Здравствуйте помогите переделать программу под этот монохромный дисплей: 128X64 I2C SSD1306. Код (C++): #include <SPI.h> #include <Wire.h> #include <Adafruit_GFX.h> #include <Adafruit_SSD1331.h> #define UP_BUTTON 2 #define DOWN_BUTTON 3 // Color definitions #define BLACK 0x0000 #define BLUE 0x001F #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF const unsigned long PADDLE_RATE = 33; const unsigned long BALL_RATE = 20; const uint8_t PADDLE_HEIGHT = 24; int MAX_SCORE = 8; int CPU_SCORE = 0; int PLAYER_SCORE = 0; // You can use any (4 or) 5 pins #define sclk 13 #define mosi 11 #define cs 10 #define rst 9 #define dc 8 // MOSI is Data pin on display breakout Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, rst); void drawCourt(); uint8_t ball_x = 64, ball_y = 32; uint8_t ball_dir_x = 1, ball_dir_y = 1; boolean gameIsRunning = true; boolean resetBall = false; static const unsigned char pong []PROGMEM = { 0xff,0xe0,0x0,0x3f,0x80,0x7,0xe0,0x7,0xc0,0x3,0xfc,0x0, 0xff,0xf8,0x1,0xff,0xe0,0x7,0xf0,0x7,0xc0,0x1f,0xff,0x0, 0xff,0xfc,0x3,0xff,0xf0,0x7,0xf0,0x7,0xc0,0x3f,0xff,0x0, 0xff,0xfe,0x7,0xff,0xf8,0x7,0xf8,0x7,0xc0,0xff,0xff,0x0, 0xf8,0x7f,0xf,0xff,0xfc,0x7,0xfc,0x7,0xc0,0xff,0xff,0x0, 0xf8,0x3f,0xf,0xe0,0xfe,0x7,0xfc,0x7,0xc1,0xfc,0x7,0x0, 0xf8,0x1f,0x1f,0x80,0x7e,0x7,0xfe,0x7,0xc3,0xf8,0x1,0x0, 0xf8,0x1f,0x1f,0x0,0x3e,0x7,0xfe,0x7,0xc3,0xf0,0x0,0x0, 0xf8,0x1f,0x3f,0x0,0x3f,0x7,0xdf,0x7,0xc7,0xe0,0x0,0x0, 0xf8,0x1f,0x3e,0x0,0x1f,0x7,0xdf,0x87,0xc7,0xc0,0x0,0x0, 0xf8,0x3f,0x3e,0x0,0x1f,0x7,0xcf,0x87,0xc7,0xc1,0xff,0x80, 0xf8,0x7e,0x3e,0x0,0x1f,0x7,0xc7,0xc7,0xc7,0xc1,0xff,0x80, 0xff,0xfe,0x3e,0x0,0x1f,0x7,0xc7,0xe7,0xc7,0xc1,0xff,0x80, 0xff,0xfc,0x3e,0x0,0x1f,0x7,0xc3,0xe7,0xc7,0xc1,0xff,0x80, 0xff,0xf8,0x3e,0x0,0x1f,0x7,0xc1,0xf7,0xc7,0xc0,0xf,0x80, 0xff,0xe0,0x3f,0x0,0x3f,0x7,0xc1,0xf7,0xc7,0xe0,0xf,0x80, 0xf8,0x0,0x1f,0x0,0x3e,0x7,0xc0,0xff,0xc3,0xe0,0xf,0x80, 0xf8,0x0,0x1f,0x80,0x7e,0x7,0xc0,0x7f,0xc3,0xf0,0xf,0x80, 0xf8,0x0,0x1f,0xc0,0xfc,0x7,0xc0,0x7f,0xc3,0xfc,0xf,0x80, 0xf8,0x0,0xf,0xff,0xfc,0x7,0xc0,0x3f,0xc1,0xff,0xff,0x80, 0xf8,0x0,0x7,0xff,0xf8,0x7,0xc0,0x3f,0xc0,0xff,0xff,0x80, 0xf8,0x0,0x3,0xff,0xf0,0x7,0xc0,0x1f,0xc0,0x7f,0xff,0x80, 0xf8,0x0,0x1,0xff,0xe0,0x7,0xc0,0xf,0xc0,0x3f,0xff,0x0, 0xf8,0x0,0x0,0x7f,0x0,0x7,0xc0,0xf,0xc0,0x7,0xf8,0x0 }; static const unsigned char game []PROGMEM ={ 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0xff,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xc3,0xff,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0xf,0xc3,0xff,0x80, 0x0,0x0,0x0,0x0,0x3,0xe0,0xf,0xc3,0xe0,0x0, 