Всем привет. Код рабочий, но сам по себе весь криво-косо написан. Как бы его весь привести в нормальный вид: Код (Text): #include "Wire.h" #define DS1307_I2C_ADDRESS 0x68 #include "OasisLED.h" #include <Arduino.h> #include <IRremote.h> #include <RCSwitch.h> int RECV_PIN = 11; uint8_t clockPin = 3; uint8_t strobePin = 2; uint8_t dataPin = 4; OasisLED ledDisplay = OasisLED(clockPin, strobePin, dataPin); IRrecv irrecv(RECV_PIN); decode_results results; RCSwitch mySwitch = RCSwitch(); int n=0; // переключение режимов работы byte decToBcd(byte val) { return ( (val/10*16) + (val%10) ); } byte bcdToDec(byte val) { return ( (val/16*10) + (val%16) ); } void setDateDs1307(byte second, // 0-59 byte minute, // 0-59 byte hour, // 1-23 byte dayOfWeek, // 1-7 byte dayOfMonth, // 1-28/29/30/31 byte month, // 1-12 byte year) // 0-99 { Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0); Wire.write(decToBcd(second)); Wire.write(decToBcd(minute)); Wire.write(decToBcd(hour)); Wire.write(decToBcd(dayOfWeek)); Wire.write(decToBcd(dayOfMonth)); Wire.write(decToBcd(month)); Wire.write(decToBcd(year)); Wire.endTransmission(); } void getDateDs1307(byte *second, byte *minute, byte *hour, byte *dayOfWeek, byte *dayOfMonth, byte *month, byte *year) { Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0); Wire.endTransmission(); Wire.requestFrom(DS1307_I2C_ADDRESS, 7); *second = bcdToDec(Wire.read() & 0x7f); *minute = bcdToDec(Wire.read()); *hour = bcdToDec(Wire.read() & 0x3f); *dayOfWeek = bcdToDec(Wire.read()); *dayOfMonth = bcdToDec(Wire.read()); *month = bcdToDec(Wire.read()); *year = bcdToDec(Wire.read()); } void setup() { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; Wire.begin(); ledDisplay.initialize(); Serial.begin(9600); irrecv.enableIRIn(); // Start the receiver mySwitch.enableTransmit(10); mySwitch.setPulseLength(237); second = 00; minute = 12; hour = 16; dayOfWeek = 2; dayOfMonth = 19; month = 5; year = 20; //setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year); // установка даты } void loop() { printTime(); ledDisplay.toggleColon(); delay (1000); ledDisplay.toggleColon(); delay(1000); ledDisplay.reset(); } void printTime() { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); ledDisplay.setValue(hour*100+minute); if(irrecv.decode(&results)) { //Serial.println(results.value, HEX); if ((results.value == 0x37) || (results.value == 0x10037)) { // Serial.println(results.value, HEX); ++n; // Serial.println(n); if (n>=7) n=0; } switch(n) { case 1: if ((results.value == 0x37) || (results.value == 0x10037)){ // переключение режимов работы mySwitch.send(7652288,24);} break; case 2: if ((results.value == 0x37) || (results.value == 0x10037)){// переключение режимов работы mySwitch.send(7652288,24);} break; case 3: if ((results.value == 0x37) || (results.value == 0x10037)){// переключение режимов работы mySwitch.send(7652144,24); } break; case 4: if ((results.value == 0x37) || (results.value == 0x10037)){// переключение режимов работы mySwitch.send(7652144,24); } break; case 5: if ((results.value == 0x37) || (results.value == 0x10037)){// переключение режимов работы mySwitch.send(7652288,24); delay(100); mySwitch.send(7652144,24); } break; case 6: if ((results.value == 0x37) || (results.value == 0x10037)){// переключение режимов работы mySwitch.send(7652288,24); delay(100); mySwitch.send(7652144,24); } break; } if ((results.value == 0x6E) || (results.value == 0x1006E)){ mySwitch.send(7652288,24); } if ((results.value == 0x70) || (results.value == 0x10070)){ mySwitch.send(7652144,24); } delay (500); irrecv.resume(); } } Спасибо
Я так полагаю тут нет никаких ООП, только процедруно-функциональное программирование? Тогда - да, сделаю как вы сказали.
