Реализация паузы в скетче без delay
Тема в разделе "Arduino & Shields", создана пользователем Vetrinus, 15 авг 2015.
  1. Vetrinus
    Vetrinus Гик
    Здравствуйте! Нужна помощь в реализации паузы. Вот сам скетч, сейчас объясню логику происходящего.
    #define PIN13 13
    #define PIN12 12
    #define PIN11 11
    #define PIN10 10
    #define PIN9 9
    #define Control A0
    #define PIN7 7
    #define PIN6 6
    #define PIN5 5
    #define PIN4 4
    #define PIN3 3
    //float V1 = 1.68;
    //float V2 = 2.05;
    //float V3 = 2.79;
    //float V4 = 5.0;
    void setup ()
      pinMode (PIN13, OUTPUT);
      pinMode (PIN12, OUTPUT);
      pinMode (PIN11, OUTPUT);
      pinMode (PIN10, OUTPUT);
      pinMode (PIN9, OUTPUT);
      pinMode (Control, INPUT);
      pinMode (PIN7, OUTPUT);
      pinMode (PIN6, OUTPUT);
      pinMode (PIN5, OUTPUT);
      pinMode (PIN4, OUTPUT);
      pinMode (PIN3, OUTPUT);
    void loop(){
    int SensorValue = analogRead (Control);
    float voltage = SensorValue * (5.0/1024.0);
    if (voltage>4.9 && voltage<5.1)
      digitalWrite (PIN13, LOW);
      delay (1000);
      digitalWrite (PIN12, LOW);
      delay (1000);
      digitalWrite (PIN11, LOW);
      delay (1000);
      digitalWrite (PIN10, LOW);
      delay (1000);
      digitalWrite (PIN9, LOW);
      delay (1000);
      digitalWrite (PIN7, LOW);
      delay (1000);
      digitalWrite (PIN6, LOW);
      delay (1000);
      digitalWrite (PIN5, LOW);
      delay (1000);
      digitalWrite (PIN4, LOW);
      delay (1000);
      digitalWrite (PIN3, LOW);
    if (voltage >2.7 && voltage <2.9) {
        digitalWrite (PIN13, HIGH);
      delay (1000);
      digitalWrite (PIN12, HIGH);
      delay (1000);
      digitalWrite (PIN11, HIGH);
      delay (1000);
      digitalWrite (PIN10, HIGH);
      delay (1000);
      digitalWrite (PIN9, HIGH);
        delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    if (voltage >=1.9 && voltage <2.2) {
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      digitalWrite (PIN7, HIGH);
      delay (1000);
      digitalWrite (PIN6, HIGH);
      delay (1000);
      digitalWrite (PIN5, HIGH);
      delay (1000);
      digitalWrite (PIN4, HIGH);
      delay (1000);
      digitalWrite (PIN3, HIGH);
    if (voltage >1.5 && voltage <1.8) {
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
        delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    Есть 1 управляющий канал, подключенный к аналоговому входу.
    С помощью
    Значение напряжения преобразуется в переменную типа float, которые внутри loop() сравниваются в if с заданными промежутками. Всего возможно 4 показателя напряжения, и, вследствие этого, 4 состояния диодов.
    1)
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    2)
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
        delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    3)
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    4)
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
        delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
      delay (1000);
    В зависимости от того, какой показатель действует сейчас, должна загораться определенная группа диодов.(Как это работает, можете посмотреть далее : https://123d.circuits.io/circuits/949051-the-unnamed-circuit ) Причем загораться не моментально, а с задержкой. И после того, как диоды загорелись или потухли, они не должны менять состояние в течение определенного времени. Мне нужно реализовать именно эти паузы.
    На этом моменте я, честно признаюсь, сильно забуксовал. Единственное, что пришло в голову - попробовать поиграть с millis(). Но я не знаю, будет ли он записывать правильное время, если внутри loop() есть delay.
    Если кто-то может что-либо подсказать, буду очень рад!
  2. vvr
    vvr Инженерище
    по вашей ссылке что то не очень понятно, но делеи будут просто тормозить работу дуни.
    нужно от них вообще уйти.
  3. DrProg
    DrProg Вечный нерд
    Вот бы еще научиться пользоваться циклами! Программка сразу станет маленькой и удобной.
    ИгорьК и Tomasina нравится это.
  4. Vetrinus
    Vetrinus Гик
    С помощью этих операторов делается?
  5. DrProg
    DrProg Вечный нерд
    for вполне подойдет.
    И вообще не понятно, так надо чтобы после того как загорается каждый светодиод выдерживалась пауза 1 сек? Или пауза нужна после того как загорятся все светодиоды?
    ИгорьК нравится это.
  6. Vetrinus
    Vetrinus Гик
    Обе паузы нужны. Причем как при включении, так и при выключении.
  7. Megakoteyka
    Megakoteyka Оракул Модератор
    На циклах придется delay использовать. Без delay можно сделать на конечном автомате.
  8. ИгорьК
    Здесь, наверно, класс надо писать. Апдейтить его в зависимости от показаний, а внутри класса - 4 состояния в таблице. Так?
  9. Tomasina
    Паузы между измерениями? Если во время этой паузы контролируемое напряжение изменится, то что делать?
    Аналогично, если, например, где-то в середине выполнения условия (3) напряжение изменится, то что делать? Завершить до конца последовательное включение светодиодов, или прервать?
  10. Megakoteyka
    Если программа больше ничего делать не будет, то нет смысла писать класс. Класс хорош в тех случаях, когда нужно отделить работу с некоторой сущностью от остального кода. А тут вполне достаточно автомата на switch.