0x0,0x0,0x0,0x0,0x7,0xf0,0x1f,0xc1,0xe0,0x0, 0x0,0x0,0x0,0xf8,0x7,0xf0,0x1f,0xc1,0xe0,0x0, 0x0,0xfc,0x1,0xfc,0x7,0xf8,0x1f,0xc1,0xe0,0x0, 0x7,0xfc,0x1,0xfc,0x3,0xf8,0x1f,0xe1,0xff,0x80, 0x1f,0xfc,0x1,0xde,0x3,0xbc,0x3d,0xe1,0xff,0x80, 0x3f,0xfe,0x1,0xde,0x3,0xbc,0x39,0xe1,0xff,0x80, 0x7e,0x0,0x3,0xdf,0x3,0xde,0x39,0xe1,0xfc,0x0, 0x7c,0x0,0x3,0xcf,0x3,0xde,0x39,0xe1,0xe0,0x0, 0xf8,0x0,0x3,0xcf,0x3,0xcf,0x39,0xe1,0xf0,0x0, 0xf8,0x0,0x3,0x87,0x83,0xcf,0x79,0xe0,0xf0,0x0, 0xf0,0x7f,0x7,0x87,0x83,0xc7,0xf1,0xe0,0xf0,0xe0, 0xf0,0xff,0x7,0x83,0xc3,0xc7,0xf1,0xe0,0xff,0xe0, 0xf0,0xff,0x7,0xff,0xc1,0xc3,0xf1,0xf0,0xff,0xe0, 0xf0,0xff,0x7,0xff,0xe1,0xc3,0xf0,0xf0,0xff,0xe0, 0xf8,0xf,0xf,0xff,0xe1,0xc1,0xe0,0xf0,0xe0,0x0, 0xf8,0xf,0x8f,0x1,0xf1,0xe1,0xe0,0xf0,0x0,0x0, 0x7c,0xf,0x8f,0x0,0xf1,0xe1,0xe0,0x0,0x0,0x0, 0x7f,0x1f,0x8f,0x0,0xf9,0xc0,0x0,0x0,0x0,0x0, 0x3f,0xff,0x9f,0x0,0x0,0x0,0x0,0x0,0x0,0x0, 0x1f,0xff,0x1f,0x0,0x0,0x0,0x0,0x0,0x0,0x0, 0x7,0xfc,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0 }; unsigned long ball_update; unsigned long paddle_update; const uint8_t CPU_X = 12; uint8_t cpu_y = 16; const uint8_t PLAYER_X = 85; uint8_t player_y = 16; void setup() { pinMode(UP_BUTTON, INPUT_PULLUP); pinMode(DOWN_BUTTON, INPUT_PULLUP); display.begin(); display.fillScreen(BLACK); display.drawBitmap(3,0,pong,89,24,GREEN); display.drawBitmap(10,30,game,75,26,RED); while(digitalRead(UP_BUTTON) == HIGH && digitalRead(DOWN_BUTTON) == HIGH) { delay(100); } unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; ball_x = random(25,65); ball_y = random(3,63); } void loop() { unsigned long time = millis(); static bool up_state = false; static bool down_state = false; up_state |= (digitalRead(UP_BUTTON) == LOW); down_state |= (digitalRead(DOWN_BUTTON) == LOW); if(resetBall) { ball_x = random(25,70); ball_y = random(3,63); do { ball_dir_x = random(-1,2); }while(ball_dir_x==0); do { ball_dir_y = random(-1,2); }while(ball_dir_y==0); resetBall=false; } if(time > ball_update && gameIsRunning) { uint8_t new_x = ball_x + ball_dir_x; uint8_t new_y = ball_y + ball_dir_y; // Check if we hit the vertical walls if(new_x == 0) //Player Gets a Point { PLAYER_SCORE++; if(PLAYER_SCORE==MAX_SCORE) { gameOver(); }else { showScore(); } } // Check if we hit the vertical walls if(new_x == 95) //CPU Gets a Point { CPU_SCORE++; if(CPU_SCORE==MAX_SCORE) { gameOver(); }else { showScore(); } } // Check if we hit the horizontal walls. if(new_y == 0 || new_y == 63) { ball_dir_y = -ball_dir_y; new_y += ball_dir_y + ball_dir_y; } // Check if we hit the CPU