Добрый день, имеется SD карта и GSM SIM800c модем пытаюсь отправить файл 1.txt Ошибка +FTPPUT: 1,64 Выходит ... подскажите в чем проблемка? Код (C++): #include <SPI.h> #include <SD.h> #include <SoftwareSerial.h> char* file_name1 = "1.txt"; // имя файла прикрепляемого char char_buffer; String string_buffer = ""; int buffer_space = 1000; File dataFile; SoftwareSerial mySerial(6, 7); void setup() { Serial.begin(19200); mySerial.begin(19200); pinMode(10, OUTPUT); if (!SD.begin(10)) { Serial.println("Initialization failed!"); return; while(true); }else { Serial.println("Initialization done."); } dataFile = SD.open(file_name1); if (dataFile) { Serial.println("Opening the file: " + String(file_name1) + " done."); }else { Serial.println("Error opening " + String(file_name1)); while(true); } Serial.println("Starting..."); Serial.println("Starting..."); gprs_modem_function (); Serial.println("The end..."); } void loop() { // put your main code here, to run repeatedly: } byte gprs_modem_function (){ byte reply = 1; int i = 0; while (i < 10 && reply == 1){ //Try 10 times... reply = sendATcommand("AT+CREG?","+CREG: 0,1","ERROR", 1000); i++; delay(1000); } if (reply == 0){ reply = sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"","OK","ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+SAPBR=3,1,\"APN\",\"internet.mts.ru\"", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+SAPBR=3,1,\"USER\",\"mts\"", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+SAPBR=3,1,\"PWD\",\"mts\"", "OK", "ERROR", 1000); if (reply == 0){ reply = 2; i = 0; while (i < 3 && reply == 2){ //Try 3 times... reply = sendATcommand("AT+SAPBR=1,1", "OK", "ERROR", 10000); if (reply == 2){ sendATcommand("AT+SAPBR=0,1", "OK", "ERROR", 10000); } i++; } if (reply == 0){ reply = sendATcommand("AT+SAPBR=2,1", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+FTPCID=1", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+FTPMODE=1", "OK", "ERROR", 1000); // Пассивный режим (1) Активный режим (0) if (reply == 0){ reply = sendATcommand("AT+FTPSERV=\"118.24.21.103\"", "OK", "ERROR", 1000); //сервер фтп, можно как айпи указать так и адрес типа ftp.tra-ta-ta.com if (reply == 0){ reply = sendATcommand("AT+FTPPORT=21", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+FTPUN=\"Ford\"", "OK", "ERROR", 1000); // Логин Ford if (reply == 0){ reply = sendATcommand("AT+FTPPW=\"Jastin\"", "OK", "ERROR", 1000); // Пароль Jastin if (reply == 0){ reply = sendATcommand("AT+FTPPUTNAME=\"" + String(file_name1) + "\"", "OK", "ERROR", 1000); if (reply == 0){ reply = sendATcommand("AT+FTPPUTPATH=\"/\"", "OK", "ERROR", 1000); if (reply == 0){ unsigned int ptime = millis(); reply = sendATcommand("AT+FTPPUT=1", "+FTPPUT: 1,1", "+FTPPUT: 1,6", 60000); Serial.println("Time: " + String(millis() - ptime)); if (reply == 0){ if (dataFile) { int i = 0; while (dataFile.available()>0) { char_buffer = dataFile.read(); string_buffer.concat(char_buffer); i++; if (i == buffer_space) { sendATcommand("AT+FTPPUT=2," + String(buffer_space), "AT+FTPPUT=2,10", "ERROR", 1000); sendATcommand(string_buffer, "OK", "ERROR", 5000); string_buffer = ""; i = 0; } } if (string_buffer != ""){ sendATcommand("AT+FTPPUT=2," + String(i), "AT+FTPPUT=2,10", "ERROR", 1000); sendATcommand(string_buffer, "OK", "ERROR", 5000); sendATcommand("AT+FTPPUT=2,0", "OK", "ERROR", 1000); } dataFile.close(); } } } } } } } } } } } } } } } } } return reply; } byte sendATcommand(String ATcommand, String answer1, String answer2, unsigned int timeout){ byte reply = 1; String content = ""; char character; //Clean the modem input buffer while(mySerial.available()>0) mySerial.read(); //Send the atcommand to the modem mySerial.println(ATcommand); delay(100); unsigned int timeprevious = millis(); while((reply == 1) && ((millis() - timeprevious) < timeout)){ while(mySerial.available()>0) { character = mySerial.read(); content.concat(character); Serial.print(character); delay(10); } //Stop reading conditions if (content.indexOf(answer1) != -1){ reply = 0; }else if(content.indexOf(answer2) != -1){ reply = 2; }else{ //Nothing to do... } } return reply; }
