Проблема с плеером grove mp3 v3
Тема в разделе "Arduino & Shields", создана пользователем Ваннафлай, 1 июл 2021.
  1. Код (C++):
    #include "WT2003S_Player.h"
    #ifdef __AVR__
    #include <SoftwareSerial.h>
    SoftwareSerial SSerial(2, 3); // RX, TX
    #define COMSerial SSerial
    #define ShowSerial Serial
    WT2003S<SoftwareSerial> Mp3Player;
    #endif
    #ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
    #define COMSerial Serial1
    #define ShowSerial SerialUSB
    WT2003S<Uart> Mp3Player;
    #endif
    #ifdef ARDUINO_ARCH_STM32F4
    WT2003S<HardwareSerial> Mp3Player;
    #endif
    uint8_t vol = 10;
    uint32_t spi_flash_songs = 0;
    uint32_t sd_songs = 0;
    STROAGE workdisk = SD;
    struct Play_history {
    uint8_t disk;
    uint16_t index;
    char name[8];
    }* SPISong, *SDSong;
    void readSongName(struct Play_history* ph, uint32_t num, STROAGE disk) {
    Mp3Player.volume(0);
    delay(100);
    switch (disk) {
    case SPIFLASH:
    Mp3Player.playSPIFlashSong(0x0001);
    break;
    case SD:
    Mp3Player.playSDRootSong(0x0001);
    break;
    case UDISK:
    Mp3Player.playUDiskRootSong(0x0001);
    break;
    ShowSerial.println("2...");
    for (int i = 0; i < num ; i++) {
    delay(300);
    ph.disk = disk;
    ph.index = Mp3Player.getTracks();
    Mp3Player.getSongName(ph.name);
    Mp3Player.next();
    ShowSerial.println("4...");
    Mp3Player.pause_or_play();
    Mp3Player.volume(14);
    delay(100);
    void getAllSong() {
    uint8_t diskstatus = Mp3Player.getDiskStatus();
    ShowSerial.println(diskstatus);
    spi_flash_songs = Mp3Player.getSPIFlashMp3FileNumber();
    ShowSerial.print("SPIFlash:");
    ShowSerial.println(spi_flash_songs);
    if (spi_flash_songs > 0) {
    SPISong = (struct Play_history*)malloc((spi_flash_songs + 1) * sizeof(struct Play_history));
    readSongName(SPISong, spi_flash_songs, SPIFLASH);
    if (diskstatus && 0x02) { // have SD
    sd_songs = Mp3Player.getSDMp3FileNumber();
    ShowSerial.print("SD:");
    ShowSerial.println(sd_songs);
    if (sd_songs > 0) {
    SDSong = (struct Play_history*)malloc((sd_songs + 1) * sizeof(struct Play_history));
    ShowSerial.println("1...");
    readSongName(SDSong, sd_songs, SD);
    void printSongs() {
    ShowSerial.print("-------------------");
    ShowSerial.print("index");
    ShowSerial.print("<-------->");
    ShowSerial.print("name");
    ShowSerial.println();
    ShowSerial.println("-------------------spi flash-------------------------------");
    for (int i = 0 ; i < spi_flash_songs; i++) {
    ShowSerial.print(SPISong.index);
    ShowSerial.print(SPISong.name);
    ShowSerial.println("-------------------sd card-------------------------------");
    for (int i = 0 ; i < sd_songs; i++) {
    ShowSerial.print(SDSong.index);
    ShowSerial.print(SDSong.name);
    while (!ShowSerial);
    ShowSerial.begin(9600);
    COMSerial.begin(9600);
    ShowSerial.println("+++++++++++++++++++++++++++++++++++++++++++++++++++++");
    Mp3Player.init(COMSerial);
    ShowSerial.println("0...");
    getAllSong();
    printMenu();
    printSongs();
    if (ShowSerial.available()) {
    char cmd = ShowSerial.read();
    switch (cmd) {
    case '+': {
    ShowSerial.print("Volume up: ");
    vol = Mp3Player.getVolume();
    Mp3Player.volume(++vol);
    ShowSerial.print(vol);
    break;
    case '-': {
    ShowSerial.print("Volume down: ");
    if (--vol > 31) {
    vol = 0;
    Mp3Player.volume(vol);
    break;
    case 't': {
    uint8_t status;
    ShowSerial.print("status:");
    status = Mp3Player.getStatus();
    if (status == 0x01) {
    ShowSerial.print("playing");
    if (status == 0x02) {
    ShowSerial.print("stop");
    if (status == 0x03) {
    ShowSerial.print("pause");
    break;
    case 'n': {
    Mp3Player.next();
    break;
    case 'p': {
    break;
    case 'w': {
    Mp3Player.playMode(SINGLE_SHOT);
    break;
    case 'x': {
    Mp3Player.playMode(SINGLE_CYCLE);
    break;
    case 'y': {
    Mp3Player.playMode(CYCLE);
    break;
    case 'z': {
    Mp3Player.playMode(RANDOM);
    break;
    case 'c': {
    ShowSerial.print(Mp3Player.copySDtoSPIFlash());
    break;
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
    ShowSerial.print("play:");
    if (workdisk == SD) {
    Mp3Player.playSDRootSong(cmd - '0' - 1);
    ShowSerial.print(cmd + ": ");
    ShowSerial.print(SDSong[cmd - '0'].name);
    if (workdisk == SPIFLASH) {
    Mp3Player.playSPIFlashSong(cmd - '0' - 1);
    ShowSerial.print(SPISong[cmd - '0'].name);
    break;
    default:
    break;
    void printMenu(void) {
    ShowSerial.println("MP3 Command List:");
    ShowSerial.println("-----------------");
    ShowSerial.println("'+' or '-' : raise/lower volume");
    ShowSerial.println("'1' ~ '9' : select a song");
    ShowSerial.println("'n' : next song");
    ShowSerial.println("'s' : switch play disk, spi flash");
    ShowSerial.println("'p' : play or pause");
    ShowSerial.println("'w' : set playmode single no loop");
    ShowSerial.println("'x' : set playmode single loop");
    ShowSerial.println("'y' : set playmode all loop");
    ShowSerial.println("'z' : set playmode random");
    ShowSerial.println("'c' : Copy mp3 to SPIFlash");
    ShowSerial.println(" (Yes, this really does go by copy order.)");
    ShowSerial.println("Any other key to show this menu");
    Пытаюсь подключить Grove MP3 V3 к Ардуино леонардо. Беру код с официального сайта производителя, ничего не работает. Но один аудиофайл воспроизводится при нажатии кнопки перезапуска на плеере, он работает. Библиотеки подключены. Плата и порт выбраны.
  2. akl
    akl Гуру
    может подключил не так? к леонарде надо подключать к пинам 0 и 1, а не как к остальным где 2 и 3
    еще вариант - rx tx перепутаны
  3. пробовал по разному получается одно и то же
  4. akl
    akl Гуру
    не очень разбираюсь в леонардо, поэтому не понимаю что значит
    вроде как тот юсбишный виртуальный сериал там называется просто Serial
    попробуй удалить все эти #ifdef в начале (все что до строчки
    uint8_t vol = 10;
    и написать просто
