Код (C): //Jeremy Blum's Arduino Tutorial Series - Episode 12 - RFID Cards //Sample Code - RFID Security //http://www.jeremyblum.com //Some Code Adapted from http://www.cooking-hacks.com //Some code from arudino Tone Library: http://arduino.cc/en/Tutorial/Tone //Some code from my 5th Arduino Tutorial on Motor Control: http://jeremyblum.com/2011/01/31/arduino-tutorial-5-motors-and-transistors/ //Code Updated on 1/21/2012 to comply with Arduino 1.0 Changes #include <Servo.h> #include "pitches.h" byte data[5]; //For holding the ID we receive int val = 0; byte jeremy[5] = {0x3E,0x00,0xFC,0xBD,0x88}; byte david[5] = {0x3E,0x00,0xFC,0xFF,0xA5}; int j_melody[] = {NOTE_G4,0,NOTE_A4,0, NOTE_B4,0,NOTE_A4,0,NOTE_B4,0, NOTE_C5,0}; int j_noteDurations[] = {8,8,8,8,8,4,8,8,8,8,8,4}; int d_melody[] = {NOTE_C4,0,NOTE_D4,0,NOTE_F4,0,NOTE_D4,0,NOTE_F4,0,NOTE_G4,0}; int d_noteDurations[] = {8,8,8,8,8,4,8,8,8,8,8,4}; int fail_melody[] = {NOTE_G2,0,NOTE_F2,0,NOTE_D2,0}; int fail_noteDurations[] = {8,8,8,8,8,4}; int speaker_pin = 8; int servoPin = 9; //Create Servo Object Servo doorLock; void setup() { //Attaches the Servo to our object doorLock.attach(servoPin); // Start serial port 19200 bps Serial.begin(19200); // Setting Auto Read Mode - EM4102 Decoded Mode - No password // command: FF 01 09 87 01 03 02 00 10 20 30 40 37 Serial.write(0xFF); //Header Serial.write(0x01); //Reserved Serial.write(0x09); //Length (Command + Data) Serial.write(0x87); //Command (0x87 sets auto mode behavior Serial.write(0x01); //Data 1: Enable Auto-Read Serial.write(0x03); //Data 2: Mode – Parity decoded – Manchester RF/64 Serial.write(0x02); //Data 3: Total number of block to be read (2) Serial.write((byte)0x00); //Data 4: No password expected Serial.write(0x10); //Data 5: Password byte 1 Serial.write(0x20); //Data 6: Password byte 2 Serial.write(0x30); //Data 7: Password byte 3 Serial.write(0x40); //Data 8: Password byte 4 Serial.write(0x37); //Checksum delay(500); while(Serial.available()>0) { Serial.read(); } Serial.println(); Serial.println("RFID module started in Auto Read Mode, Waiting for Card..."); } void loop() { val = Serial.read(); while (val != 0xff) { //On Successful read, first byte will always be 0xFF val = Serial.read(); delay(1000); } //we already read the header (0xff) Serial.read(); // reserved Serial.read(); // length Serial.read(); // command (indicates tag data) data[0] = Serial.read(); // we read data 1 data[1] = Serial.read(); // we read data 2 data[2] = Serial.read(); // we read data 3 data[3] = Serial.read(); // we read data 4 data[4] = Serial.read(); // we read data 5 Serial.read(); // checksum // Indentify RFID Card boolean j_card = true; boolean d_card = true; Serial.print("Card found - Code: "); for (int i=0; i<5; i++) { if (data[I] < 16) Serial.print("0"); Serial.print(data[I], HEX); //cross-check if (data[I] != jeremy[I]) j_card = false; if (data[I] != david[I]) d_card = false; } Serial.println(); if (j_card) { Serial.println("Hello Jeremy!"); for (int i = 0; i < 12; i++) { int j_noteDuration = 1000/j_noteDurations[I]; tone(speaker_pin, j_melody[I],j_noteDuration); int j_pauseBetweenNotes = j_noteDuration * 1.30; delay(j_pauseBetweenNotes); noTone(speaker_pin); } } else if (d_card) { Serial.println("Hello David!"); for (int i = 0; i < 12; i++) { int d_noteDuration = 1000/d_noteDurations[I]; tone(speaker_pin, d_melody[I],d_noteDuration); int d_pauseBetweenNotes = d_noteDuration * 1.30; delay(d_pauseBetweenNotes); noTone(speaker_pin); } } else { Serial.println("Not Recognized! Get out of Here!"); for (int i = 0; i < 6; i++) { int fail_noteDuration = 1000/fail_noteDurations[I]; tone(speaker_pin, fail_melody[I],fail_noteDuration); int fail_pauseBetweenNotes = fail_noteDuration * 1.30; delay(fail_pauseBetweenNotes); noTone(speaker_pin); } } //Unlock Door for Authorized Users if (d_card || j_card) { doorLock.write(180); delay(5000); doorLock.write(0); } Serial.println(); } с какой строки не понятно?
В последовательный порт, к которому подключен RFID сканер, выдаются команды. Выдаются они побайтно. Всякая команда сканера начинается с байта 0xFF и заканчивается байтом контрольной суммы. В данном случае передается команда активации режима сканирования общей длиной 13 байт.
внесу и свои 5 копеек данная настройка требуется для RFID сканера использованного в видео уроке,а для RFID сканера который продаться в амперке этого не нужно ,он сразу готов к работе.