paddle if(new_x == CPU_X && new_y >= cpu_y && new_y <= cpu_y + PADDLE_HEIGHT) { ball_dir_x = -ball_dir_x; new_x += ball_dir_x + ball_dir_x; } // Check if we hit the player paddle if(new_x == PLAYER_X && new_y >= player_y && new_y <= player_y + PADDLE_HEIGHT) { ball_dir_x = -ball_dir_x; new_x += ball_dir_x + ball_dir_x; } display.drawPixel(ball_x, ball_y, BLACK); display.drawPixel(new_x, new_y, WHITE); ball_x = new_x; ball_y = new_y; ball_update += BALL_RATE; } if(time > paddle_update && gameIsRunning) { paddle_update += PADDLE_RATE; // CPU paddle display.drawFastVLine(CPU_X, cpu_y,PADDLE_HEIGHT, BLACK); const uint8_t half_paddle = PADDLE_HEIGHT >> 1; if(cpu_y + half_paddle > ball_y) { cpu_y -= 1; } if(cpu_y + half_paddle < ball_y) { cpu_y += 1; } if(cpu_y < 1) cpu_y = 1; if(cpu_y + PADDLE_HEIGHT > 63) cpu_y = 63 - PADDLE_HEIGHT; display.drawFastVLine(CPU_X, cpu_y, PADDLE_HEIGHT, RED); // Player paddle display.drawFastVLine(PLAYER_X, player_y,PADDLE_HEIGHT, BLACK); if(up_state) { player_y -= 1; } if(down_state) { player_y += 1; } up_state = down_state = false; if(player_y < 1) player_y = 1; if(player_y + PADDLE_HEIGHT > 63) player_y = 63 - PADDLE_HEIGHT; display.drawFastVLine(PLAYER_X, player_y, PADDLE_HEIGHT, GREEN); } } void drawCourt() { display.drawRect(0, 0, 96, 64, WHITE); } void gameOver() { gameIsRunning = false; display.fillScreen(BLACK); drawCourt(); if(PLAYER_SCORE>CPU_SCORE) { display.setCursor(5,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("You Won"); }else { display.setCursor(5,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("CPU WON"); } display.setCursor(20,30); display.setTextColor(RED); display.setTextSize(3); display.print(String(CPU_SCORE)); display.setCursor(60,30); display.setTextColor(GREEN); display.setTextSize(3); display.print(String(PLAYER_SCORE)); delay(2000); while(digitalRead(UP_BUTTON) == HIGH && digitalRead(DOWN_BUTTON) == HIGH) { delay(100); } gameIsRunning = true; CPU_SCORE = PLAYER_SCORE = 0; unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; gameIsRunning = true; resetBall=true; } void showScore() { gameIsRunning = false; display.fillScreen(BLACK); drawCourt(); display.setCursor(15,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("Score"); display.setCursor(20,30); display.setTextColor(RED); display.setTextSize(3); display.print(String(CPU_SCORE)); display.setCursor(60,30); display.setTextColor(GREEN); display.setTextSize(3); display.print(String(PLAYER_SCORE)); delay(2000); unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; gameIsRunning = true; resetBall=true; }
