Подскажите пожалуйста. Имеется следующее железо ArduinoMega + Ethernet Shield W5100 + фоторезистор. Мини задача - создать сервер, что бы можно было контролировать состояние освещенности с любого устройства по интернету. Переделал пример в следующий скетч: Код (C++): [code] #include <SPI.h> #include <Ethernet.h> #include <Wire.h> #include <TimeLib.h> #include <DS1307RTC.h> // Enter a MAC address and IP address for your controller below. // The IP address will be dependent on your local network: byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; IPAddress ip(192, 168, 1, 177); // Initialize the Ethernet server library // with the IP address and port you want to use // (port 80 is default for HTTP): EthernetServer server(80); void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } // start the Ethernet connection and the server: Ethernet.begin(mac, ip); server.begin(); Serial.print("server is at "); Serial.println(Ethernet.localIP()); } void loop() { // listen for incoming clients EthernetClient client = server.available(); if (client) { Serial.println("new client"); // an http request ends with a blank line boolean currentLineIsBlank = true; while (client.connected()) { if (client.available()) { char c = client.read(); Serial.write(c); // if you've gotten to the end of the line (received a newline // character) and the line is blank, the http request has ended, // so you can send a reply if (c == '\n' && currentLineIsBlank) { // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Connection: close"); // the connection will be closed after completion of the response client.println(); client.println("<!DOCTYPE HTML>"); client.println("<html>"); client.println("<meta http-equiv='refresh' content='5'/>"); client.println("<meta http-equiv='content-type' content='text/html; charset=UTF-8'>"); client.println("<title>Сервер датчика освещенности</title>"); int sensePin = 0; int val = analogRead(sensePin); val = constrain(val, 650, 975); int sdv = map(val,650,975,1,0); client.print("Состояние освещенности = "); client.print(sdv); client.println("<br />"); client.println("</html>"); break; } if (c == '\n') { // you're starting a new line currentLineIsBlank = true; } else if (c != '\r') { // you've gotten a character on the current line currentLineIsBlank = false; } } } // give the web browser time to receive the data delay(1); // close the connection: client.stop(); Serial.println("client disconnected"); } } Суть вопроса в следующем. Когда ардуинка питается от USBподключенному к компьютеру на котором осуществляется просмотр порта через ArduinoIDE показания фоторезистора можно наблюдать в браузере по заданному IP. Когда запитываю ардуинку от блока питания, показания фоторезистора в браузере пропадаю и страничка по IP вообще не открывается. Подскажите где я туплю? Я ведь нуб еще)
та же проблема: Ethernet Shield W5100 подключен к роутеру, ардуинка при подключении к компу по USB шлет данные по MQTT. пробовал подключать отдельным питанием (не от компа) через штыревой разъем, через микро usb с подключением к зарядке от телефона на 2А. результата нет. только при подключении микро USB - USB компа работает. проблема с самим шилдом или кривыми руками (кодом)?
У меня после нажатия кнопки reset начинает работать.http://forum.amperka.ru/threads/arduino-due-не-запускает-скетч-без-resetа.14312/
