Ну, делайте: http://nodemcu.readthedocs.io/en/master/en/modules/net/#netcreateserver Смотрите ссылку и не болтайтесь по другим сайтам. Код (Lua): do srv = net.createServer(net.TCP) function receiver(sck, data) local response = {} -- if you're sending back HTML over HTTP you'll want something like this instead -- local response = {"HTTP/1.0 200 OK\r\nServer: NodeMCU on ESP8266\r\nContent-Type: text/html\r\n\r\n"} response[#response + 1] = "lots of data" response[#response + 1] = "even more data" response[#response + 1] = "e.g. content read from a file" -- sends and removes the first element from the 'response' table local function send(localSocket) if #response > 0 then localSocket:send(table.remove(response, 1)) else localSocket:close() response = nil end end -- triggers the send() function again once the first chunk of data was sent sck:on("sent", send) send(sck) end srv:listen(80, function(conn) conn:on("receive", receiver) end) end