  11. DrProg
    DrProg Вечный нерд
    Я вообще не понял, если все будет включаться и переключаться с задержкой, то почему бы не использовать тот же delay? Все эти millis() хороши для одновременной работы с несколькими задачами, а если все последовательно, то зачем городить огород? Вот например классический Hello World в виде мигающей лампочки можно сделать и через millis() и через прерывания по таймерам, но зачем?
  12. Vetrinus
    Vetrinus Гик
    Завершить до конца, причем гореть они должны не менее минуты, скажем. И в случае выключения тоже самое. Даже если во время выключения подается сигнал на включение, они все равно должны все последовательно выключиться, и не включаться минимум ту же минуту.
  13. Vetrinus
    Vetrinus Гик
    Столкнулся с тем, что switch сравнивает числа только в integer, в то время как voltage объявлен как float.
    Можно попробовать изменить формулу расчета (float voltage = SensorValue * (5.0/1024.0);), чтобы был integer
  14. Tomasina
    Тогда зачем вообще отказ от delay? Программа линейная, паузы жёстко фиксированы, параллельных измерений и других действий не требуется - delay тут идеально подходит.
  15. Vetrinus
    Vetrinus Гик
    Вообще, я такого же мнения, но господа Гики выше говорят, что делей ниочень. По сути меня он не устраивает только в одном. Если его просто прописать в конце каждого условия, то выглядеть это будет так. Допустим, все диоды включены, нужно все выключить, тогда: подаем 5 вольт на Control, сначала выключается 1 группа, и минуту ждем. Потом выключается вторая группа, и опять ждем минуту. При включении тоже самое. Все бы ничего, но на практике мне нужна не минута задержки, а 10 минут, причем в обоих случаях... И как это избежать, я хз. Вот, что я сейчас написал через switch case:
    #define PIN13 13
    #define PIN12 12
    #define PIN11 11
    #define PIN10 10
    #define PIN9 9
    #define Control A0
    #define PIN7 7
    #define PIN6 6
    #define PIN5 5
    #define PIN4 4
    #define PIN3 3
    //float V1 = 1.68;
    //float V2 = 2.05;
    //float V3 = 2.79;
    //float V4 = 5.0;
    void setup ()
    void loop(){
    float voltage = 10 *SensorValue * (5.0/1024.0);
    switch (voltage) {
      case 5.0:
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        break;
      case 2.79:
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
          delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        break;
      case 2.05:
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        break;
      case 1.68:
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        delay (1000);
        break;
    Но не компилируется с ошибкой
    sketch_aug15a:36: error: switch quantity not an integer
    Я пробовал сделать так
    int voltage = 10*sensorValue*(5.0/1024.0),
    компилируется, но в цирквите не работает...
  16. Tomasina
    в switch может быть только целое число, а не дробное.
    можно так:
    switch (voltage * 100) {
      case 500:
      case 297:
    Но тут switch мало подходит, ведь он сработает только если, например, voltage будет строго 2,97. А если намеряет 2.96 или 4.99, то условие не сработает. Тебе ведь нужен диапазон, а не строгое соответствие?
  17. Unixon
    Ну блин, кто ж так делает сравнение неточной величины ...
    Во-первых, напряжение измеряется с некоторой погрешностью и нужно сравнивать с интервалом, а не с константой.
    Во-вторых, switch-case работает только с целыми числами.
  18. Vetrinus
    Vetrinus Гик
    Я все это прекрасно понимаю, но считаю, что проблемы нужно решать по мере их поступления. Если в идеальных условиях в цирквите это заработало бы, то дальше я уже стал бы думать на счет интервала значений. А switch case я попробовал только потому, что его мне посоветовали.
  19. Vetrinus
    Vetrinus Гик
    если прописать voltage * 100, то при компиляции та же ошибка.
    Если прописать
    int voltage = 100 *SensorValue * (5.0/1024.0);
    switch (voltage) {
      case 500:
    и так далее
    то никаких действий не происходит вообще. С ифами медленно, но работало.
  20. Tomasina
    примерно так:
    #define PAUSE_LED 1000      // пауза между зажиганием LED, мсек
    #define PAUSE_MES 10000     // пауза между измерениями, мсек
    #define CONTROL A0
    const byte pinLed[10] = {13,12,11,10,9,7,6,5,4,3};  // массив с адресами пинов для LED
    const bool stateLed[4][10] = {     // маска состояний: ноль-LED выключен, единица-LED включен
      {0,0,0,0,0,0,0,0,0,0},           // для условия №1
      {1,1,1,1,1,0,0,0,0,0},           // для условия №2
      {0,0,0,0,0,1,1,1,1,1},
      {1,1,1,1,1,1,1,1,1,1}
      pinMode (CONTROL, INPUT);
      byte i = 0;
      while(pinLed[i]) pinMode(pinLed[i++], OUTPUT);  // настраиваем все LED-пины на OUTPUT
    }  // конец setup
      int SensorValue = analogRead (CONTROL);
      if (voltage>4.9 && voltage<5.1)          ledOperate(1);  // условие №1 - подаем на пины маску №1
      else if (voltage >2.7 && voltage <2.9)   ledOperate(2);
      else if (voltage >=1.9 && voltage <2.2)  ledOperate(3);
      else if (voltage >1.5 && voltage <1.8)   ledOperate(4);
      delay(PAUSE_MES);    // задержка перед следующим измерением
    }  // конец loop
    void ledOperate(byte state)  // функция включения-отключения соответствующих LED по номеру условия
      byte i = 0;
      while(pinLed[i])
        digitalWrite (pinLed[i], stateLed[state-1][i]);
        delay(PAUSE_LED);     // задержка перед зажиганием следующего LED
        i++;
    }  // конец ledOperate
    DrProg и Vetrinus нравится это.
