Всё очень просто: Код (Text): Не могу сохранить файл настроек сборки java.io.FileNotFoundException: C:\Users\916C~1\AppData\Local\Temp\build1094674835637434401.tmp\Bluetooth.cpp (Системе не удается найти указанный путь) at java.io.FileOutputStream.open0(Native Method) at java.io.FileOutputStream.open(FileOutputStream.java:270) at java.io.FileOutputStream.<init>(FileOutputStream.java:213) at java.io.FileOutputStream.<init>(FileOutputStream.java:162) at processing.app.debug.Compiler.preprocess(Compiler.java:1217) at processing.app.debug.Compiler.preprocess(Compiler.java:1177) at processing.app.debug.Compiler.compile(Compiler.java:354) at processing.app.debug.Compiler.build(Compiler.java:116) at processing.app.Sketch.build(Sketch.java:1162) at processing.app.Sketch.exportApplet(Sketch.java:1180) at processing.app.Sketch.exportApplet(Sketch.java:1166) at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487) at java.lang.Thread.run(Thread.java:745) java.lang.NullPointerException at processing.app.debug.Compiler.adviseDuplicateLibraries(Compiler.java:442) at processing.app.debug.Compiler.build(Compiler.java:123) at processing.app.Sketch.build(Sketch.java:1162) at processing.app.Sketch.exportApplet(Sketch.java:1180) at processing.app.Sketch.exportApplet(Sketch.java:1166) at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487) at java.lang.Thread.run(Thread.java:745) Как с этим бороться?
