описываю подключение: Код (Javascript): // I2C I2C1.setup({scl:P1,sda:P0}); var g = require("SSD1306").connect(I2C1) после загрузки в консоли следующее: Код (Javascript): ERROR: Pin B10 is not capable of I2C1 SCL Suitable pins are: B6 B8 Uncaught Error: I2C device not responding at line 1 col 18 b.writeTo(c,[0,a]) ^ in function called from line 1 col 42 ...tion(a){b.writeTo(c,[0,a])});var a=new Uint8Array(129);a[0]=... ^ in function "flip" called from line 6 col 10 g.flip(); ^ in function "drawLcd" called from line 43 col 9 drawLcd(); ^ Uncaught Error: I2C device not responding at line 2 col 6 [0,a]) ^ in function called from line 2 col 8 [0,a])}) ^ in function called from system > =undefined > что делать? спасибо
