291645] [1164] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3156-f4070274 [0:00:54.282229926] [1178] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx477' [0:00:54.282366645] [1178] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database [0:00:54.391040343] [1164] INFO Camera camera.cpp:937 configuring streams: (0) 2028x1520-YUV420 [0:00:54.391294353] [1178] INFO RPI raspberrypi.cpp:122 Mode: 1332x990 fmt RG10 Score: 3956.22 (best 3956.22) [0:00:54.391447947] [1178] INFO RPI raspberrypi.cpp:122 Mode: 4056x3040 fmt RG12 Score: 1387 (best 1387) [0:00:54.391505551] [1178] INFO RPI raspberrypi.cpp:122 Mode: 2028x1520 fmt RG12 Score: 500 (best 500) [0:00:54.391558624] [1178] INFO RPI raspberrypi.cpp:122 Mode: 2028x1080 fmt RG12 Score: 1583.84 (best 500) [0:00:54.391614301] [1178] INFO RPI raspberrypi.cpp:122 Mode: 1332x990 fmt pRAA Score: 3456.22 (best 500) [0:00:54.391670968] [1178] INFO RPI raspberrypi.cpp:122 Mode: 4056x3040 fmt pRCC Score: 887 (best 500) [0:00:54.391723676] [1178] INFO RPI raspberrypi.cpp:122 Mode: 2028x1520 fmt pRCC Score: 0 (best 0) [0:00:54.391775083] [1178] INFO RPI raspberrypi.cpp:122 Mode: 2028x1080 fmt pRCC Score: 1083.84 (best 0) [0:00:54.392012531] [1178] INFO RPI raspberrypi.cpp:620 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected mode: 2028x1520-pRCC [0:00:54.454541906] [1178] ERROR V4L2 v4l2_videodevice.cpp:1165 /dev/video15[19:cap]: Not enough buffers provided by V4L2VideoDevice [0:00:54.454926958] [1178] ERROR RPI raspberrypi.cpp:817 Failed to allocate buffers Также открывается чёрное окно и более ничего не происходит... Для соединения к RPI используется VNC Viewer. Как решить?
