Здравствуйте, скажите пожалуйста что делает этот код? /* * EEPROM Clear * * Sets all of the bytes of the EEPROM to 0. * This example code is in the public domain. */ #include <EEPROM.h> void setup() { // write a 0 to all 512 bytes of the EEPROM for (int i = 0; i < 512; i++) EEPROM.write(i, 0); // turn the LED on when we're done digitalWrite(13, HIGH); } void loop() { }
И этот * EEPROM Read * * Reads the value of each byte of the EEPROM and prints it * to the computer. * This example code is in the public domain. */ #include <EEPROM.h> // start reading from the first byte (address 0) of the EEPROM int address = 0; byte value; void setup() { // initialize serial and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } } void loop() { // read a byte from the current address of the EEPROM value = EEPROM.read(address); Serial.print(address); Serial.print("\t"); Serial.print(value, DEC); Serial.println(); // advance to the next address of the EEPROM address = address + 1; // there are only 512 bytes of EEPROM, from 0 to 511, so if we're // on address 512, wrap around to address 0 if (address == 512) address = 0; delay(500); } И этот /* * EEPROM Write * * Stores values read from analog input 0 into the EEPROM. * These values will stay in the EEPROM when the board is * turned off and may be retrieved later by another sketch. */ #include <EEPROM.h> // the current address in the EEPROM (i.e. which byte // we're going to write to next) int addr = 0; void setup() { } void loop() { // need to divide by 4 because analog inputs range from // 0 to 1023 and each byte of the EEPROM can only hold a // value from 0 to 255. int val = analogRead(0) / 4; // write the value to the appropriate byte of the EEPROM. // these values will remain there when the board is // turned off. EEPROM.write(addr, val); // advance to the next address. there are 512 bytes in // the EEPROM, so go back to 0 when we hit 512. addr = addr + 1; if (addr == 512) addr = 0; delay(100); }
Создание двух одинаковых тем - признак невоспитанности и засорение форума мусором. Не нужно так делать, это не прибавит форумчанам желания Вам помогать.
А темы одинаковые зачем создавать? Так не вольетесь. Вам в другой такой же теме уже ответили. Лучшее, что можно сделать - удалить вторую тему и вести обсуждение в первой.
